serial
- TiagoCovacic
12 Sep 2014 20:33 #51116
by TiagoCovacic
serial was created by TiagoCovacic
First, sorry for my bad english, i'm from Brazil, i need install LinuxCNC on a Cubieboard, but this developer board have no paralel out, exists some form to make this out to serial form?
- ArcEye
- Thank you received: 758
12 Sep 2014 20:48 #51117
by ArcEye
Replied by ArcEye on topic serial
HI
I see you have posted on the MachineKit site, you probably need to wait for your answers there.
There is no serial port output option with linuxcnc, it works on parport, ppmc card or fpga cards.
There is also no ARM option, it runs on x86 computers (with some caveats that would just complicate to go into)
MachineKit runs on ARM, on boards which also do not natively have parallel ports.
There is a cape available for that, albeit I don't know if they use it or output direct from pins
They will advise you
The following user(s) said Thank You: TiagoCovacic
