Cubieboard
29 Aug 2014 00:27 #50422 by TiagoCovacic
Cubieboard was created by TiagoCovacic
I need to install LinuxCnc on a Cubieboard, can anyone help me set it up?
29 Aug 2014 15:57 #50447 by ArcEye
Replied by ArcEye on topic Cubieboard
Hi
I should go over to the MachineKit forum
groups.google.com/forum/#!forum/machinekit
They are mostly running on arm builds of a xenomai kernel with machinekit ( which is a linuxcnc fork )
I know some have experimented with the cubieboard.
They will have far more info on getting linuxcnc running on an arm based board
There are some disc images available which can be written to SD card and used, one of these may be suitable as is
The following user(s) said Thank You: TiagoCovacic
06 Sep 2014 07:59 #50825 by Bari
Replied by Bari on topic Cubieboard
Linuxcnc on the Cubie2 is still a work in progress. Linuxcnc does run on Debian using a preempt_rt kernel but there is no working real time IO yet or connectivity to HostMot2. wiki.debian.org/InstallingDebianOn/Allwinner
We are currently working on a Gentoo install of Linuxcnc with preempt_rt that will use hm2_eth and /or hm2_spi to wok with a 7i90. SATA is working but the Cubie2 board has a hardware bug with the 5V power when serial and USB is attached.
We'll post the fix and more news as it develops.
07 Sep 2014 05:36 #50869 by TiagoCovacic
Replied by TiagoCovacic on topic Cubieboard
and about the cubietruck, do you know something ?
12 Sep 2014 19:46 #51112 by TiagoCovacic
The advice you were a great help, thank you :laugh:
Time to create page: 0.056 seconds
