core dumped when run Axis 2.6
- htrantx
26 Aug 2014 09:05 - 26 Aug 2014 09:08 #50291
by htrantx
core dumped when run Axis 2.6 was created by htrantx
Please help,
I got core dumped every time i fired up Axis 2.6. This happened with both debian and ubuntu 12 installations. Error was at python: ../../../../../../../src/mesa/drivers/dri/nouveau/nv04_state_raster.c, get_blend_func . Did anyone get this problem?
Last edit: 26 Aug 2014 09:08 by htrantx.
- ArcEye
- Thank you received: 758
26 Aug 2014 15:18 #50296
by ArcEye
Replied by ArcEye on topic core dumped when run Axis 2.6
Hi
I would look at the graphics, that is what the error points towards.
nouveau is normally used as the default driver for nvidia cards, looks like you have a 1.6Mhz P4 with an AGP graphics card?
Axis uses openGL heavily and relies upon hardware acceleration. The widget that does the rendering is a python one called gremlin, that may be the python references.
Some cards are not compatable with this, the implementation of GLX by nvidia can cause a lot of problems with openGL.
It is possible that changing to software based openGL might improve things
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
Otherwise you probably need to try a new video card, I use Matrox 32MB AGP cards in my workshop P4s and they work well.
Second hand from ebay, they were about £7 each.
The following user(s) said Thank You: htrantx
- htrantx
26 Aug 2014 21:43 #50319
by htrantx
Good call! That was it.
Thanks,
htrantx
Replied by htrantx on topic core dumped when run Axis 2.6
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL ...
Thanks,
htrantx
Time to create page: 0.066 seconds
