Released 2.6
30 Jul 2014 20:52 #49290 by tjamscad
Released 2.6 was created by tjamscad
Does the CD have this on it already? Will this work with out fail from 2.5?
30 Jul 2014 21:22 #49292 by ArcEye
Replied by ArcEye on topic Released 2.6
Hi
The CD has 2.5.3 or 2.5.4 on it, but based upon Ubuntu 10.04 still.
These are the instructions for upgrading, including the points to note for change of syntax in hm2 and HAL generally
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.6
There is already a DVD here with a 3.4.9-rtai kernel and realtime to suit
linuxcnc.org/binary.hybrid.iso
which has Debian wheezy with 2.6~pre-5 ready installed
I suspect this will be updated with the full 2.6 release before long, or you could install and do that manually easily.
It will work without fail but you have to appreciate that you are not upgrading from 2.5 to 2.6, you are trying to upgrade from a much older version indirectly
so some of your configs may not run at first.
There were changes to units in the configs, emc.nml was not required and crashed everything if it was etc.
You will just have to choose which path suits best and then ask for help if you get stuck.
It should only be something like the above and easy to fix
30 Jul 2014 21:27 #49293 by smalla
Replied by smalla on topic Released 2.6
on debian 7.6 include these packages in dependencies for a successfull configure:
bwidget
libtk-img
30 Jul 2014 21:46 - 30 Jul 2014 21:47 #49294 by ArcEye
bwidget
libtk-img
The DVD image I indicated is a fully working user install with all the necessary libraries, I have installed it to test it myself a couple of days ago.
If you are building from sources, yes you need a long list of dependencies including those two
The 2 you hilight are the gotchas, because they are python libs and are only used by the config picker when Linuxcnc is launched and pyVCP, in a lot of versions you can build quite happily
and then find it won't run because they are missing. B)
Last edit: 30 Jul 2014 21:47 by ArcEye.
30 Jul 2014 21:52 - 30 Jul 2014 21:52 #49295 by smalla
of course there are a lot more packages, but these two are not highlighted with dpkg-checkbuilddeps when building from source.
Last edit: 30 Jul 2014 21:52 by smalla.
31 Jul 2014 00:13 #49296 by ArcEye
Yeah, that's the gotcha
31 Jul 2014 00:40 #49297 by tjamscad
Replied by tjamscad on topic Released 2.6
but, the DVD has this so it will not be a problem later?
31 Jul 2014 02:14 #49302 by ArcEye
I have just read that the DVD image has been updated to the release version of 2.6 as well
31 Jul 2014 02:25 #49303 by tjamscad
And you can get it from where?
31 Jul 2014 03:32 - 31 Jul 2014 18:30 #49305 by ArcEye
Now see also
www.linuxcnc.org/index.php/english/forum...inuxcnc-260-released
Last edit: 31 Jul 2014 18:30 by ArcEye.
Time to create page: 0.082 seconds
