Possible to run LinuxCNC on Macintosh PowerPC G5?
- hamburg65
13 Mar 2014 06:30 #44746
by hamburg65
Possible to run LinuxCNC on Macintosh PowerPC G5? was created by hamburg65
Hey community,
Simple Question:
Is it possible to run LinuxCNC on Macintosh PowerPC G5?
I have the G5 as 'working machine' without use. I dont need OSX on it.
I found this project: www.mintppc.org/about and that:
wiki.ubuntu.com/PowerPCDownloads/
So theoretically Ubuntu should work, but how I manage to modify LinuxCNC ?
Thanks in advance!
Best regards from Austria
Matei
Simple Question:
Thanks in advance!
Matei
- jmelson
- Thank you received: 159
13 Mar 2014 09:39 #44747
by jmelson
doubt it. If you do, how will you control a machine with it? it has
no usable ports, as far as I know. Some people have built a sim version
of LinuxCNC to run on Apple hardware, but I doubt it was worth
the trouble.
Jon
Replied by jmelson on topic Possible to run LinuxCNC on Macintosh PowerPC G5?
Can you get RTAI on that kernel? On a Power PC architecture? IHey community,
Simple Question:
the trouble.
Jon
- Thank you received: 4976
13 Mar 2014 10:21 #44748
I run LinuxCNC all the time under VMware on my Mac. In fact I do LinuxCNC development while sat at a Mac.
But: The typical Mac has no usable IO ports for LinuxCNC.
It is just about possible that a Mac with PCI ports booted into Linux would work with a LinuxCNC-supported PCI card.
In fact, LinuxCNC has been made to run on a Mac natively in the past, but I am not sure if he made it control hardware.
The G5 adds a complication. I am not sure if PowerPC RTAI kernels exist.
Replied by andypugh on topic Possible to run LinuxCNC on Macintosh PowerPC G5?
- galfenol
10 Apr 2014 20:30 #45793
by galfenol
Replied by galfenol on topic Possible to run LinuxCNC on Macintosh PowerPC G5?
I recently acquired a USB dongle from Ecklersoft.com for a very reasonable price, which allows my intel iMac running Mac OSX 10.9.2 to control 4 stepper motors using Eckler's "rtstepper" software. It worked right out of the box with very little effort. The software runs natively on the Mac, no installation of Linux is needed. There are also builds for Windows and Linux.
Since the source code is available at:
ecklersoft.com/download.shtml and at
code.google.com/p/rtstepperemc/
it may be possible to do a build of the software for your Mac G5.
This is a stripped down build of LinuxCNC and the "tkmini" gui, that removes the real time components. They are not needed, because the USB dongle has a memory buffer that mimics the performance of a real time system. I plan to measure the performance of the product and compare it to a conventional LinuxCNC system. This product may address the problem that it is getting harder to find new motherboards with parallel port support.
Time to create page: 0.072 seconds
