Debian Wheezy 2.6n install on GX620
- ArcEye
- Thank you received: 758
11 Dec 2014 01:38 #53891
by ArcEye
Replied by ArcEye on topic Debian Wheezy 2.6n install on GX620
As per an earlier post you need the firmware for this.
It should be in the package firmware-linux-nonfree
You will be delighted to know this is another NIC which seems to cause huge problems on Linux.
Hopefully installing the firmware, will generate a rebuild of initrd.img and a reboot may find it
- tjamscad
11 Dec 2014 02:53 - 11 Dec 2014 03:33 #53895
by tjamscad
Replied by tjamscad on topic Debian Wheezy 2.6n install on GX620
Here is the dmesg.txt How do I get the firmware-linux-nonfree?
I get this message when trying it reapply the firmware with Synaptic Pacakge Manager
w: Failed to fetch http:.......
Could not resolve 'http.debian.net'
Last edit: 11 Dec 2014 03:33 by tjamscad.
- ArcEye
11 Dec 2014 15:21 #53906
by ArcEye
Download it on another machine, search 'debian wheezy firmware-linux-nonfree' and download via a browser.
Then transfer via USB stick and install with
sudo dpkg -i {fullname of package}
The dmesg has no trace of anything to do with ethernet or network, it is completely failing to recognise the chip.
- tjamscad
12 Dec 2014 05:41 #53939
by tjamscad
I downloaded and installed per your instructions. It did not give me any options or ask me to install drivers. Here are new versions of the files you had previously requested.
- ArcEye
13 Dec 2014 00:53 #53971
by ArcEye
Hi
The ethernet chip is not being detected.
Scouring the net, looks as though there is an option in BIOS to enable ethernet chip, this needs to be set.
Then source and install the package firmware-bnx2 by the same method as with the other one.
What should happen after installing is that the initrd.img is remade, so that next time you boot, hopefully it may find the chip
- tjamscad
16 Dec 2014 00:40 #54027
by tjamscad
That was it. Turning on in the Bios, Sorry for all the effort you went through, thanks for the help ArcEye
