Debian Wheezy Incorrect Password
20 Oct 2014 11:42 #52202 by Tonyo
Debian Wheezy Incorrect Password was created by Tonyo
B)"Incorrect password" message when trying log in (Debian Wheezy). Installed Debian on two different computers with same results!
20 Oct 2014 16:11 - 20 Oct 2014 16:12 #52203 by ArcEye
Replied by ArcEye on topic Debian Wheezy Incorrect Password
Hi
I take it you have tried the obvious thing, try it with the Caps Lock on, in case that is how it was when you set it.
The other possibility is using a foreign keyboard with the keyboard type set incorrectly, but since you are in the US and it defaults to US, probably not.
Otherwise you need to reset it
Boot into the recovery option,
or if that is not present, press 'e' at the GRUB menu and edit the kernel boot line from something like
ro quiet splash
to
ro single
then press F10
You will get a root shell
Enter
passwd tonyo (or whatever your user name is)
Then enter the new password twice when prompted
Then enter passwd -u tonyo
Now reboot and you should be able to log in normally
Last edit: 20 Oct 2014 16:12 by ArcEye.
The following user(s) said Thank You: Tonyo
21 Oct 2014 00:02 #52219 by Tonyo
Replied by Tonyo on topic Debian Wheezy Incorrect Password
:) Works !!!! Thank you.
29 Nov 2015 21:35 #66058 by jberkner
Replied by jberkner on topic Debian Wheezy Incorrect Password
When the computer comes to the login screen the top area says jberknercnc and when I enter the password I get the incorrect password screen
I did the procedure and when I tried to do the passwd jberknercnc It told me there was no user by that name.. I did a passwd -Sa and found only a line for jim.
I changed the passwd for jim then entered passwd -u jim
After a reboot, the passwd still came up incorrect. any ideas?
Thanks Jim
30 Nov 2015 01:00 #66072 by andypugh
Replied by andypugh on topic Debian Wheezy Incorrect Password
It is very easy to type a password when the prompt is actually asking for a username.
"login" means "type your username". Even if there is only one user.
I make this mistake regularly, as my other machines just need a password.
The following user(s) said Thank You: cwalker1960, jberkner
