Advice
10 May 2014 14:23 #46787 by nissjay
Advice was created by nissjay
I would like to get Linuxcnc original disc or dvd from Linux org as I could not get installed Linux cnc on my new win xp pro desk top. Itried so many times with out luck as it always come up with an error.
re
nissjay
10 May 2014 15:30 #46788 by ArcEye
Replied by ArcEye on topic Advice
Hi
There is no facility to supply CDs from linuxcnc.org, it would have to be an informal arrangement with another member, preferably in Australia to keep shipping costs down.
Go to the user map and you can see the members in your area who have specified their address ( a lot do not) and you could PM one nearest to you who seems active.
www.linuxcnc.org/index.php/english/linuxcnc-user-map
If you can be specific as to the errors you get, we should be able to help.
An XP is unlikely to have UEFI, so that leaves a 95% chance that it is the burning process under windoze that is the problem
Follow the instructions here
www.linuxcnc.org/docs/devel/html/common/Getting_LinuxCNC.html
10 May 2014 18:10 #46791 by BigJohnT
Replied by BigJohnT on topic Advice
I'm guessing you did not follow the instructions as no luck is involved.
linuxcnc.org/docs/html/common/Getting_EMC.html
JT
Time to create page: 0.103 seconds
