Fresh install Precise
- Iselman
22 Aug 2014 02:37 #50159
by Iselman
Fresh install Precise was created by Iselman
sudo apt-get install rtai-modules-3.4-9-rtai-686-pae, can't find package!
sudo apt-get install linux-image-3.4-9-rtai-686-pae is installing perfectly.
apt-key is of course ok. What I should do?
Arto
Arto
- ArcEye
- Thank you received: 758
22 Aug 2014 15:01 #50175
by ArcEye
Replied by ArcEye on topic Fresh install Precise
Hi
It is in the same directory, so no idea why you cannot find it
linuxcnc.org/dists/wheezy/base/binary-i3...65.gd99c55e_i386.deb
What is your apt line and where is the file?
The following user(s) said Thank You: Iselman
- Iselman
25 Aug 2014 04:28 #50241
by Iselman
Replied by Iselman on topic Fresh install Precise
Hi!
I made this apt line mistake again! 2.6 base was not correct.
succeeded to install 2.6.2 to Ubuntu Precise. Still some peculatiries when running linuxcnc.
Few error messages from system sometimes. When booting, system tells some bios
timing problem, not available in bios.
can't see coordinates display in Axis screen, only area is little darker.
when trying to change window size in axis the system crashis.
my machine is older Fujitsu Siemens Intel Celeron 32bit 2.8Ghz, 1G ram
I have been running linuxcnc 2.5.4 even in older computer 1.5Ghz processor. 500Meg ram Ubuntu 8.04 without any problems.
Difficult to buy new or used computer, before first installing OS and linuxcnc-2.6.x and testing it.
I am uncertain of version 2.6 functioning. Any ideas?
Arto
Arto
- ArcEye
25 Aug 2014 15:12 #50260
by ArcEye
Hi
It won't be anything to do with the Linuxcnc version, it will be the computer / graphics chip or card
The Axis plot display widget makes heavy use of openGL. Some computers have to use the software version because the hardware GLX acceleration is not supported.
Try this and see if it improves it
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
I have not tried it on Debian, you may have to google to get the package name right if it is not the same as the Ubuntu one
- Iselman
26 Aug 2014 19:05 #50307
by Iselman
Thanks! Linuxcnc 2.6.2 working now allright.
The other problems are due to old machine and AGP board and also Ubuntu 12.04 incombatypility for the HW system.
I was running Ub. 12.04 in general mode without realtime and got some errors. It is possible also that Precise is somehow ruined
during installation, because I also uninstalled and reinstalled packets.
Conclusion: I should reinstall Precise. This was only testing the linuxcnc2.6. Perhaps I'll test Debian Wheezy.
Windows 7 is running allright in same computer.
Perhaps this is all!. Thanks very much!
Arto
Arto
