2.6 from LiveDVD - > New latency problems.
- doronby
Latency test report a jitter of ~5000ns.
We installed along side of it the new hybrid 2.6 version (Debian based) .
Latency test report a jitter of ~400,000ns.
The Stepconfig Axis test seems to run the machine smoothly but when running LinuxCNC we get bad grinding noise and the motors do not run smooth. (I assume it is the latency issue)
How do I start figuring this out ?
Thanks.
-Doron
- Thank you received: 4967
There may be technical interest in figuring out the problem, but if you want a working system then there is no problem with running 2.6 on 10.04 + RTAI.
- cncbasher
- Thank you received: 288
install the hybrid to a fresh drive , and see
i'm using the hybrid on 3 machines without probs as far as latency
but mixing repro's is perhaps not a good idea
- ArcEye
- Thank you received: 758
I presume you mean on another partition?
If you have a working config, why have you created a new one? Use the old one.
....................but when running LinuxCNC we get bad grinding noise and the motors do not run smooth. (I assume it is the latency issue)
What gives really rough grinding noise and slow movement, is often the stepper timings far too short.
Have you entered us values in the fields that are ns in stepconf?
Back to the original config, try using that.
- doronby
We have tried to do a fresh install on a new drive...got same results.
We reverted to 2.5 on Ubuntu for now but it might be worth while to sort it out.
(FYI : on another Dell machine we have with a smaller CNC, we had no problems with 2.6)
- doronby
it's probably due to the mix and something has screwed up.
We have tried it to a fresh drive and to a separate partition with identical BAD results.
- doronby
I would go back to the 2.5 LiveCD then upgrade LinuxCNC _only_ to 2.6
That machine has no internet access. Can you point us to How do we upgrade to 2.6 from DVD or USB?
- ArcEye
If you have done an install to another computer and it works fine, I should just forget about it, there is obviously something basically incompatible with that machine.
You just download the packages, put them on a USB stick, remove the old packages and install the new ones, using dpkg.
Machine with internet fetch these
linuxcnc.org/dists/lucid/2.6/binary-i386...uxcnc_2.6.2_i386.deb
linuxcnc.org/dists/lucid/2.6/binary-i386...c-dev_2.6.2_i386.deb
copy to USB
Host machine
sudo dpkg -r linuxcnc-dev
sudo dpkg -i -linuxcnc_2.6.2_i386.deb
sudo dpkg -i -linuxcnc-dev_2.6.2_i386.deb
Lemon squeezy
- doronby
Hi
That machine has been running 2.5 just fine.... We have no other machine to keep at that location....
I will try to manually upgrade just the 2.6 files with the older Ubuntu.
Do we need to copy the 2 files from the USB stick to any specific location for the rest of your instructions to work ?
Thanks.
-D
- ArcEye
No, you just have to be in that location when you issue the dpkg -i command or it will not find them
