LinuxCNC On Ubuntu Precise - ACPI error
- redbase
28 May 2014 10:02 - 28 May 2014 18:17 #47435
by redbase
LinuxCNC On Ubuntu Precise - ACPI error was created by redbase
Hi All
Fresh install of Precise 12.04.4 desktop i386 following wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise.
Max CPU's are set to 1, ACPI is enabled in BIOS and BIOS is the latest version.
No issues during install process however when trying to run HALCMD receive the error:
RTAPI: ERROR could not open shared memory (errorno=2)
Segmentation fault (core dumped)
DMesg has the complaint shown in the list below.
Can someone provide some comments on how to / where to look for a fix? Newbie to Linux
Greg
Greg
root@filament-1:/home/filament# dmesg
Linux version 3.4.55-rtai-2 (root@precise-x86) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Sun Dec 15 23:40:48 MST 2013
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
BIOS-e820: 0000000020200000 - 0000000040004000 (usable)
BIOS-e820: 0000000040004000 - 0000000040005000 (reserved)
BIOS-e820: 0000000040005000 - 00000000ccd15000 (usable)
BIOS-e820: 00000000ccd15000 - 00000000cd184000 (reserved)
BIOS-e820: 00000000cd184000 - 00000000cd194000 (ACPI data)
BIOS-e820: 00000000cd194000 - 00000000cd2b6000 (ACPI NVS)
BIOS-e820: 00000000cd2b6000 - 00000000cd84c000 (reserved)
BIOS-e820: 00000000cd84c000 - 00000000cd84d000 (usable)
BIOS-e820: 00000000cd84d000 - 00000000cd890000 (ACPI NVS)
BIOS-e820: 00000000cd890000 - 00000000cdcad000 (usable)
BIOS-e820: 00000000cdcad000 - 00000000cdff4000 (reserved)
BIOS-e820: 00000000cdff4000 - 00000000ce000000 (usable)
BIOS-e820: 00000000cf000000 - 00000000df200000 (reserved)
BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
BIOS-e820: 0000000100000000 - 000000041fe00000 (usable)
Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
SMBIOS 2.7 present.
DMI: System manufacturer System Product Name/P8H61-I R2.0, BIOS 0804 10/12/2012
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
last_pfn = 0xce000 max_arch_pfn = 0x100000
MTRR default type: uncachable
MTRR fixed ranges enabled:
00000-9FFFF write-back
A0000-BFFFF uncachable
C0000-CFFFF write-protect
D0000-E7FFF uncachable
E8000-FFFFF write-protect
MTRR variable ranges enabled:
0 base 000000000 mask C00000000 write-back
1 base 400000000 mask FE0000000 write-back
2 base 0E0000000 mask FE0000000 uncachable
3 base 0D0000000 mask FF0000000 uncachable
4 base 0CF000000 mask FFF000000 uncachable
5 base 41FE00000 mask FFFE00000 uncachable
6 disabled
7 disabled
8 disabled
9 disabled
x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
e820 update range: 00000000cf000000 - 0000000100000000 (usable) ==> (reserved)
found SMP MP-table at [c00fd770] fd770
initial memory mapped : 0 - 01c00000
Base memory trampoline at [c009c000] 9c000 size 4096
init_memory_mapping: 0000000000000000-00000000377fe000
0000000000 - 0000400000 page 4k
0000400000 - 0037400000 page 2M
0037400000 - 00377fe000 page 4k
kernel direct mapping tables up to 0x377fdfff @ [mem 0x01bf8000-0x01bfffff]
RAMDISK: 36684000 - 3733a000
ACPI: RSDP 000f0490 00024 (v02 ALASKA)
ACPI: XSDT cd187080 00074 (v01 ALASKA A M I 01072009 AMI 00010013)
ACPI: FACP cd191078 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
ACPI: DSDT cd187188 09EED (v02 ALASKA A M I 00000022 INTL 20051117)
ACPI: FACS cd2b4080 00040
ACPI: APIC cd191188 0005A (v03 ALASKA A M I 01072009 AMI 00010013)
ACPI: FPDT cd1911e8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
ACPI: MCFG cd191230 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
ACPI: HPET cd191270 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
ACPI: SSDT cd1912a8 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
ACPI: SSDT cd191618 005CC (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
ACPI: SSDT cd191be8 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
ACPI: SSDT cd192428 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
ACPI: DMAR cd192f18 000B0 (v01 INTEL SNB 00000001 INTL 00000001)
ACPI: Local APIC address 0xfee00000
2408MB HIGHMEM available.
887MB LOWMEM available.
mapped low ram: 0 - 377fe000
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
Normal 0x00001000 -> 0x000377fe
HighMem 0x000377fe -> 0x000ce000
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000010 -> 0x0000009d
0: 0x00000100 -> 0x00020000
0: 0x00020200 -> 0x00040004
0: 0x00040005 -> 0x000ccd15
0: 0x000cd84c -> 0x000cd84d
0: 0x000cd890 -> 0x000cdcad
0: 0x000cdff4 -> 0x000ce000
On node 0 totalpages: 839371
free_area_init_node: node 0, pgdat c160d9c0, node_mem_map f4cc4200
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 3949 pages, LIFO batch:0
Normal zone: 1744 pages used for memmap
Normal zone: 220974 pages, LIFO batch:31
HighMem zone: 4817 pages used for memmap
HighMem zone: 607855 pages, LIFO batch:31
Using APIC driver default
ACPI: PM-Timer IO Port: 0x408
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x8086a701 base: 0xfed00000
SMP: Allowing 1 CPUs, 0 hotplug CPUs
nr_irqs_gsi: 40
Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
PERCPU: Embedded 17 pages/cpu @f77da000 s47552 r0 d22080 u69632
pcpu-alloc: s47552 r0 d22080 u69632 alloc=17*4096
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 832778
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4.55-rtai-2 root=UUID=2046a44e-be2f-46c2-95fa-d00c1913e067 ro quiet splash maxcpus=1 vt.handoff=7
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Initializing CPU#0
xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
Initializing HighMem for node 0 (000377fe:000ce000)
Memory: 3309756k/3375104k available (4612k kernel code, 47728k reserved, 1613k data, 544k init, 2450688k highmem)
virtual kernel memory layout:
fixmap : 0xfff18000 - 0xfffff000 ( 924 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
.init : 0xc1615000 - 0xc169d000 ( 544 kB)
.data : 0xc148113d - 0xc1614580 (1613 kB)
.text : 0xc1000000 - 0xc148113d (4612 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
Dump stacks of tasks blocking RCU-preempt GP.
NR_IRQS:2304 nr_irqs:256 16
CPU 0 irqstacks, hard=f4808000 soft=f480a000
Extended CMOS year: 2000
Interrupt pipeline (release #3)
Console: colour dummy device 80x25
console [tty0] enabled
hpet clockevent registered
Fast TSC calibration using PIT
Detected 2999.980 MHz processor.
Calibrating delay loop (skipped), value calculated using timer frequency.. 5999.96 BogoMIPS (lpj=2999980)
pid_max: default: 32768 minimum: 301
Security Framework initialized
AppArmor: AppArmor initialized
Mount-cache hash table entries: 512
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
mce: CPU supports 9 MCE banks
CPU0: Thermal monitoring enabled (TM1)
SMP alternatives: switching to UP code
Freeing SMP alternatives: 20k freed
ACPI: Core revision 20120320
Enabling APIC mode: Flat. Using 1 I/O APICs
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
CPU0: Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz stepping 09
Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
... version: 3
... bit width: 48
... generic registers: 8
... value mask: 0000ffffffffffff
... max period: 000000007fffffff
... fixed-purpose events: 3
... event mask: 00000007000000ff
Brought up 1 CPUs
Total of 1 processors activated (5999.96 BogoMIPS).
devtmpfs: initialized
EVM: security.selinux
EVM: security.SMACK64
EVM: security.capability
dummy:
NET: Registered protocol family 16
EISA bus registered
ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
ACPI: bus type pci registered
PCI: Using configuration type 1 for base access
bio: create slab <bio-0> at 0
ACPI: Added _OSI(Module Device)
ACPI: Added _OSI(Processor Device)
ACPI: Added _OSI(3.0 _SCP Extensions)
ACPI: Added _OSI(Processor Aggregator Device)
ACPI: EC: Look up EC in DSDT
ACPI: Executed 1 blocks of module-level executable AML code
ACPI: Interpreter enabled
ACPI: (supports S0 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: Power Resource [FN00] (off)
ACPI: Power Resource [FN01] (off)
ACPI: Power Resource [FN02] (off)
ACPI: Power Resource [FN03] (off)
ACPI: Power Resource [FN04] (off)
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
pci 0000:00:02.0: [8086:0152] type 00 class 0x030000
pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
pci 0000:00:16.0: reg 10: [mem 0xf7d0a000-0xf7d0a00f 64bit]
pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
pci 0000:00:1a.0: reg 10: [mem 0xf7d08000-0xf7d083ff]
pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
pci 0000:00:1b.0: reg 10: [mem 0xf7d00000-0xf7d03fff 64bit]
pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
pci 0000:00:1d.0: reg 10: [mem 0xf7d07000-0xf7d073ff]
pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
pci 0000:00:1f.0: [8086:1c5c] type 00 class 0x060100
pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
pci 0000:00:1f.2: reg 24: [mem 0xf7d06000-0xf7d067ff]
pci 0000:00:1f.2: PME# supported from D3hot
pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
pci 0000:00:1f.3: reg 10: [mem 0xf7d05000-0xf7d050ff 64bit]
pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
pci 0000:00:01.0: PCI bridge to [bus 01-01]
pci 0000:00:1c.0: PCI bridge to [bus 02-02]
pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
pci 0000:03:00.0: reg 10: [io 0xe000-0xe0ff]
pci 0000:03:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
pci 0000:03:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
pci 0000:03:00.0: supports D1 D2
pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:1c.4: PCI bridge to [bus 03-03]
pci 0000:00:1c.4: bridge window [io 0xe000-0xefff]
pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
pci 0000:04:00.0: [1b21:1042] type 00 class 0x0c0330
pci 0000:04:00.0: reg 10: [mem 0xf7c00000-0xf7c07fff 64bit]
pci 0000:04:00.0: PME# supported from D3hot D3cold
pci 0000:00:1c.5: PCI bridge to [bus 04-04]
pci 0000:00:1c.5: bridge window [mem 0xf7c00000-0xf7cfffff]
pci_bus 0000:00: on NUMA node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *4 5 6 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 *14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 *15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 10 11 12 14 15)
vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
vgaarb: bridge control possible 0000:00:02.0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: pci_cache_line_size set to 64 bytes
reserve RAM buffer: 000000000009d800 - 000000000009ffff
reserve RAM buffer: 0000000040004000 - 0000000043ffffff
reserve RAM buffer: 00000000ccd15000 - 00000000cfffffff
reserve RAM buffer: 00000000cd84d000 - 00000000cfffffff
reserve RAM buffer: 00000000cdcad000 - 00000000cfffffff
reserve RAM buffer: 00000000ce000000 - 00000000cfffffff
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Switching to clocksource hpet
AppArmor: AppArmor Filesystem Enabled
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:00: [bus 00-3e]
pnp 00:00: [io 0x0000-0x0cf7 window]
pnp 00:00: [io 0x0cf8-0x0cff]
pnp 00:00: [io 0x0d00-0xffff window]
pnp 00:00: [mem 0x000a0000-0x000bffff window]
pnp 00:00: [mem 0x000c0000-0x000c3fff window]
pnp 00:00: [mem 0x000c4000-0x000c7fff window]
pnp 00:00: [mem 0x000c8000-0x000cbfff window]
pnp 00:00: [mem 0x000cc000-0x000cffff window]
pnp 00:00: [mem 0x000d0000-0x000d3fff window]
pnp 00:00: [mem 0x000d4000-0x000d7fff window]
pnp 00:00: [mem 0x000d8000-0x000dbfff window]
pnp 00:00: [mem 0x000dc000-0x000dffff window]
pnp 00:00: [mem 0x000e0000-0x000e3fff window]
pnp 00:00: [mem 0x000e4000-0x000e7fff window]
pnp 00:00: [mem 0x000e8000-0x000ebfff window]
pnp 00:00: [mem 0x000ec000-0x000effff window]
pnp 00:00: [mem 0x000f0000-0x000fffff window]
pnp 00:00: [mem 0xdf200000-0xfeafffff window]
pnp 00:00: [mem 0x00010000-0x0001ffff window]
pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
pnp 00:01: [mem 0xfed40000-0xfed44fff]
system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
pnp 00:02: [io 0x0000-0x001f]
pnp 00:02: [io 0x0081-0x0091]
pnp 00:02: [io 0x0093-0x009f]
pnp 00:02: [io 0x00c0-0x00df]
pnp 00:02: [dma 4]
pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
pnp 00:03: [mem 0xff000000-0xffffffff]
pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
pnp 00:04: [mem 0xfed00000-0xfed003ff]
pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
pnp 00:05: [io 0x002e-0x002f]
pnp 00:05: [io 0x004e-0x004f]
pnp 00:05: [io 0x0061]
pnp 00:05: [io 0x0063]
pnp 00:05: [io 0x0065]
pnp 00:05: [io 0x0067]
pnp 00:05: [io 0x0070]
pnp 00:05: [io 0x0080]
pnp 00:05: [io 0x0092]
pnp 00:05: [io 0x00b2-0x00b3]
pnp 00:05: [io 0x0680-0x069f]
pnp 00:05: [io 0x1000-0x100f]
pnp 00:05: [io 0xffff]
pnp 00:05: [io 0x0400-0x0453]
pnp 00:05: [io 0x0458-0x047f]
pnp 00:05: [io 0x0500-0x057f]
pnp 00:05: [io 0x164e-0x164f]
system 00:05: [io 0x0680-0x069f] has been reserved
system 00:05: [io 0x1000-0x100f] has been reserved
system 00:05: [io 0xffff] has been reserved
system 00:05: [io 0x0400-0x0453] has been reserved
system 00:05: [io 0x0458-0x047f] has been reserved
system 00:05: [io 0x0500-0x057f] has been reserved
system 00:05: [io 0x164e-0x164f] has been reserved
system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:06: [io 0x0070-0x0077]
pnp 00:06: [irq 8]
pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:07: [io 0x0454-0x0457]
system 00:07: [io 0x0454-0x0457] has been reserved
system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
pnp 00:08: [io 0x0000-0xffffffff disabled]
pnp 00:08: [io 0x0a00-0x0a1f]
pnp 00:08: [io 0x0290-0x029f]
pnp 00:08: [io 0x0a20-0x0a2f]
system 00:08: [io 0x0a00-0x0a1f] has been reserved
system 00:08: [io 0x0290-0x029f] has been reserved
system 00:08: [io 0x0a20-0x0a2f] has been reserved
system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:09: [io 0x0010-0x001f]
pnp 00:09: [io 0x0022-0x003f]
pnp 00:09: [io 0x0044-0x005f]
pnp 00:09: [io 0x0062-0x0063]
pnp 00:09: [io 0x0065-0x006f]
pnp 00:09: [io 0x0072-0x007f]
pnp 00:09: [io 0x0080]
pnp 00:09: [io 0x0084-0x0086]
pnp 00:09: [io 0x0088]
pnp 00:09: [io 0x008c-0x008e]
pnp 00:09: [io 0x0090-0x009f]
pnp 00:09: [io 0x00a2-0x00bf]
pnp 00:09: [io 0x00e0-0x00ef]
pnp 00:09: [io 0x04d0-0x04d1]
system 00:09: [io 0x04d0-0x04d1] has been reserved
system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:0a: [io 0x00f0-0x00ff]
pnp 00:0a: [irq 13]
pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:0b: [mem 0xfed1c000-0xfed1ffff]
pnp 00:0b: [mem 0xfed10000-0xfed17fff]
pnp 00:0b: [mem 0xfed18000-0xfed18fff]
pnp 00:0b: [mem 0xfed19000-0xfed19fff]
pnp 00:0b: [mem 0xf8000000-0xfbffffff]
pnp 00:0b: [mem 0xfed20000-0xfed3ffff]
pnp 00:0b: [mem 0xfed90000-0xfed93fff]
pnp 00:0b: [mem 0xfed45000-0xfed8ffff]
pnp 00:0b: [mem 0xff000000-0xffffffff]
pnp 00:0b: [mem 0xfee00000-0xfeefffff]
pnp 00:0b: [mem 0xdf200000-0xdf200fff]
system 00:0b: [mem 0xfed1c000-0xfed1ffff] has been reserved
system 00:0b: [mem 0xfed10000-0xfed17fff] has been reserved
system 00:0b: [mem 0xfed18000-0xfed18fff] has been reserved
system 00:0b: [mem 0xfed19000-0xfed19fff] has been reserved
system 00:0b: [mem 0xf8000000-0xfbffffff] has been reserved
system 00:0b: [mem 0xfed20000-0xfed3ffff] has been reserved
system 00:0b: [mem 0xfed90000-0xfed93fff] has been reserved
system 00:0b: [mem 0xfed45000-0xfed8ffff] has been reserved
system 00:0b: [mem 0xff000000-0xffffffff] has been reserved
system 00:0b: [mem 0xfee00000-0xfeefffff] could not be reserved
system 00:0b: [mem 0xdf200000-0xdf200fff] has been reserved
system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:0c: [mem 0x20000000-0x201fffff]
pnp 00:0c: [mem 0x40004000-0x40004fff]
system 00:0c: [mem 0x20000000-0x201fffff] has been reserved
system 00:0c: [mem 0x40004000-0x40004fff] has been reserved
system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
pnp: PnP ACPI: found 13 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
pci_bus 0000:00: resource 13 [mem 0xdf200000-0xfeafffff]
pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
pci_bus 0000:03: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
pci 0000:00:02.0: Boot video device
PCI: CLS 64 bytes, default 64
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 13016k freed
audit: initializing netlink socket (disabled)
type=2000 audit(1401181555.307:1): initialized
highmem bounce pool size: 64 pages
HugeTLB registered 4 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.18)
msgmni has been set to 1703
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Linux agpgart interface v0.103
agpgart-intel 0000:00:00.0: Intel Ivybridge Chipset
agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
agpgart-intel 0000:00:00.0: detected 262144K stolen memory
agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
brd: module loaded
loop: module loaded
ahci 0000:00:1f.2: version 3.0
ahci 0000:00:1f.2: irq 40 for MSI/MSI-X
ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
ahci 0000:00:1f.2: setting latency timer to 64
scsi0 : ahci
scsi1 : ahci
scsi2 : ahci
scsi3 : ahci
ata1: SATA max UDMA/133 abar m2048@0xf7d06000 port 0xf7d06100 irq 40
ata2: SATA max UDMA/133 abar m2048@0xf7d06000 port 0xf7d06180 irq 40
ata3: DUMMY
ata4: DUMMY
Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
PPP generic driver version 2.4.2
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:1a.0: setting latency timer to 64
ehci_hcd 0000:00:1a.0: EHCI Host Controller
ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:1a.0: debug port 2
ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
ehci_hcd 0000:00:1a.0: irq 23, io mem 0xf7d08000
ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci_hcd 0000:00:1d.0: setting latency timer to 64
ehci_hcd 0000:00:1d.0: EHCI Host Controller
ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:1d.0: debug port 2
ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7d07000
ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
uhci_hcd: USB Universal Host Controller Interface driver
xhci_hcd 0000:04:00.0: xHCI Host Controller
xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
xhci_hcd 0000:04:00.0: irq 41 for MSI/MSI-X
xhci_hcd 0000:04:00.0: irq 42 for MSI/MSI-X
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
i8042: PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mousedev: PS/2 mouse device common for all mice
rtc_cmos 00:06: RTC can wake from S4
rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
EISA: Probing bus 0 at eisa.0
EISA: Cannot allocate resource for mainboard
Cannot allocate resource for EISA slot 1
Cannot allocate resource for EISA slot 2
Cannot allocate resource for EISA slot 3
Cannot allocate resource for EISA slot 4
Cannot allocate resource for EISA slot 5
Cannot allocate resource for EISA slot 6
Cannot allocate resource for EISA slot 7
Cannot allocate resource for EISA slot 8
EISA: Detected 0 cards.
EFI Variables Facility v0.08 2004-May-17
TCP: cubic registered
NET: Registered protocol family 10
NET: Registered protocol family 17
Registering the dns_resolver key type
Using IPI Shortcut mode
registered taskstats version 1
rtc_cmos 00:06: setting system clock to 2014-05-27 09:05:56 UTC (1401181556)
BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
EDD information not available.
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[b]ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f4847000), AE_NOT_FOUND (20120320/psparse-536)
ata2.00: ATA-9: INTEL SSDSC2CT120A3, 300i, max UDMA/133
ata2.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT0._GTF] (Node f482dfa8), AE_NOT_FOUND (20120320/psparse-536)
ata1.00: ATAPI: TSSTcorp CDDVDW SH-224BB, SB00, max UDMA/100
ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT0._GTF] (Node f482dfa8), AE_NOT_FOUND (20120320/psparse-536)[/b]
ata1.00: configured for UDMA/100
usb 1-1: new high-speed USB device number 2 using ehci_hcd
scsi 0:0:0:0: CD-ROM TSSTcorp CDDVDW SH-224BB SB00 PQ: 0 ANSI: 5
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
cdrom: Uniform CD-ROM driver Revision: 3.20
sr 0:0:0:0: Attached scsi CD-ROM sr0
sr 0:0:0:0: Attached scsi generic sg0 type 5
ata2.00: configured for UDMA/133
scsi 1:0:0:0: Direct-Access ATA INTEL SSDSC2CT12 300i PQ: 0 ANSI: 5
sd 1:0:0:0: Attached scsi generic sg1 type 0
sd 1:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2 < sda5 >
sd 1:0:0:0: [sda] Attached SCSI disk
Freeing unused kernel memory: 544k freed
udevd[82]: starting version 175
r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
r8169 0000:03:00.0: irq 43 for MSI/MSI-X
r8169 0000:03:00.0: eth0: RTL8168f/8111f at 0xf802c000, 60:a4:4c:40:51:6b, XID 08000800 IRQ 43
r8169 0000:03:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
init: ureadahead main process (247) terminated with status 5
usb 2-1: new high-speed USB device number 2 using ehci_hcd
Adding 16460796k swap on /dev/sda5. Priority:-1 extents:1 across:16460796k SS
EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
Refined TSC clocksource calibration: 3000.020 MHz.
Switching to clocksource tsc
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 6 ports detected
udevd[364]: starting version 175
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
ACPI: Power Button [PWRB]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
ACPI: Power Button [PWRF]
wmi: Mapper loaded
[drm] Initialized drm 1.1.0 20060810
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
i915 0000:00:02.0: setting latency timer to 64
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
usb 2-1.3: new low-speed USB device number 3 using ehci_hcd
type=1400 audit(1401181557.344:2): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=544 comm="apparmor_parser"
type=1400 audit(1401181557.344:3): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=544 comm="apparmor_parser"
microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x12
type=1400 audit(1401181557.476:4): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=622 comm="apparmor_parser"
type=1400 audit(1401181557.476:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=622 comm="apparmor_parser"
type=1400 audit(1401181557.476:6): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=622 comm="apparmor_parser"
mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[drm] MTRR allocation failed. Graphics performance may suffer.
i915 0000:00:02.0: irq 44 for MSI/MSI-X
[drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[drm] Driver supports precise vblank timestamp query.
[drm:intel_dsm_platform_mux_info] *ERROR* MUX INFO call failed
vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
usb 2-1.4: new low-speed USB device number 4 using ehci_hcd
asus_wmi: ASUS WMI generic driver loaded
asus_wmi: Initialization: 0x0
asus_wmi: BIOS WMI version: 0.9
asus_wmi: SFUN value: 0x0
input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input2
microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
asus_wmi: Backlight controlled by ACPI video driver
input: PixArt Microsoft USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/input/input3
generic-usb 0003:045E:00CB.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Microsoft USB Optical Mouse] on usb-0000:00:1d.0-1.3/input0
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
input: Microsoft Wired Keyboard 600 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input/input4
generic-usb 0003:045E:0750.0002: input,hidraw1: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 600] on usb-0000:00:1d.0-1.4/input0
input: Microsoft Wired Keyboard 600 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.1/input/input5
generic-usb 0003:045E:0750.0003: input,hidraw2: USB HID v1.11 Device [Microsoft Wired Keyboard 600] on usb-0000:00:1d.0-1.4/input1
[drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
init: failsafe main process (716) killed by TERM signal
type=1400 audit(1401181557.801:7): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=859 comm="apparmor_parser"
type=1400 audit(1401181557.801:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper//chromium_browser" pid=859 comm="apparmor_parser"
type=1400 audit(1401181557.805:9): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=864 comm="apparmor_parser"
type=1400 audit(1401181557.808:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=864 comm="apparmor_parser"
fbcon: inteldrmfb (fb0) is primary device
r8169 0000:03:00.0: eth0: link down
ADDRCONF(NETDEV_UP): eth0: link is not ready
Console: switching to colour frame buffer device 240x67
fb0: inteldrmfb frame buffer device
drm: registered panic notifier
acpi device:3b: registered as cooling_device0
input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X
init: alsa-restore main process (927) terminated with status 19
input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
r8169 0000:03:00.0: eth0: link up
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: no IPv6 routers present
audit_printk_skb: 42 callbacks suppressed
type=1400 audit(1401181579.725:25): apparmor="DENIED" operation="open" parent=1 profile="/usr/lib/telepathy/mission-control-5" name="/usr/share/gvfs/remote-volume-monitors/" pid=2004 comm="mission-control" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
halcmd[2043]: segfault at 8 ip b7729695 sp bfd7d600 error 6 in liblinuxcnchal.so.0[b7725000+a000]
Last edit: 28 May 2014 18:17 by BigJohnT. Reason: add code tags
- ArcEye
- Thank you received: 758
28 May 2014 15:48 - 28 May 2014 20:09 #47440
by ArcEye
Replied by ArcEye on topic LinuxCNC On Ubuntu Precise - ACPI error
Hi
The error in dmesg may well be related to your BIOS and has occurred many times before especially with Ubuntu kernels it seems
bugzilla.kernel.org/show_bug.cgi?id=43229
Asus boards have been noted with this bug especially the Ivy Bridge chipset ones (i3 i5 i7)
However I have an Asus P8H61-M-Pro i7 board with none of those warnings and it runs the 3.4.55-rtai kernel just fine (albeit I am using Debian 7)
I would go back to the start, remove the packages, revert BIOS to multi-core and any other original settings and start the stock pae kernel and check dmesg.
If you still have the warnings, you then know it is nothing to do with the kernel
If not change the BIOS settings to as you had them but still boot the pae kernel
Any warnings then?
Remove the BIOS changes and install the new kernel and boot it
Any warnings?
Revert the BIOS changes and check again on a reboot etc
Then at least you will have a better idea where the problem in dmesg lies.
Any warnings then?
Any warnings?
Last edit: 28 May 2014 20:09 by ArcEye.
The following user(s) said Thank You: redbase
- redbase
03 Jun 2014 16:06 #47647
by redbase
Replied by redbase on topic LinuxCNC On Ubuntu Precise - ACPI error
Thanks for the feedback, we have this part up and running.
As suggested BIOS back to original settings - was a Gigabyte GA-P35-DS3R
Fresh install of 12.04.4 LTS with 3.4.55 RTAI-2 seems to work.
Cheers all
Cheers all
