Wierd (2 me) issues attempting install touchscreen
- dracozny
13 Sep 2014 09:42 #51137
by dracozny
Replied by dracozny on topic Wierd (2 me) issues attempting install touchscreen
chipset for mine is based on ilitek, its a glitchy monster, I have had to play with various sensitivity settings to get it to behave(mostly). Oddly it will effect the standard mouse simultaneously when they are both plugged in.
I found a work around for my right click issue and that was the use of gestures using easystroke. it's not the best option but it gets it done
pengpod.com/forum/viewtopic.php?f=4&t=4489
You may find you have to install more packages than what this guy lists in his last post in my case I also had to install
libxtst-dev
xserver-xorg-dev
The first part of this video she shows you how the gesture works for right clicking.
Hope this helps some of you.
libxtst-dev
xserver-xorg-dev
- alessandro torre
23 Feb 2016 18:03 #70532
by alessandro torre
Replied by alessandro torre on topic Wierd (2 me) issues attempting install touchscreen
Someone can help me?
I have an asus touch screen vt207 and the following version of debian and kernel
linuxcnc@debian:~$ uname -a
Linux debian 3.2.0-4-rt-686-pae #1 SMP PREEMPT RT Debian 3.2.73-2+deb7u2 i686 GNU/Linux
I tried to follow all the online guide to add the touch screen without success.
How can I add the ilitek driver in the right place?Is it possible?
linuxcnc@debian:~$ sudo tail -f /var/log/messages
Feb 23 18:23:06 debian kernel: [ 2311.434233] usb 2-2: Product: ILITEK Multi-Touch
Feb 23 18:23:06 debian kernel: [ 2311.434242] usb 2-2: Manufacturer: ILITEK
Feb 23 18:23:06 debian mtp-probe: checking bus 2, device 4: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-2"
Feb 23 18:23:06 debian mtp-probe: bus: 2, device: 4 was not an MTP device
lsusb:
linuxcnc@debian:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0846:9030 NetGear, Inc. WNA1100 Wireless-N 150 [Atheros AR9271]
Bus 003 Device 002: ID 062a:3286 Creative Labs Nano Receiver [Sandstrom Laser Mouse SMWLL11]
Bus 002 Device 004: ID 222a:0045
linuxcnc@debian:~$
linuxcnc@debian:~$ ls /lib/modules/3.2.0-4-rt-686-pae/kernel/drivers/hid/
hid-a4tech.ko hid-hyperv.ko hid-petalynx.ko hid-sjoy.ko
hid-apple.ko hid-kensington.ko hid-picolcd.ko hid-sony.ko
hid-axff.ko hid-keytouch.ko hid-pl.ko hid-speedlink.ko
hid-belkin.ko hid.ko hid-primax.ko hid-sunplus.ko
hid-cherry.ko hid-kye.ko hid-prodikeys.ko hid-tmff.ko
hid-chicony.ko hid-lcpower.ko hid-quanta.ko hid-topseed.ko
hid-cypress.ko hid-logitech-dj.ko hid-roccat-arvo.ko hid-twinhan.ko
hid-dr.ko hid-logitech.ko hid-roccat-common.ko hid-uclogic.ko
hid-elecom.ko hid-magicmouse.ko hid-roccat.ko hid-wacom.ko
hid-emsff.ko hid-microsoft.ko hid-roccat-kone.ko hid-waltop.ko
hid-ezkey.ko hid-monterey.ko hid-roccat-koneplus.ko hid-wiimote.ko
hid-gaff.ko hid-multitouch.ko hid-roccat-kovaplus.ko hid-zpff.ko
hid-gyration.ko hid-ntrig.ko hid-roccat-pyra.ko hid-zydacron.ko
hid-holtekff.ko hid-ortek.ko hid-samsung.ko usbhid
Thank you in advance
lsusb:
linuxcnc@debian:~$
- alessandro torre
29 Feb 2016 19:12 #70829
by alessandro torre
I partially solved following this guide ( no multitouch):
wiki.ubuntu.com/Touchscreen
Before I added
load_hid_multitouch.sh to /etc/udev
41-hid-multitouch.rules to /etc/udev/rules.d
after I did:
sudo modprobe -r usbtouchscreen
echo "blacklist usbtouchscreen" | sudo tee -a /etc/modprobe.d/blacklist.conf
sudo reboot
and now it works!
Before I added
after I did:
sudo reboot
and now it works!
- Einar
21 Mar 2016 08:58 #71967
by Einar
Mostly because I wanted to try Gmoccapy. But now they just work as screen protective devices.
Did you get yours running?
OK, so I called you and found out you did not. But I post this anyway to BTT as maybe someone else did?
Replied by Einar on topic Wierd (2 me) issues attempting install touchscreen
So are mine. I bought 2 of these, one for the lathe and one for the mill.Mine is an Acer B226HQL which lsusb shows as 0408:3021, nothing like yours dracozny.
Time to create page: 0.328 seconds
