10.04 image and Via Epia M10000 problems
- smartroad
29 Jun 2014 21:27 #48322
by smartroad
10.04 image and Via Epia M10000 problems was created by smartroad
Hi All,
I have installed the 10.04 image onto my Epia M10000 board. I am having a few issues with it. I can't get the latency test to load. Click on the icon and nothing happens, no message in the DMESG about it either. Also I am stuck at 800x600 and linux won't allow me to change with 'unknown monitor' and I am also getting graphical glitches.
Is anyone else using this board? It may well be that the board is faulty but wanted to see if anyone else is running on it.
Thanks for any pointers!
- ArcEye
- Thank you received: 758
29 Jun 2014 22:33 #48324
by ArcEye
Replied by ArcEye on topic 10.04 image and Via Epia M10000 problems
Hi
There appear to be 2 issues which should not be interlinked (hopefully)
Search 'Via Epia M10000 Ubuntu 10.04' and you will come up with shed loads of posts on Ubuntu forums re graphics problems, hopefully one will assist you.
Regards Linuxcnc, open a terminal and run latency-test ( or indeed linuxcnc) from there.
Now you will hopefully have a meaningful error message which will give some idea what is happening
- MrkiMedo
27 Oct 2014 21:56 #52436
by MrkiMedo
Replied by MrkiMedo on topic 10.04 image and Via Epia M10000 problems
Try to start linuxcnc, it might throw error dialog, with message like "local apic configured but.." near the bottom.
I am getting that error with Via C7 based motherboard. (and latency test silently ignores me, like you are experiencing)
- ArcEye
27 Oct 2014 22:19 #52438
by ArcEye
Hi
The latency test does not ignore you, it is just there is nowhere to display the errors
As per my last post, run linuxcnc from a terminal ( and latency-test) and you will get error messages that will tell you what is wrong
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
...........latency test silently ignores me, like you are experiencing..........
Time to create page: 0.056 seconds
