I inadvertently updated to 12.04 LTS
- johns00056
03 Mar 2014 14:07 #44343
by johns00056
I inadvertently updated to 12.04 LTS was created by johns00056
I inadvertently updated to 12.04 LTS. This is a new install. I am completely new to LINUX. How do I fix this?
Can I just boot from the CD and start all over again?
- ArcEye
- Thank you received: 758
03 Mar 2014 15:22 #44344
by ArcEye
In the circumstances, it is probably the easiest option.
You could stay with 12.04 and install different kernel, realtime and linuxcnc packages, but without any linux knowledge that is probably a recipe for disaster
So yes, start again, overwrite the partition and keep your mouse away from the dist upgrade button
Replied by ArcEye on topic I inadvertently updated to 12.04 LTS
- Thank you received: 4966
03 Mar 2014 19:18 #44354
Yes, though if you have a working machine config then you probably want to back-up the linuxcnc directory onto a USB drive first.
If you fancy the challenge of running LinuxCNC on a Ubuntu version that is only 2 years out of date, rather than 4...
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
Replied by andypugh on topic I inadvertently updated to 12.04 LTS
- johns00056
03 Mar 2014 22:42 #44365
by johns00056
Replied by johns00056 on topic I inadvertently updated to 12.04 LTS
I got it working, thanks a lot.
Time to create page: 0.133 seconds
