Debian install - problems updating
- blacksmith99
- Thank you received: 4
16 Oct 2014 09:30 #52130
by blacksmith99
Debian install - problems updating was created by blacksmith99
I installed the Debian Wheezy (debian.hybrid.iso' earlier this evening. Linuxcnc works fine. The version is 2.6.1
When I try 'sudo apt-get update'
I get the errors listed below.
I have looked at the sources.list file and the sources.list.d directory and found the linuxcnc entries. Everything seems fine, but I am not a Linux person.
I can't seem to resolve this.
Here is the screen text after the apt-get update..............
~$ sudo apt-get update
Err linuxcnc.org lucid Release.gpg
Could not resolve 'linuxcnc.org'
Err linuxcnc.org wheezy Release.gpg
Hit security.debian.org wheezy/updates Release.gpg
Hit security.debian.org wheezy/updates/main Sources
Hit security.debian.org wheezy/updates/contrib Sources
Err buildbot.linuxcnc.org wheezy Release.gpg
Could not resolve 'buildbot.linuxcnc.org'
Hit security.debian.org wheezy/updates/non-free Sources
Hit security.debian.org wheezy/updates/main i386 Packages
Hit security.debian.org wheezy/updates/contrib i386 Packages
Hit security.debian.org wheezy/updates/non-free i386 Packages
Hit security.debian.org wheezy/updates/contrib Translation-en
Err http.debian.net wheezy Release.gpg
Could not resolve 'cloudfront.debian.net'
Err http.debian.net wheezy-updates Release.gpg
Hit security.debian.org wheezy/updates/main Translation-en
Hit security.debian.org wheezy/updates/non-free Translation-en
Reading package lists... Done
W: Failed to fetch http.debian.net/debian/dists/wheezy/Release.gpg Could not resolve 'cloudfront.debian.net'
W: Failed to fetch http.debian.net/debian/dists/wheezy-updates/Release.gpg Could not resolve 'cloudfront.debian.net'
W: Failed to fetch linuxcnc.org/dists/lucid/Release.gpg Could not resolve 'linuxcnc.org'
W: Failed to fetch linuxcnc.org/dists/wheezy/Release.gpg Could not resolve 'linuxcnc.org'
W: Failed to fetch buildbot.linuxcnc.org/dists/wheezy/Release.gpg Could not resolve 'buildbot.linuxcnc.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Anyone have an idea what the 'cloudfront.debian.net'
and the errors following the "W: " errors are all about?
Thanks,
Matt
Thanks,
Matt
- Thank you received: 5202
16 Oct 2014 09:58 #52131
Replied by PCW on topic Debian install - problems updating
Sounds like a bad network connection or DNS problem
You might try pinging linuxcnc.org or cloudfront.debian.net
to see if its just a temporary thing or some network issue you need to resolve
- blacksmith99
16 Oct 2014 10:17 - 16 Oct 2014 10:17 #52132
by blacksmith99
Replied by blacksmith99 on topic Debian install - problems updating
Hmm, I don't have any issues getting out on the web.
The computer updated through the software update tool.
Am I missing something?
Thank you for the reply.
I will try the pings.
Regards,
Matt
Regards,
Matt
Last edit: 16 Oct 2014 10:17 by blacksmith99.
- ArcEye
- Thank you received: 758
16 Oct 2014 13:08 #52133
by ArcEye
Replied by ArcEye on topic Debian install - problems updating
It has just taken me 5 minutes and 3 server errors to reply to this post, so that probably says it all.
I routinely change my debian settings in apt to the German servers, because the UK ones are often slow or don't work at all, so debian is not immune either.
Give it a while and try again, if you have the default install apt settings, it will work (connected to the main debian US servers)
The following user(s) said Thank You: blacksmith99
- blacksmith99
16 Oct 2014 18:49 #52136
by blacksmith99
Thanks for the quick response!
I forget that the connection issue doesn't always happen my end.
Cheers!
Matt
Cheers!
Matt
Time to create page: 0.065 seconds
