LinuxCNC On Ubuntu Precise
- blacksmith99
- Thank you received: 4
27 May 2014 10:00 - 28 May 2014 07:43 #47380
by blacksmith99
LinuxCNC On Ubuntu Precise was created by blacksmith99
Hello,
I followed the install process at this website: LinuxCNC On Ubuntu Precise
Everything went fine until I got to:
Step 6. Install the RTAI kernel and modules by running: sudo apt-get install linux-image-3.4.55-rtai-2 rtai-modules-3.4.55-rtai-2
This created errors, I'm sorry I wasn't able capture them. I had to remove the files with :
sudo apt-get install --uninstall linux-image-3.4.55-rtai-2
sudo apt-get install --uninstall rtai-modules-3.4.55-rtai-2
To get this to install correctly after removing the files I had to break it the commands into two parts:
sudo apt-get install rtai-modules-3.4.55-rtai-2
This worked without errors.
A reminder to reboot after Step 11 will take care of the shmem memory error I got.
I would post this somewhere where the original author could see it but I'm not sure where to do that. If comeone could forward this information to the author so the page could be updated I would appreciate it.
If there is an updated real time kernel I should be using please direct me to it.
Thanks!
Regards,
Matt
Thanks!
Regards,
Matt
Last edit: 28 May 2014 07:43 by blacksmith99. Reason: Link wasn't showing.
The following user(s) said Thank You: emcPT
- emcPT
- Thank you received: 139
27 May 2014 17:27 #47388
by emcPT
Replied by emcPT on topic LinuxCNC On Ubuntu Precise
Thank you for sharing info. Always welcome.
Time to create page: 0.114 seconds
