Installation problems
- CaspianCmonster
19 Jun 2014 01:09 - 19 Jun 2014 02:17 #48079
by CaspianCmonster
Installation problems was created by CaspianCmonster
Hi, I feel like I should be able to find the answer without asking but I have not managed to so I am posting here.
The short version is that I have a new iso install that will not launch LinucCNC in simulation mode (my electronics are on there way but are not here yet)
the specs
ubuntu-10.04-linuxcnc3-i386.iso
the computer is an old used htpc I picked up. I am not sure my Mesa card is going to fit or not but anyway for now this is what I am trying.
global.aopen.com/products_detail.aspx?auno=2170
I am using the on board graphics but because I have read that that is some times a problem and that I will end up using the computer as a htpc if I can't get it to work for this I ordered a new graphics card to try out.
The image works in a virtual machine on my portable computer so I think that is fine. I have tried it before and after updates (but not upgrades since that will kill it)
the error file that gets shown when Linuxcnc fails is attached
thanks
the specs
thanks
Last edit: 19 Jun 2014 02:17 by CaspianCmonster. Reason: fixing attachment
- ArcEye
- Thank you received: 758
19 Jun 2014 01:49 #48081
by ArcEye
Replied by ArcEye on topic Installation problems
Nothing attached, change the extension to .txt and try again
- ArcEye
19 Jun 2014 03:08 #48086
by ArcEye
APIC is not configured or available
See this for info, if you cannot fix because the PC is too old, you can always install the 8.04 Live CD which does not require it
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
83.837165] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
The following user(s) said Thank You: CaspianCmonster
- Thank you received: 4989
19 Jun 2014 07:26 #48098
Every LinuxCNC machine I have used has used onboard graphics. That's only 4 or 5 machines, actually, but I think the problem is over-stated.
Replied by andypugh on topic Installation problems
Time to create page: 0.111 seconds
