USB ports won't work after install
08 Nov 2014 03:16 #52918 by invntr
USB ports won't work after install was created by invntr
I installed LinuxCNC with no problem. For some reason when booting off of the flash drive, all my USB ports worked on 3 different motherboards (Asus, AsRock, and Gigabyte). After the install, none of the USB ports work and I get the error below on boot up. I thought it was USB 3.0 related, so I disabled USB 3.0 in the bios, but I still get the error and the USB ports don't work. Any ideas anyone? Thanks in advance for the help!
usb 1-1: device not accepting address 3, error -110
usb 1-1: device not accepting address 4, error -110
usb 1-1: device not accepting address 1, error -110
usb 1-1: device not accepting address 2, error -110
08 Nov 2014 10:34 #52927 by cmorley
Replied by cmorley on topic USB ports won't work after install
Is this with the RTAI realtime kernel?
There was an issue with that, which was fixed recently.
So you may need to update the RTAI kernel.
Chris M
08 Nov 2014 12:01 #52934 by invntr
Replied by invntr on topic USB ports won't work after install
Thanks Chris. Is that something that would update with running the typical updates? I ran the regular updates a few weeks ago, but the error kept occurring.
08 Nov 2014 15:30 - 08 Nov 2014 19:32 #52935 by ArcEye
Replied by ArcEye on topic USB ports won't work after install
Afraid that does not tell us anything.
Can you be precise as to which version, of which distro, you installed and onto what machine (motherboard model).
There is already a warning on the latency test list that some motherboards have been found to have non-functioning USB with rtai kernel.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
I was not aware that this issue was resolved, that may have been another USB issue.
If apt-get update && apt-get dist-upgrade followed by reboot does not solve it, need all the info as per first para.
Last edit: 08 Nov 2014 19:32 by ArcEye.
08 Nov 2014 22:46 #52948 by PCW
Replied by PCW on topic USB ports won't work after install
This issue (non working USB on Baytrail = J1800,J1900,J2900 based) motherboards
has been fixed on the wheezy RTAI kernel as of a few days ago.
Thanks to Brian Morel for chasing down the patch that fixed
the USB issue, Sebastian Kuzminsky for building the distribution kernel
and Chris Radek for packaging it with the latest (2.6.4) ISO image
This is important as these are very nice fanless systems, much faster than the Atom D525s
at the same or lower power
08 Nov 2014 22:51 - 08 Nov 2014 23:28 #52949 by ArcEye
Excellent, I obviously missed that announcement on the lists.
I will amend the latency page in a while
EDIT: Now done, original entry left in with update re 3.4.55-4-rtai kernel
Last edit: 08 Nov 2014 23:28 by ArcEye.
08 Nov 2014 23:11 #52953 by invntr
Thank you everyone, I will try downloading the 2.6 version to see if that fixes the issue.
08 Nov 2014 23:15 #52954 by PCW
BTW
The patched kernel is 3.4.55-4
The non-working(on Baytrail) kernel is 3.4.55-3
09 Nov 2014 00:24 #52959 by invntr
SUCCESS! The updae fixed it! Everything is working great! Thank you ery much everyone
Time to create page: 0.160 seconds
