ubuntu-10.04-linuxcnc3-i386.iso
10 Nov 2014 06:01 #52980 by Jeff-504
ubuntu-10.04-linuxcnc3-i386.iso was created by Jeff-504
can i install ubuntu-10.04-linuxcnc3-i386.iso
on amd 64 bit cpu?
I'm will have to remove my current hard drive and install empty drive for this.
Its been a wile since i needed to install new hard drive.
refreshing my memory i just need to go into the sys bios and hopfully it will auto detect correct?
i searched for ubuntu-10.04-linuxcnc3- latest version for 64 bit but not found
10 Nov 2014 15:38 - 10 Nov 2014 15:41 #52984 by ArcEye
Replied by ArcEye on topic ubuntu-10.04-linuxcnc3-i386.iso
Hi
Most processors in desktops these days are 64bit, you can run 32 or 64 bit OS's on them.
The limitation is RAM. The Ubuntu kernel will only allow access to a max of 3.25GB but the PAE kernel on the debian.hybrid.iso should allow access to all your RAM, with a suitable processor.
Ubuntu 10.04 is dead, with no further updates and no support for later chipsets etc so the debian based iso is the one to install.
Yes your BIOS should just detect the HDD, if you have an old computer with an IDE bus, just make sure the HDD is correctly jumpered (master or slave) depending upon whether it is the first or second device on the bus.
Normally drive on the plug nearest the motherboard connector is 0 (master) and furthest from it is 1 (slave)
There is no 64 bit iso at this time
Last edit: 10 Nov 2014 15:41 by ArcEye.
Time to create page: 0.065 seconds
