64bit + linux-3.8.13/rtai-4.0 + linuxcnc-2.6.0-pre
05 May 2014 18:03 - 05 May 2014 18:04 #46611 by rythmnbls
The kernel patch came from the links below..
Thread discussing the patch comments.gmane.org/gmane.linux.real-time.rtai/24950
Link to the patch cvs.gna.org/cvsweb/magma/base/arch/x86/patches/?cvsroot=rtai
Kernel config attached.
Regards.
Steve.
Last edit: 05 May 2014 18:04 by rythmnbls.
05 May 2014 18:05 - 05 May 2014 18:23 #46612 by rythmnbls
2nd attempt to attach the config file.
Last edit: 05 May 2014 18:23 by rythmnbls. Reason: attaching the config - again :)
05 May 2014 18:19 #46613 by ArcEye
Try renaming it to config.txt
txt is about the only thing certain to work B)
05 May 2014 18:23 #46614 by ArcEye
I am obviously missing something.
All the patches are named x86 and not x86_64
Are you saying that the x86 patches work on x86_64?
If so, I have been assuming that no patches existed since 2.6.34, because of the name of them :(
05 May 2014 18:25 #46615 by rythmnbls
From the linked thread.
Starting with kernel 2.6.24, the sources for arch/x86_64 and arch/i386 have been unified into a single x86
directory. This is why the more recent patches can be found in base/arch/x86/patches. While the released
versions don't seem to include a 2.6.26 patch, you can get one from cvs:
Regards,
Steve
05 May 2014 18:28 #46616 by ArcEye
Great, if you can attach your config as a txt file or in a zip, 2 ways guaranteed to work, I will try building it now
cheers
05 May 2014 18:35 #46619 by rythmnbls
I edited my earlier post, its attached there.
Steve.
The following user(s) said Thank You: ArcEye
05 May 2014 19:38 #46623 by rythmnbls
Some more things I should mention..
The config file is for a vanilla kernel from kernel.org
The linuxcnc sources will complain about sse math and version.h during the realtime modules build, my fixes are below.
version.h can be fixed with a simple symlink
root:~/linux-3.8.13/include/linux# ls -al version.h
lrwxrwxrwx 1 root root 33 Apr 14 17:23 version.h -> ../generated/uapi/linux/version.h
Attached is a patch for the x86 kernel Makefile, this is probably entirely wrong, but it worked for me. :whistle:
Steve.
05 May 2014 22:12 #46631 by ArcEye
Thanks, I could not build on my existing x86_64 partition easily as I have nvidia drivers installed and would have to keep switching configs.
Just finished installing on a new x86_64 partition.
Your kernel config is quite similar to one I used for 3.8.0, but with newest processor instruction set and a much reduced set of modules
I will see what shakes out
05 May 2014 23:02 #46634 by Bari
Are you using the RTAI 4.0 Tarball or something else?
www.rtai.org/userfiles/downloads/RTAI/
Time to create page: 0.169 seconds
