2.6 live+install "stuck"
23 Aug 2014 07:41 #50199 by doronby
2.6 live+install "stuck" was created by doronby
I am trying to install the latest live CD with Wheezy and 2.6 but it gets stuck on :
"detect network hardware"
...Help....
P.S.
live CD works....
I have a b43 based wifi card.
23 Aug 2014 13:06 #50201 by ArcEye
Replied by ArcEye on topic 2.6 live+install "stuck"
You have already established that your wi-fi card uses non-standard firmware, which is probably not open source
www.linuxcnc.org/index.php/english/forum...eless-networks#49925
So you can't expect that firmware to be present on the install image.
You should be given the option to load drivers and firmware before the attempt to establish networking, or at least you do on a full Debian install.
If not, just plug in an ethernet cable to get the install done and then install the firmware the same way you did before.
23 Aug 2014 20:28 - 23 Aug 2014 20:30 #50205 by doronby
Replied by doronby on topic 2.6 live+install "stuck"
I managed somehow to get it installed. NOT VERY ELEGANT....
During the start up.... while asking me about keyboard etc... I was able to get to a menu that let me execute a shell
then i followed this:
$ nano /bin/check-missing-firmware
Inserted “exit 0” directly after “#!/bin/sh” line
Saved the file
$ exit
continue with the install
Once Linux was up... i copied the /lib/firmware/b43 I got from Asus to the filesystem Wii started to work. :)
The wifi card I have is wl-138g v2 asus
Last edit: 23 Aug 2014 20:30 by doronby.
23 Aug 2014 22:06 #50207 by ArcEye
Good hacking B)
I noticed when doing an install from the DVD of the iso, just how cut down the install was compared to a full debian install
On a full install there is an option to put firmware files on a USB stick (at least on the expert install there is) which enable devices to be found properly
I had similar problems with a built in wifi realtek PCIe card and managed to get it recognised that way, albeit I removed the card and went to ethernet cable full time, just wanted to see if it worked :laugh:
Time to create page: 0.119 seconds
