Master on Ubuntu 12.04/10.04 nokey from keyserver
23 Oct 2014 00:44 - 24 Oct 2014 01:17 #52294 by Blackwind
hi to all:
i was trying to install LCNC on Precise following this guide wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.6
but on the step to add the LinuxCNC Archive Signing Key ($ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 8f374fef) the server timed out(or failed to respond).
if i run sudo apt-get update keep complaining about buildbot is a missing public (gpg?) key, and shows one but its not 8f374fef.
i was thinking about a problem with 12.04 but is doing the same with master in 10.04.
any advise ?
thanks for your time reading and answering
rick
PS: seems that 2.8 is out, the key was changed?
Last edit: 24 Oct 2014 01:17 by Blackwind.
23 Oct 2014 03:03 #52303 by BigJohnT
Replied by BigJohnT on topic Master on Ubuntu 12.04
Unless you have some reason to use Ubuntu I'd use the Debian Wheezy hybrid iso.
www.linuxcnc.org/index.php/english/download
2.6 is the latest release. There is a 2.7 beta branch and master.
JT
The following user(s) said Thank You: Blackwind
24 Oct 2014 01:15 #52339 by Blackwind
Replied by Blackwind on topic Master on Ubuntu 12.04
Thanks for the answer BJT.
Nothing special keeps me with Ubuntu, only folders and file sharing and remote desktop with a very few clicks and go. I tried debian wheezy installation and is ok, but these items seems missing its gui, i know it could be done in command line, but these two things are done in ubuntu in a breeze.
Today i encountered the same error trying to update a 10.04lts fresh instalation from its original 2.5 to latest master (2.8pre...).
this is i was doing and the results:
to add buildbot master:
sudo gedit /etc/apt/sources.list.d/linuxcnc-buildbot.list
added:
deb     http://buildbot.linuxcnc.org/ lucid master-rt
deb-src http://buildbot.linuxcnc.org/ lucid master-rt
then run:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
[sudo] password for fw:
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /etc/apt/secring.gpg --trustdb-name /etc/apt/trustdb.gpg --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
gpg: requesting key E0EE663E from hkp server keys.gnupg.net
gpg: keyserver timed out
gpg: keyserver receive failed: keyserver error[/quote]
and in between:
sudo apt-get update
W: GPG error: http://buildbot.linuxcnc.org lucid Release:
 The following signatures couldn't be verified because the public key is not available: NO_PUBKEY EF1B07FEE0EE663E
the same error that give me in precise and spoil my installation, from this i was thinking on the key missing in the latest master release.
any thougth?
Regards
Rick
PS: many thanks to BJT and much others work, yours forum post are an invaluable source of knowledge to me.
Time to create page: 0.055 seconds
