Install on Gigiabyte H81M-S2PH
11 Mar 2014 16:51 #44656 by GPtech
Install on Gigiabyte H81M-S2PH was created by GPtech
Hi everyone,
I'm trying to install linuxcnc with this motherboard Gigiabyte H81M-S2PH (which has a built in LPT and COM ports) using a Intel G3220 processor and 4gb of Ram.
I can get the LiveCD to boot to the desktop but as soon as I click on anything the screen goes to the "Log In" screen and I can't get back to the desktop.
I've tried the LiveCD on a laptop and it works fine.
Can anyone help?
Thanks.
11 Mar 2014 16:58 #44657 by ArcEye
Replied by ArcEye on topic Install on Gigiabyte H81M-S2PH
Hi
That is extremely weird, because there is no log in screen on the live CD.
The only thing I can think of immediately, is this is some strange UEFI thing, because it detects the booting of an unsigned OS
Go into BIOS and disable secure boot and UEFI completely if you can and try again
11 Mar 2014 17:00 #44658 by GPtech
Replied by GPtech on topic Install on Gigiabyte H81M-S2PH
Hi, yes I've already done that. All UEFI has been changed to Legacy.
11 Mar 2014 17:02 #44659 by GPtech
The only thing I haven't done is to remove one of the 2gb Ram sticks.
I might try that tomorrow as it has burned me out a bit today trying to get it to work.
Thanks,
Grant.
12 Mar 2014 08:19 #44716 by GPtech
Hi, I tried it with just 2gb of ram but it made no difference.
I also burnt a cd using infrarecorder and imgburn, with verified burn after, and MD5 verified.
Here is a youtube video of what happens.
I really want to get linuxcnc installed on this pc
Thanks.
12 Mar 2014 10:52 #44719 by GPtech
I FOUND THE PROBLEM! :woohoo:
I was just about to give up but I thought I would download the 10.04 live cd without linuxcnc to see what that did. Low and behold it did exactly the same thing that the linuxcnc disk did.
I found out that the username on the livecd is "ubuntu" and password is blank. This would bring me back to the desktop, as soon as I clicked the left mouse button, boom, back to the log in screen. Hmmm.
Then it occurred to me that whenever I clicked the lmb the screen would go blank and I would be back at the login screen.
So, I swapped out my Logitech G300 mouse for a Logitech M90 and no more problem.
I'm currently trying to install so we'll see if I have anymore hiccups.
The following user(s) said Thank You: ArcEye
12 Mar 2014 13:38 #44723 by GPtech
Ok, I now have Linuxcnc installed.
You must install using the VGA monitor port and a basic mouse or at least not the Logitech G300 mouse.
This mouse has a known issue, here is the fix
ubuntuforums.org/showthread.php?t=184904...1424355#post11424355
I now have the mouse working correctly.
My latency test is 4078 for servo and 6319 for base.
Hope this helps anyone else that is going to use this motherboard.
The following user(s) said Thank You: eFalegname
12 Mar 2014 16:00 #44730 by ArcEye
Well done for persisting, I have never seen that happen, some peculiar interaction between your mouse and gdm or whatever.
I seldom if ever run the Live Cd itself, just install straight away and was not even aware that there was a password (of sorts)
Time to create page: 0.107 seconds
