can´t run real configuration on debian wheezy
- jtc
- Thank you received: 13
24 Nov 2014 22:42 #53354
by jtc
can´t run real configuration on debian wheezy was created by jtc
Hi.
Today I try to migrate from ubuntu 12 to the LCNC version that uses debian wheezy, I install linuxcnc from GIT and everything looks fine.
I can run simulation configurations, but when I try to run the machione configuration, I got this error>
I confirm and looks like I´m running a real time kernel,
the uname -r command returns me this
any suggestion?
Thanks,
João
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/user/linuxcnc-dev/configs/faststeel'
Machine configuration file is 'faststeel.ini'
Starting LinuxCNC...
RTAPI: ERROR: shmem size mismatch
HAL: ERROR: could not open shared memory
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Running HAL shutdown script
3.4-9-rtai-686-pae
any suggestion?
Thanks,
João
- ArcEye
- Thank you received: 758
25 Nov 2014 00:16 #53358
by ArcEye
You will have to be specific as to what you have done.
The debian based distro has Linuxcnc 2.6 included.
Is this what you have installed?
If so does the included version of Linuxcnc work?
The error is because the size of shared memory returned is less than requested, but the reason for that is not straight forward.
For a start, what are the contents of /etc/security/limits.conf?
Replied by ArcEye on topic can´t run real configuration on debian wheezy
- jtc
25 Nov 2014 19:18 #53391
by jtc
Hi.
I install in a new SSD this version of debian with a usb pen. after that install and pull the master version of linuxcnc. install all the dependencies and compile it.
yes it has the 2.6.4 version installed and it runs the machine configuration.
here is the file:
Replied by jtc on topic can´t run real configuration on debian wheezy
Hi.
here is the file:
# /etc/security/limits.conf
#Each line describes a limit for a user in the form:
#<domain> <type> <item> <value>
#Where:
#<domain> can be:
# - an user name
# - a group name, with @group syntax
# - the wildcard *, for default entry
# - the wildcard %, can be also used with %group syntax,
# for maxlogin limit
# - NOTE: group and wildcard limits are not applied to root.
# To apply a limit to the root user, <domain> must be
# the literal username root.
#<type> can have the two values:
# - "soft" for enforcing the soft limits
# - "hard" for enforcing hard limits
#<item> can be one of the following:
# - core - limits the core file size (KB)
# - data - max data size (KB)
# - fsize - maximum filesize (KB)
# - memlock - max locked-in-memory address space (KB)
# - nofile - max number of open files
# - rss - max resident set size (KB)
# - stack - max stack size (KB)
# - cpu - max CPU time (MIN)
# - nproc - max number of processes
# - as - address space limit (KB)
# - maxlogins - max number of logins for this user
# - maxsyslogins - max number of logins on the system
# - priority - the priority to run user process with
# - locks - max number of file locks the user can hold
# - sigpending - max number of pending signals
# - msgqueue - max memory used by POSIX message queues (bytes)
# - nice - max nice priority allowed to raise to values: [-20, 19]
# - rtprio - max realtime priority
# - chroot - change root to directory (Debian-specific)
#* soft core 0
#root hard core 100000
#* hard rss 10000
#@student hard nproc 20
#@faculty soft nproc 20
#@faculty hard nproc 50
#ftp hard nproc 0
#ftp - chroot /ftp
#@student - maxlogins 4
# End of file
* - memlock 20480 #EMC2
- ArcEye
25 Nov 2014 20:19 #53392
by ArcEye
Hi
That is what i was looking for in the limits.conf file, should be OK
Can you zip your config folder and attach it, will need to try some tests.
- jtc
25 Nov 2014 21:34 #53395
by jtc
I send you in a PM.
João
Hi
I send you in a PM.
João
- ArcEye
25 Nov 2014 23:28 #53401
by ArcEye
Nothing received, it very often does not work.
I should just attach the config folder, someone else may have a far better idea than me anyway
I send you in a PM.
Time to create page: 0.215 seconds
