libmodbus-dev
- REEEN
21 May 2014 01:51 #47117
by REEEN
libmodbus-dev was created by REEEN
Hello,
I'm trying to update to Linuxcnc Master Branch, but something with libmodbus-dev package is wrong I can not install it, it can not be found...
I have to do this really quick, fast help would be really good.
Thank you guys!
Greets REEEN
Thank you guys!
Greets REEEN
- rythmnbls
21 May 2014 03:26 #47118
by rythmnbls
Replied by rythmnbls on topic libmodbus-dev
Do you need really libmodbus? if not, compile without it by adding --with-libmodbus=no to the configure command.
Regards.
Steve.
Regards.
Steve.
- Thank you received: 4989
21 May 2014 06:49 #47128
www.linuxcnc.org/docs/devel/html/drivers...ml#_programming_note
Says that it isn't there in Lucid (and gives one solution).
You could try moving on to Precise:
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
Replied by andypugh on topic libmodbus-dev
- REEEN
21 May 2014 14:19 #47140
by REEEN
Replied by REEEN on topic libmodbus-dev
Hello folks,
I solved the problem, I reinstalled ubuntu and installed master with git in the terminal and somehow it works.
Thank you for your fast answers !!
Greets Rene
Greets Rene
Time to create page: 0.195 seconds
