Newbie struggles having LinuxCNC to launch !
03 Mar 2014 01:39 - 03 Mar 2014 01:45 #44329 by cramredan
Hello;
While experimenting my first CNC environment (GeckoDrive540 drive on a Windows/Mach3 install), I have been highly annoyed by the lack of thinking and organization put in Mach3 interface. This awful and unprofessional product is certainly used by lots of windows aficionados, but this is typically the type of no brain software that pushes me to fly away from Windows !! Only pain in the neck in terms of overkilled complexity.
That said, "+1" brand new user to the Linux community... I decided to abandon my dear and friendly Windows and trash with joy this awful Mach3 configuration, only to dive into the unknown world... Linux/Emc2.
Please excuse my lack of experience and know-how in this forum.
Managed to download the latest installer in january 2014 "Ubuntu 10.04 'Lucid Lynx' along LinuxCNC (version 2.5 as displayed by the startup screen)" and installed it to my X64 Dell machine. Perfect Linux install.... but, LinuxCNC displays a big big error at startup...whatever sample config. file chosen.
Could somebody help me on this as I am completely stuck now... Many thanks in advance.
This is the error message I get :
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/cnc/linuxcnc/configs/GeckoDrive_540'
Machine configuration file is 'GeckoDrive_540.ini'
INIFILE=/home/cnc/linuxcnc/configs/GeckoDrive_540/GeckoDrive_540.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Realtime system did not load
Killing task linuxcncsvr, PID=7198
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_sched.ko': -1 Cannot allocate memory
7198
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: line 428:  7240 Erreur de segmentation  $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: line 428:  7241 Erreur de segmentation  $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
Kernel message information:
[ 3467.730900] I-pipe: Domain RTAI registered.
[ 3467.730905] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3467.730907] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3467.731010] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3467.731012] PIPELINE layers:
[ 3467.731014] fb215e20 9ac15d93 RTAI 200
[ 3467.731016] c085cb20 0 Linux 100
[ 3467.746322] vmap allocation for size 2101248 failed: use vmalloc=<size> to increase size.
[ 3467.746326] RTAI[malloc]: failed to initialize the global heap (size=2097152 bytes).
[ 3467.973174] halcmd[7240]: segfault at 8 ip 007b56bc sp bfdf92d0 error 6 in liblinuxcnchal.so.0[7b0000+8000]
[ 3467.975158] halcmd[7241]: segfault at 8 ip 00e356bc sp bf84cfe0 error 6 in liblinuxcnchal.so.0[e30000+8000]
[ 3467.979053] halcmd[7244]: segfault at 8 ip 005346bc sp bfdede10 error 6 in liblinuxcnchal.so.0[52f000+8000]
[ 3468.183416] halcmd[7248]: segfault at 8 ip 00eb36bc sp bf80d350 error 6 in liblinuxcnchal.so.0[eae000+8000]
[ 3468.387760] halcmd[7252]: segfault at 8 ip 002a16bc sp bf97d230 error 6 in liblinuxcnchal.so.0[29c000+8000]
[ 3468.591929] halcmd[7256]: segfault at 8 ip 00dd16bc sp bfecb600 error 6 in liblinuxcnchal.so.0[dcc000+8000]
[ 3468.796041] halcmd[7260]: segfault at 8 ip 00be66bc sp bfbafb20 error 6 in liblinuxcnchal.so.0[be1000+8000]
[ 3469.000129] halcmd[7264]: segfault at 8 ip 004656bc sp bf831010 error 6 in liblinuxcnchal.so.0[460000+8000]
[ 3469.204361] halcmd[7268]: segfault at 8 ip 001e66bc sp bff69870 error 6 in liblinuxcnchal.so.0[1e1000+8000]
[ 3470.042924] I-pipe: Domain RTAI unregistered.
[ 3470.043047] RTAI[hal]: unmounted.
Last edit: 03 Mar 2014 01:45 by BigJohnT. Reason: add code tags
03 Mar 2014 01:54 #44330 by BigJohnT
Replied by BigJohnT on topic Newbie struggles having LinuxCNC to launch !
How did you install LinuxCNC? Looks like you may not have the realtime kernel.
In a terminal what does uname -a return?
JT
03 Mar 2014 19:14 #44353 by andypugh
Replied by andypugh on topic Newbie struggles having LinuxCNC to launch !
In deference to your claimed Linux-newbiness...
You can open a terminal window from the top-left menu, under accessories. (Or ctrl-alt-T I think, it might be Ctrl-shift-T)
It is possible to get the information requested in the GUI, but it is much easier to suggest command-line instructions on a forum or chat.
So, open a terminal window, type
uname -a
and paste the result of the command here.
03 Mar 2014 21:59 #44361 by cramredan
Replied by cramredan on topic Newbie struggles having LinuxCNC to launch !
Hello BigJohn... Many thanks for your reply.... This is what i get :
Linux cnc-desktop 2.6.32-122-rtai #rtai SMP Tue Jul 27 12:44:07 CDT 2010 i686 GNU/Linux
03 Mar 2014 22:28 #44363 by andypugh
That is the correct kernel. The next most likely thing is a problem with the Local APIC. (LAPIC).
In the terminal again, type
dmesg
This will produce a ton of stuff, scroll back up to where the timestamp is zero (machine boot time) and see if you can see any lines mentioning "LAPIC" or "Local APIC"
03 Mar 2014 23:13 #44366 by cramredan
BigJohn, you'll find the dump of the dmesg terminal query. I see ACPI in it, but no sign of LAPIC neither Local APIC. Hope this helps diagnosing ! Thanks again.
rved
[ 0.481376] Switching to clocksource acpi_pm
[ 0.481764] pci 0000:00:03.0: PCI bridge, secondary bus 0000:01
[ 0.481764] pci 0000:00:03.0: IO window: 0xe000-0xefff
[ 0.481764] pci 0000:00:03.0: MEM window: 0xe6000000-0xe9ffffff
[ 0.481764] pci 0000:00:03.0: PREFETCH window: 0x000000c0000000-0x000000cfffffff
[ 0.481764] pci 0000:00:05.0: PCI bridge, secondary bus 0000:02
[ 0.481764] pci 0000:00:05.0: IO window: 0xc000-0xcfff
[ 0.481764] pci 0000:00:05.0: MEM window: 0xea000000-0xedffffff
[ 0.481764] pci 0000:00:05.0: PREFETCH window: 0x000000b0000000-0x000000bfffffff
[ 0.481764] pci 0000:00:10.0: PCI bridge, secondary bus 0000:03
[ 0.481764] pci 0000:00:10.0: IO window: 0xd000-0xdfff
[ 0.481764] pci 0000:00:10.0: MEM window: 0xdc000000-0xe3ffffff
[ 0.481764] pci 0000:00:10.0: PREFETCH window: 0xefe00000-0xefefffff
[ 0.481764] pci 0000:00:03.0: setting latency timer to 64
[ 0.481764] pci 0000:00:05.0: setting latency timer to 64
[ 0.481764] pci 0000:00:10.0: setting latency timer to 64
[ 0.481764] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.481764] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.481764] pci_bus 0000:01: resource 0 io: [0xe000-0xefff]
[ 0.481764] pci_bus 0000:01: resource 1 mem: [0xe6000000-0xe9ffffff]
[ 0.481764] pci_bus 0000:01: resource 2 pref mem [0xc0000000-0xcfffffff]
[ 0.481764] pci_bus 0000:02: resource 0 io: [0xc000-0xcfff]
[ 0.481764] pci_bus 0000:02: resource 1 mem: [0xea000000-0xedffffff]
[ 0.481764] pci_bus 0000:02: resource 2 pref mem [0xb0000000-0xbfffffff]
[ 0.481764] pci_bus 0000:03: resource 0 io: [0xd000-0xdfff]
[ 0.481764] pci_bus 0000:03: resource 1 mem: [0xdc000000-0xe3ffffff]
[ 0.481764] pci_bus 0000:03: resource 2 pref mem [0xefe00000-0xefefffff]
[ 0.481764] pci_bus 0000:03: resource 3 io: [0x00-0xffff]
[ 0.481764] pci_bus 0000:03: resource 4 mem: [0x000000-0xffffffff]
[ 0.481764] NET: Registered protocol family 2
[ 0.481764] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.481764] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.481764] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.481764] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.481764] TCP reno registered
[ 0.481764] NET: Registered protocol family 1
[ 0.500127] pci 0000:01:00.0: Boot video device
[ 0.500155] Simple Boot Flag value 0xd1 read from CMOS RAM was invalid
[ 0.500157] Simple Boot Flag at 0x3d set to 0x1
[ 0.500410] Scanning for low memory corruption every 60 seconds
[ 0.500482] audit: initializing netlink socket (disabled)
[ 0.500490] type=2000 audit(1393862420.497:1): initialized
[ 0.507398] highmem bounce pool size: 64 pages
[ 0.507403] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.508844] VFS: Disk quotas dquot_6.5.2
[ 0.508900] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.509421] fuse init (API version 7.13)
[ 0.509508] msgmni has been set to 1658
[ 0.509872] alg: No test for stdrng (krng)
[ 0.509936] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.509939] io scheduler noop registered
[ 0.509941] io scheduler anticipatory registered
[ 0.509943] io scheduler deadline registered
[ 0.509976] io scheduler cfq registered (default)
[ 0.510121] alloc irq_desc for 24 on node -1
[ 0.510123] alloc kstat_irqs on node -1
[ 0.510131] pcieport 0000:00:03.0: irq 24 for MSI/MSI-X
[ 0.510137] pcieport 0000:00:03.0: setting latency timer to 64
[ 0.510227] alloc irq_desc for 25 on node -1
[ 0.510229] alloc kstat_irqs on node -1
[ 0.510235] pcieport 0000:00:05.0: irq 25 for MSI/MSI-X
[ 0.510239] pcieport 0000:00:05.0: setting latency timer to 64
[ 0.510310] aer 0000:00:03.0:pcie02: AER service couldn't init device: no _OSC support
[ 0.510317] aer 0000:00:05.0:pcie02: AER service couldn't init device: no _OSC support
[ 0.510325] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.510345] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.510400] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.510403] ACPI: Power Button [PWRB]
[ 0.510459] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.510461] ACPI: Power Button [PWRF]
[ 0.510528] isapnp: Scanning for PnP cards...
[ 0.511581] hpet_acpi_add: no address or irqs in _CRS
[ 0.511628] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.512760] brd: module loaded
[ 0.513158] loop: module loaded
[ 0.513221] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.513347] pata_acpi 0000:00:0d.0: setting latency timer to 64
[ 0.513604] Fixed MDIO Bus: probed
[ 0.513632] PPP generic driver version 2.4.2
[ 0.513658] tun: Universal TUN/TAP device driver, 1.6
[ 0.513659] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.513725] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.513972] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 21
[ 0.513975] alloc irq_desc for 21 on node -1
[ 0.513977] alloc kstat_irqs on node -1
[ 0.513982] ehci_hcd 0000:00:0b.1: PCI INT B -> Link[APCL] -> GSI 21 (level, low) -> IRQ 21
[ 0.513989] ehci_hcd 0000:00:0b.1: setting latency timer to 64
[ 0.513992] ehci_hcd 0000:00:0b.1: EHCI Host Controller
[ 0.514018] ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
[ 0.514035] ehci_hcd 0000:00:0b.1: debug port 1
[ 0.514042] ehci_hcd 0000:00:0b.1: cache line size of 32 is not supported
[ 0.514056] ehci_hcd 0000:00:0b.1: irq 21, io mem 0xefffe000
[ 0.528021] ehci_hcd 0000:00:0b.1: USB 2.0 started, EHCI 1.00
[ 0.528102] usb usb1: configuration #1 chosen from 1 choice
[ 0.528125] hub 1-0:1.0: USB hub found
[ 0.528131] hub 1-0:1.0: 8 ports detected
[ 0.528178] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.528414] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 20
[ 0.528417] alloc irq_desc for 20 on node -1
[ 0.528418] alloc kstat_irqs on node -1
[ 0.528422] ohci_hcd 0000:00:0b.0: PCI INT A -> Link[APCF] -> GSI 20 (level, low) -> IRQ 20
[ 0.528429] ohci_hcd 0000:00:0b.0: setting latency timer to 64
[ 0.528432] ohci_hcd 0000:00:0b.0: OHCI Host Controller
[ 0.528459] ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
[ 0.528477] ohci_hcd 0000:00:0b.0: irq 20, io mem 0xeffff000
[ 0.586065] usb usb2: configuration #1 chosen from 1 choice
[ 0.586086] hub 2-0:1.0: USB hub found
[ 0.586094] hub 2-0:1.0: 8 ports detected
[ 0.586144] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.586206] PNP: No PS/2 controller found. Probing ports directly.
[ 0.586572] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.586578] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.586655] mice: PS/2 mouse device common for all mice
[ 0.586760] rtc_cmos 00:05: RTC can wake from S4
[ 0.586790] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.586817] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.586893] device-mapper: uevent: version 1.0.3
[ 0.587000] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.587170] device-mapper: multipath: version 1.1.0 loaded
[ 0.587172] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.587280] EISA: Probing bus 0 at eisa.0
[ 0.587285] Cannot allocate resource for EISA slot 1
[ 0.587304] EISA: Detected 0 cards.
[ 0.587306] cpuidle: using governor ladder
[ 0.587308] cpuidle: using governor menu
[ 0.587644] TCP cubic registered
[ 0.587777] NET: Registered protocol family 10
[ 0.588149] lo: Disabled Privacy Extensions
[ 0.588407] NET: Registered protocol family 17
[ 0.588435] Using IPI No-Shortcut mode
[ 0.588492] registered taskstats version 1
[ 0.588922] rtc_cmos 00:05: setting system clock to 2014-03-03 16:00:21 UTC (1393862421)
[ 0.588924] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.588926] EDD information not available.
[ 0.615666] Freeing initrd memory: 12828k freed
[ 0.840528] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 0.863509] isapnp: No Plug & Play device found
[ 0.863521] Freeing unused kernel memory: 620k freed
[ 0.863817] Write protecting the kernel text: 4540k
[ 0.863862] Write protecting the kernel read-only data: 1668k
[ 0.880492] udev: starting version 151
[ 0.922962] Linux agpgart interface v0.103
[ 0.942092] [drm] Initialized drm 1.1.0 20060810
[ 0.942896] sata_nv 0000:00:0e.0: version 3.5
[ 0.943194] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 23
[ 0.943199] alloc irq_desc for 23 on node -1
[ 0.943201] alloc kstat_irqs on node -1
[ 0.943207] sata_nv 0000:00:0e.0: PCI INT A -> Link[APSI] -> GSI 23 (level, low) -> IRQ 23
[ 0.943210] sata_nv 0000:00:0e.0: Using SWNCQ mode
[ 0.943251] sata_nv 0000:00:0e.0: setting latency timer to 64
[ 0.943367] scsi0 : sata_nv
[ 0.943480] scsi1 : sata_nv
[ 0.943622] ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xf800 irq 23
[ 0.943625] ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xf808 irq 23
[ 0.943868] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 23
[ 0.943871] sata_nv 0000:00:0f.0: PCI INT A -> Link[APSJ] -> GSI 23 (level, low) -> IRQ 23
[ 0.943873] sata_nv 0000:00:0f.0: Using SWNCQ mode
[ 0.943902] sata_nv 0000:00:0f.0: setting latency timer to 64
[ 0.943989] scsi2 : sata_nv
[ 0.944057] scsi3 : sata_nv
[ 0.944193] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xf300 irq 23
[ 0.944196] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xf308 irq 23
[ 0.944583] pata_amd 0000:00:0d.0: version 0.4.1
[ 0.944635] pata_amd 0000:00:0d.0: setting latency timer to 64
[ 0.944823] scsi4 : pata_amd
[ 0.944902] scsi5 : pata_amd
[ 0.945432] ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfd00 irq 14
[ 0.945435] ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xfd08 irq 15
[ 0.946511] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 0.946766] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 22
[ 0.946770] alloc irq_desc for 22 on node -1
[ 0.946771] alloc kstat_irqs on node -1
[ 0.946776] forcedeth 0000:00:14.0: PCI INT A -> Link[APCH] -> GSI 22 (level, low) -> IRQ 22
[ 0.946780] forcedeth 0000:00:14.0: setting latency timer to 64
[ 0.946804] nv_probe: set workaround bit for reversed mac addr
[ 0.965418] FDC 0 is a post-1991 82077
[ 0.976536] usb 1-1: configuration #1 chosen from 1 choice
[ 0.976610] hub 1-1:1.0: USB hub found
[ 0.976713] hub 1-1:1.0: 4 ports detected
[ 1.262452] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.408059] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.416379] ata1.00: ATA-7: Hitachi HDS721075KLA330, GK8OA97A, max UDMA/133
[ 1.416383] ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.432387] ata1.00: configured for UDMA/133
[ 1.432506] scsi 0:0:0:0: Direct-Access ATA Hitachi HDS72107 GK8O PQ: 0 ANSI: 5
[ 1.432637] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.432803] sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
[ 1.432848] sd 0:0:0:0: [sda] Write Protect is off
[ 1.432850] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.432873] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.433018] sda: sda1 sda2 sda3 sda4 <
[ 1.465119] forcedeth 0000:00:14.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:1e:c9:37:7a:96
[ 1.465122] forcedeth 0000:00:14.0: highdma pwrctl gbit lnktim desc-v3
[ 1.471769] sda5 sda6 sda7 sda8 sda9 >
[ 1.534024] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.568024] usb 2-2: new full speed USB device using ohci_hcd and address 2
[ 1.790120] usb 2-2: configuration #1 chosen from 1 choice
[ 1.900554] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.908671] ata2.00: ATAPI: PLDS DVD+/-RW DH-16A6S, YD11, max UDMA/100
[ 1.928686] ata2.00: configured for UDMA/100
[ 1.930505] scsi 1:0:0:0: CD-ROM PLDS DVD+-RW DH-16A6S YD11 PQ: 0 ANSI: 5
[ 1.936014] sr0: scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.936017] Uniform CD-ROM driver Revision: 3.20
[ 1.936122] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.936172] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.096039] usb 2-4: new low speed USB device using ohci_hcd and address 3
[ 2.258482] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.258568] ata6: port disabled. ignoring.
[ 2.261196] ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
[ 2.261203] alloc irq_desc for 17 on node -1
[ 2.261205] alloc kstat_irqs on node -1
[ 2.261213] ohci1394 0000:03:05.0: PCI INT A -> Link[APC2] -> GSI 17 (level, low) -> IRQ 17
[ 2.261219] ohci1394 0000:03:05.0: setting latency timer to 64
[ 2.273406] ACPI: PCI Interrupt Link [APC5] enabled at IRQ 16
[ 2.273410] alloc irq_desc for 16 on node -1
[ 2.273412] alloc kstat_irqs on node -1
[ 2.273417] nouveau 0000:01:00.0: PCI INT A -> Link[APC5] -> GSI 16 (level, low) -> IRQ 16
[ 2.273421] nouveau 0000:01:00.0: setting latency timer to 64
[ 2.274835] [drm] nouveau 0000:01:00.0: Detected an NV50 generation card (0x092880a2)
[ 2.275278] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PRAMIN
[ 2.275899] usbcore: registered new interface driver hiddev
[ 2.289168] generic-usb: probe of 0003:0955:000A.0001 failed with error -22
[ 2.289199] usbcore: registered new interface driver usbhid
[ 2.289202] usbhid: v2.6:USB HID core driver
[ 2.317557] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[17] MMIO=[e3fff000-e3fff7ff] Max Packet=[2048] IR/IT contexts=[8/8]
[ 2.318119] usb 2-4: configuration #1 chosen from 1 choice
[ 2.331164] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 2.331167] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 2.331170] [drm] nouveau 0000:01:00.0: Bios version 62.92.3a.00
[ 2.331172] [drm] nouveau 0000:01:00.0: TMDS table revision 2.0 not currently supported
[ 2.331175] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 4.0
[ 2.331178] [drm] nouveau 0000:01:00.0: DCB connector table: VHER 0x40 5 16 4
[ 2.331181] [drm] nouveau 0000:01:00.0: 0: 0x00001030: type 0x30 idx 0 tag 0x07
[ 2.331183] [drm] nouveau 0000:01:00.0: 1: 0x00002130: type 0x30 idx 1 tag 0x08
[ 2.331185] [drm] nouveau 0000:01:00.0: 2: 0x00000210: type 0x10 idx 2 tag 0xff
[ 2.331188] [drm] nouveau 0000:01:00.0: 3: 0x00000211: type 0x11 idx 2 tag 0xff
[ 2.331190] [drm] nouveau 0000:01:00.0: 4: 0x00000213: type 0x13 idx 2 tag 0xff
[ 2.331192] [drm] nouveau 0000:01:00.0: Raw DCB entry 0: 02000300 00000028
[ 2.331195] [drm] nouveau 0000:01:00.0: Raw DCB entry 1: 01000302 00000030
[ 2.331197] [drm] nouveau 0000:01:00.0: Raw DCB entry 2: 04011310 00000028
[ 2.331199] [drm] nouveau 0000:01:00.0: Raw DCB entry 3: 02011312 00000030
[ 2.331201] [drm] nouveau 0000:01:00.0: Raw DCB entry 4: 010223f1 00c0c080
[ 2.331208] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xC14D
[ 2.331259] input: USB Receiver as /devices/pci0000:00/0000:00:0b.0/usb2/2-4/2-4:1.0/input/input3
[ 2.331312] generic-usb 0003:05AF:3062.0002: input,hidraw0: USB HID v1.10 Keyboard [ USB Receiver] on usb-0000:00:0b.0-4/input0
[ 2.352409] input: USB Receiver as /devices/pci0000:00/0000:00:0b.0/usb2/2-4/2-4:1.1/input/input4
[ 2.352506] generic-usb 0003:05AF:3062.0003: input,hiddev96,hidraw1: USB HID v1.10 Mouse [ USB Receiver] on usb-0000:00:0b.0-4/input1
[ 2.372665] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xC526
[ 2.388523] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xD2A1
[ 2.388530] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xD3C3
[ 2.396589] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xD5F3
[ 2.396591] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0xD658
[ 2.420034] [drm] nouveau 0000:01:00.0: 0xD658: Condition still not met after 20ms, skipping following opcodes
[ 2.420040] [drm] nouveau 0000:01:00.0: 0xB342: parsing output script 0
[ 2.420042] [drm] nouveau 0000:01:00.0: 0xB342: parsing output script 0
[ 2.420044] [drm] nouveau 0000:01:00.0: 0x9F10: parsing output script 0
[ 2.503544] [TTM] Zone kernel: Available graphics memory: 431370 kiB.
[ 2.503547] [TTM] Zone highmem: Available graphics memory: 1417934 kiB.
[ 2.503556] [drm] nouveau 0000:01:00.0: 512 MiB VRAM
[ 2.517926] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 2.519754] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 2.523202] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 2.523606] [drm] nouveau 0000:01:00.0: Detected a DAC output
[ 2.523609] [drm] nouveau 0000:01:00.0: Detected a TMDS output
[ 2.523611] [drm] nouveau 0000:01:00.0: Detected a DAC output
[ 2.523613] [drm] nouveau 0000:01:00.0: Detected a TMDS output
[ 2.523615] [drm] nouveau 0000:01:00.0: DCB encoder 1 unknown
[ 2.523618] [drm] nouveau 0000:01:00.0: Detected a DVI-I connector
[ 2.523663] [drm] nouveau 0000:01:00.0: Detected a DVI-I connector
[ 2.656025] usb 2-6: new full speed USB device using ohci_hcd and address 4
[ 2.694110] [drm] nouveau 0000:01:00.0: allocated 1440x900 fb: 0x40250000, bo f712d000
[ 2.694164] fb0: nouveaufb frame buffer device
[ 2.694166] registered panic notifier
[ 2.694170] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 2.694185] nouveau 0000:02:00.0: enabling device (0000 -> 0003)
[ 2.694193] nouveau 0000:02:00.0: PCI INT A -> Link[APC5] -> GSI 16 (level, low) -> IRQ 16
[ 2.694198] nouveau 0000:02:00.0: setting latency timer to 64
[ 2.695492] [drm] nouveau 0000:02:00.0: Detected an NV50 generation card (0x092880a2)
[ 2.696065] [drm] nouveau 0000:02:00.0: Attempting to load BIOS image from PRAMIN
[ 2.696071] [drm] nouveau 0000:02:00.0: ... BIOS signature not found
[ 2.696072] [drm] nouveau 0000:02:00.0: Attempting to load BIOS image from PROM
[ 2.859277] [drm] nouveau 0000:02:00.0: ... appears to be valid
[ 2.859280] [drm] nouveau 0000:02:00.0: BIT BIOS found
[ 2.859283] [drm] nouveau 0000:02:00.0: Bios version 62.92.3a.00
[ 2.859285] [drm] nouveau 0000:02:00.0: TMDS table revision 2.0 not currently supported
[ 2.859288] [drm] nouveau 0000:02:00.0: Found Display Configuration Block version 4.0
[ 2.859291] [drm] nouveau 0000:02:00.0: DCB connector table: VHER 0x40 5 16 4
[ 2.859293] [drm] nouveau 0000:02:00.0: 0: 0x00001030: type 0x30 idx 0 tag 0x07
[ 2.859296] [drm] nouveau 0000:02:00.0: 1: 0x00002130: type 0x30 idx 1 tag 0x08
[ 2.859298] [drm] nouveau 0000:02:00.0: 2: 0x00000210: type 0x10 idx 2 tag 0xff
[ 2.859300] [drm] nouveau 0000:02:00.0: 3: 0x00000211: type 0x11 idx 2 tag 0xff
[ 2.859302] [drm] nouveau 0000:02:00.0: 4: 0x00000213: type 0x13 idx 2 tag 0xff
[ 2.859305] [drm] nouveau 0000:02:00.0: Raw DCB entry 0: 02000300 00000028
[ 2.859307] [drm] nouveau 0000:02:00.0: Raw DCB entry 1: 01000302 00000030
[ 2.859310] [drm] nouveau 0000:02:00.0: Raw DCB entry 2: 04011310 00000028
[ 2.859312] [drm] nouveau 0000:02:00.0: Raw DCB entry 3: 02011312 00000030
[ 2.859314] [drm] nouveau 0000:02:00.0: Raw DCB entry 4: 010223f1 00c0c080
[ 2.859322] [drm] nouveau 0000:02:00.0: Adaptor not initialised
[ 2.859324] [drm] nouveau 0000:02:00.0: Running VBIOS init tables
[ 2.859329] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0xC14D
[ 2.878134] usb 2-6: configuration #1 chosen from 1 choice
[ 2.890258] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:0b.0/usb2/2-6/2-6:1.0/input/input5
[ 2.890313] generic-usb 0003:046D:C52B.0004: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:0b.0-6/input0
[ 2.899409] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:0b.0/usb2/2-6/2-6:1.1/input/input6
[ 2.899497] generic-usb 0003:046D:C52B.0005: input,hiddev97,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:0b.0-6/input1
[ 2.912104] generic-usb 0003:046D:C52B.0006: hiddev98,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:0b.0-6/input2
[ 2.984225] usb 1-1.1: new full speed USB device using ehci_hcd and address 6
[ 2.996056] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0xC526
[ 3.012521] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0xD2A1
[ 3.012548] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0xD3C3
[ 3.020611] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0xD5F3
[ 3.020614] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table at offset 0xD658
[ 3.044043] [drm] nouveau 0000:02:00.0: 0xB342: parsing output script 0
[ 3.044045] [drm] nouveau 0000:02:00.0: 0xB342: parsing output script 0
[ 3.044048] [drm] nouveau 0000:02:00.0: 0x9F10: parsing output script 0
[ 3.079892] usb 1-1.1: configuration #1 chosen from 1 choice
[ 3.080118] hub 1-1.1:1.0: USB hub found
[ 3.080345] hub 1-1.1:1.0: 3 ports detected
[ 3.128225] [drm] nouveau 0000:02:00.0: 512 MiB VRAM
[ 3.142617] [drm] nouveau 0000:02:00.0: 512 MiB GART (aperture)
[ 3.142625] mtrr: no more MTRRs available
[ 3.142785] [drm] nouveau 0000:02:00.0: Allocating FIFO number 1
[ 3.146227] [drm] nouveau 0000:02:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 3.146641] [drm] nouveau 0000:02:00.0: Detected a DAC output
[ 3.146644] [drm] nouveau 0000:02:00.0: Detected a TMDS output
[ 3.146646] [drm] nouveau 0000:02:00.0: Detected a DAC output
[ 3.146648] [drm] nouveau 0000:02:00.0: Detected a TMDS output
[ 3.146650] [drm] nouveau 0000:02:00.0: DCB encoder 1 unknown
[ 3.146653] [drm] nouveau 0000:02:00.0: Detected a DVI-I connector
[ 3.146686] [drm] nouveau 0000:02:00.0: Detected a DVI-I connector
[ 3.152222] usb 1-1.2: new high speed USB device using ehci_hcd and address 7
[ 3.251683] No connectors reported connected with modes
[ 3.251688] [drm] Initialized nouveau 0.0.15 20090420 for 0000:02:00.0 on minor 1
[ 3.253067] vga16fb: initializing
[ 3.253070] vga16fb: mapped to 0xc00a0000
[ 3.253073] vga16fb: not registering due to another framebuffer present
[ 3.258853] [drm] nouveau 0000:01:00.0: 0xB346: parsing output script 1
[ 3.258866] [drm] nouveau 0000:01:00.0: 0xB347: parsing output script 2
[ 3.258892] [drm] nouveau 0000:01:00.0: 0xB186: parsing clock script 0
[ 3.259292] Console: switching to colour frame buffer device 180x56
[ 3.307037] usb 1-1.2: configuration #1 chosen from 1 choice
[ 3.313034] Initializing USB Mass Storage driver...
[ 3.313194] scsi6 : SCSI emulation for USB Mass Storage devices
[ 3.313300] usbcore: registered new interface driver usb-storage
[ 3.313303] USB Mass Storage support registered.
[ 3.313358] usb-storage: device found at 7
[ 3.313359] usb-storage: waiting for device to settle before scanning
[ 3.384094] usb 1-1.1.2: new full speed USB device using ehci_hcd and address 8
[ 3.484614] usb 1-1.1.2: configuration #1 chosen from 1 choice
[ 3.488122] input: Logitech BT Mini-Receiver as /devices/pci0000:00/0000:00:0b.1/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/input/input7
[ 3.488225] generic-usb 0003:046D:C718.0007: input,hidraw5: USB HID v1.11 Keyboard [Logitech BT Mini-Receiver] on usb-0000:00:0b.1-1.1.2/input0
[ 3.547246] xor: automatically using best checksumming function: pIII_sse
[ 3.564225] usb 1-1.1.3: new full speed USB device using ehci_hcd and address 9
[ 3.565013] pIII_sse : 9380.000 MB/sec
[ 3.565015] xor: using function: pIII_sse (9380.000 MB/sec)
[ 3.567003] device-mapper: dm-raid45: initialized v0.2594b
[ 3.592904] ieee1394: Host added: ID:BUS[0-00:1023] GUID[001d098a52f597dc]
[ 3.665052] usb 1-1.1.3: configuration #1 chosen from 1 choice
[ 3.672369] input: Logitech BT Mini-Receiver as /devices/pci0000:00/0000:00:0b.1/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/input/input8
[ 3.672485] generic-usb 0003:046D:C719.0008: input,hiddev99,hidraw6: USB HID v1.11 Mouse [Logitech BT Mini-Receiver] on usb-0000:00:0b.1-1.1.3/input0
[ 3.731866] EXT4-fs (sda8): mounted filesystem with ordered data mode
[ 8.318332] usb-storage: device scan complete
[ 8.322631] scsi 6:0:0:0: Direct-Access DELL USB HS-CF Card 7.08 PQ: 0 ANSI: 0
[ 8.326376] scsi 6:0:0:1: Direct-Access DELL USB HS-xD/SM 7.08 PQ: 0 ANSI: 0
[ 8.329877] scsi 6:0:0:2: Direct-Access DELL USB HS-MS Card 7.08 PQ: 0 ANSI: 0
[ 8.333125] scsi 6:0:0:3: Direct-Access DELL USB HS-SD Card 7.08 PQ: 0 ANSI: 0
[ 8.333712] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 8.333818] sd 6:0:0:1: Attached scsi generic sg3 type 0
[ 8.333922] sd 6:0:0:2: Attached scsi generic sg4 type 0
[ 8.334025] sd 6:0:0:3: Attached scsi generic sg5 type 0
[ 8.346236] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 8.359479] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[ 8.363977] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[ 8.368355] sd 6:0:0:3: [sde] Attached SCSI removable disk
[ 9.612649] udev: starting version 151
[ 9.622118] lp: driver loaded but no devices found
[ 9.669646] i2c i2c-6: nForce2 SMBus adapter at 0x1c00
[ 9.669664] i2c i2c-7: nForce2 SMBus adapter at 0x1c80
[ 9.688485] Adding 8304632k swap on /dev/sda9. Priority:-1 extents:1 across:8304632k
[ 9.709006] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 9.709527] dell-wmi: No known WMI GUID found
[ 9.804996] ACPI: PCI Interrupt Link [AAZA] enabled at IRQ 21
[ 9.805001] HDA Intel 0000:00:10.1: PCI INT B -> Link[AAZA] -> GSI 21 (level, low) -> IRQ 21
[ 9.805004] hda_intel: Disable MSI for Nvidia chipset
[ 9.805034] HDA Intel 0000:00:10.1: setting latency timer to 64
[ 9.825846] type=1505 audit(1393858830.735:2): operation="profile_load" pid=874 name="/sbin/dhclient3"
[ 9.826335] type=1505 audit(1393858830.735:3): operation="profile_replace" pid=876 name="/sbin/dhclient3"
[ 9.826418] type=1505 audit(1393858830.735:4): operation="profile_load" pid=874 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 9.826734] type=1505 audit(1393858830.735:5): operation="profile_load" pid=874 name="/usr/lib/connman/scripts/dhclient-script"
[ 9.826910] type=1505 audit(1393858830.735:6): operation="profile_replace" pid=876 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 9.827228] type=1505 audit(1393858830.735:7): operation="profile_replace" pid=876 name="/usr/lib/connman/scripts/dhclient-script"
[ 9.944810] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 9.944815] alloc irq_desc for 19 on node -1
[ 9.944817] alloc kstat_irqs on node -1
[ 9.944823] SB-XFi 0000:03:07.0: PCI INT A -> Link[APC4] -> GSI 19 (level, low) -> IRQ 19
[ 9.944880] SB-XFi 0000:03:07.0: setting latency timer to 64
[ 10.364113] hda_codec: ALC1200: BIOS auto-probing.
[ 10.616092] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:10.1/input/input9
[ 10.622063] type=1505 audit(1393858831.531:8): operation="profile_load" pid=1102 name="/usr/share/gdm/guest-session/Xsession"
[ 10.622180] type=1505 audit(1393858831.531:9): operation="profile_replace" pid=1103 name="/sbin/dhclient3"
[ 10.622761] type=1505 audit(1393858831.531:10): operation="profile_replace" pid=1103 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 10.623082] type=1505 audit(1393858831.531:11): operation="profile_replace" pid=1103 name="/usr/lib/connman/scripts/dhclient-script"
[ 10.960858] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 10.960862] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 11.182262] ppdev: user-space parallel port driver
[ 11.373698] [drm] nouveau 0000:01:00.0: Allocating FIFO number 2
[ 11.377157] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 2
03 Mar 2014 23:24 #44367 by andypugh
Unfortunately it starts a bit too late (we don't see timestamp 0)
You can probably see the whole thing by opening /sys/log/kernel.log in the text editor.
03 Mar 2014 23:40 #44368 by cramredan
Sorry for the incomplete copy. This is the right printout ... (limited to zero timestamp !)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] KERNEL supported cpus:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Intel GenuineIntel
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] AMD AuthenticAMD
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] NSC Geode by NSC
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Cyrix CyrixInstead
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Centaur CentaurHauls
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Transmeta GenuineTMx86
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Transmeta TransmetaCPU
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] UMC UMC UMC UMC
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-provided physical RAM map:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009b800 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 000000000009b800 - 00000000000a0000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 0000000001e00000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 0000000001e00000 - 0000000001f00040 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 0000000001f00040 - 00000000afee0000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 00000000afee0000 - 00000000afee3000 (ACPI NVS)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 00000000afee3000 - 00000000afef0000 (ACPI data)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 00000000afef0000 - 00000000aff00000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 00000000f0000000 - 00000000f2000000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] BIOS-e820: 0000000100000000 - 0000000250000000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] DMI 2.5 present.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] last_pfn = 0xafee0 max_arch_pfn = 0x100000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] MTRR default type: uncachable
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] MTRR fixed ranges enabled:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 00000-9FFFF write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] A0000-BFFFF uncachable
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] C0000-CBFFF write-protect
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] CC000-FFFFF uncachable
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] MTRR variable ranges enabled:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0 base 100000000 mask F00000000 write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 1 base 200000000 mask FC0000000 write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 2 base 240000000 mask FF0000000 write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 3 base 000000000 mask F80000000 write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 4 base 080000000 mask FE0000000 write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 5 base 0A0000000 mask FF0000000 write-back
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 6 base 0AFF00000 mask FFFF00000 uncachable
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 7 disabled
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] e820 update range: 00000000aff00000 - 0000000100000000 (usable) ==> (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Scanning 1 areas for low memory corruption
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified physical RAM map:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000000006000 - 000000000009b800 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 000000000009b800 - 00000000000a0000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000000100000 - 0000000001e00000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000001e00000 - 0000000001f00040 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000001f00040 - 00000000afee0000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 00000000afee0000 - 00000000afee3000 (ACPI NVS)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 00000000afee3000 - 00000000afef0000 (ACPI data)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 00000000afef0000 - 00000000aff00000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 00000000f0000000 - 00000000f2000000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 00000000fec00000 - 0000000100000000 (reserved)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] modified: 0000000100000000 - 0000000250000000 (usable)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] initial memory mapped : 0 - 00c00000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Using x86 segment limits to approximate NX protection
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0000000000 - 0000400000 page 4k
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0000400000 - 0037400000 page 2M
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0037400000 - 00377fe000 page 4k
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] kernel direct mapping tables up to 377fe000 @ 7000-c000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] RAMDISK: 37368000 - 37fef22b
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Allocated new RAMDISK: 008b5000 - 0153c22b
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Move RAMDISK from 0000000037368000 - 0000000037fef22a to 008b5000 - 0153c22a
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: RSDP 000f8280 00014 (v00 DELL )
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: RSDT afee3000 00040 (v01 DELL MC09 42302E31 NVDA 00000000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: FACP afee3080 00074 (v01 DELL MC09 42302E31 NVDA 00000000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0000000000000000/1 (20090903/tbfadt-557)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: DSDT afee3100 041BF (v01 DELL MC09 00001000 MSFT 03000000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: FACS afee0000 00040
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: HPET afee7380 00038 (v01 DELL MC09 42302E31 NVDA 00000098)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: MCFG afee73c0 0003C (v01 DELL MC09 42302E31 NVDA 00000000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: SLIC afee7400 00176 (v01 DELL MC09 42302E31 NVDA 0100000E)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: APIC afee72c0 00098 (v01 DELL MC09 42302E31 NVDA 00000000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: SSDT afee7f20 00380 (v01 PmRef CpuPm 00003000 INTL 20030224)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: BOOT afee7600 00028 (v01 DELL MC09 42302E31 NVDA 00000000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: Local APIC address 0xfee00000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 1926MB HIGHMEM available.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 887MB LOWMEM available.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] mapped low ram: 0 - 377fe000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] low ram: 0 - 377fe000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] node 0 low ram: 00000000 - 377fe000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] node 0 bootmap 00008000 - 0000ef00
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #4 [000009b800 - 0000100000] BIOS reserved ==> [000009b800 - 0000100000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #5 [00008b1000 - 00008b41a8] BRK ==> [00008b1000 - 00008b41a8]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #6 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #7 [00008b5000 - 000153c22b] NEW RAMDISK ==> [00008b5000 - 000153c22b]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] #8 [0000008000 - 000000f000] BOOTMAP ==> [0000008000 - 000000f000]
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] found SMP MP-table at [c00f3f40] f3f40
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Zone PFN ranges:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] DMA 0x00000000 -> 0x00001000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Normal 0x00001000 -> 0x000377fe
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] HighMem 0x000377fe -> 0x000afee0
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Movable zone start PFN for each node
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] early_node_map[4] active PFN ranges
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0: 0x00000000 -> 0x00000002
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0: 0x00000006 -> 0x0000009b
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0: 0x00000100 -> 0x00001e00
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] 0: 0x00001f01 -> 0x000afee0
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] On node 0 totalpages: 720246
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1f01000
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] DMA zone: 32 pages used for memmap
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] DMA zone: 0 pages reserved
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] DMA zone: 3959 pages, LIFO batch:0
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Normal zone: 1744 pages used for memmap
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Normal zone: 221229 pages, LIFO batch:31
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] HighMem zone: 3854 pages used for memmap
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] HighMem zone: 489428 pages, LIFO batch:31
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Using APIC driver default
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x1008
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x03] enabled)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] IOAPIC[0]: apic_id 4, version 17, address 0xfec00000, GSI 0-23
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: IRQ0 used by override.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: IRQ2 used by override.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: IRQ9 used by override.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: IRQ14 used by override.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] ACPI: IRQ15 used by override.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] nr_irqs_gsi: 24
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Allocating PCI resources starting at aff00000 (gap: aff00000:40100000)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] PERCPU: Embedded 24 pages/cpu @c3800000 s74936 r0 d23368 u1048576
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] pcpu-alloc: s74936 r0 d23368 u1048576 alloc=1*4194304
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] pcpu-alloc: [0] 0 1 2 3
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 714616
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=02413898-0324-4ad5-aca3-94b292ce8511 ro quiet splash
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Enabling fast FPU save and restore... done.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Enabling unmasked SIMD FPU exception support... done.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Initializing CPU#0
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] allocated 14412160 bytes of page_cgroup
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Initializing HighMem for node 0 (000377fe:000afee0)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Memory: 2821440k/2882432k available (4539k kernel code, 58564k reserved, 1928k data, 620k init, 1973128k highmem)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] virtual kernel memory layout:
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Hierarchical RCU implementation.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] NR_IRQS:2304 nr_irqs:440
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] I-pipe 2.6-03: pipeline enabled.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] spurious 8259A interrupt: IRQ7.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Console: colour VGA+ 80x25
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] console [tty0] enabled
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Fast TSC calibration using PIT
Mar 3 16:00:31 cnc-desktop kernel: [ 0.000000] Detected 2500.271 MHz processor.
Mar 3 16:00:31 cnc-desktop kernel: [ 0.008005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5000.54 BogoMIPS (lpj=10001084)
03 Mar 2014 23:53 #44370 by andypugh
It could be this. There is a solution fouind by someone else here: www.linuxcnc.org/index.php/english/forum...imit=6&start=6#16132
I have no idea why only you two would see this problem.
04 Mar 2014 01:37 #44374 by cramredan
BINGO ! Thanks a lot for your precious help BigJohn. It works fine now... I followed the previous thread link and discovered i also had a double GT880 NVidia graphic card... so that's maybe the cultprit for increased memory requirements.
This is what i've done to solve the problem:
> Typed the following in Accessories>Terminal (because the grub.cfg file was only in read mode in graphical user mode)
cd /etc/default
sudo gedit grub
> Typed my admin password at sudo password prompt (even if my typing was not displayed, it took my digits into account, then I hit ENTER)
> The grub.cfg file then appeared in read/write mode.
> Changed the command line to : "GRUB_CMDLINE_LINUX_DEFAULT="quiet splash vmalloc=256M"
> Restarted the machine
> Launched LinuxCNC
> Brilliant. The app launches !
Thanks again for your help.
Time to create page: 0.111 seconds
