What processor to install LinuxCNC 2.6?
- gimpo
08 Jan 2015 03:58 - 08 Jan 2015 04:01 #54727
by gimpo
I made another fresh burning of the downloaded binary.hybrid.iso image (Debian + LinuxCNC):
checksum = verified
write process = successful
written DVD data verification = ok
So, again:
ASROCK mini-computer = installation hangs (on graphical and text installation both)
Old AMD Sempron desktop PC = installation hangs (on graphical and text installation both)
New notebook of my wife = live installation works like a charm (I didn't make the installation otherwise my wife kill me)
Again, I think the problem is the iso file, not the PC.
Solution:
I've downloaded and burned the Ubuntu 10.04 + LinuxCNC 2.5 image and................. it works like a charm!
Ubuntu 10 it's incredibly fast, smooth and easy.
Now I have to setup wifi connection, update the OS and LinuxCNC to version 2.6. This is a long process that I will do tomorrow (the old PC is now in the room where my baby sleeps so I have to stop now
By the way, the 8-9 years old PC gives the following latency-test results:
max Jitter (servo thread) = 14789
max Jitter (basethread) = 18288
Seems good values, isn't it?
(I've just stressed the machine by opening the office spreadsheet, build a chart and made some calculation - the PC will be used just for driving the CNC machine)
Replied by gimpo on topic What processor to install LinuxCNC 2.6?
Be sure to check the ISO before you burn it to the disk. (that way you don't make another bad one)
checksum = verified
So, again:
Solution:
Last edit: 08 Jan 2015 04:01 by gimpo.
- BigJohnT
- Thank you received: 1175
08 Jan 2015 04:53 #54728
by BigJohnT
Replied by BigJohnT on topic What processor to install LinuxCNC 2.6?
If you upgrade the OS you will loose the real time kernel...
JT
JT
- gimpo
08 Jan 2015 05:33 - 08 Jan 2015 05:34 #54731
by gimpo
In other words, I mean the instructions reported here: Update to 2.6
I hope that they will work with no headache or troubles...
Yeah, I know that. In fact I have the word "update" (not "upgrade") used.If you upgrade the OS you will loose the real time kernel...
Last edit: 08 Jan 2015 05:34 by gimpo.
- Thank you received: 4957
08 Jan 2015 05:34 #54732
I just did a DVD install of Wheezy / 2.6 on my Lathe controller. (SMART was saying that HD failure was imminent). No problems at all, and that is a machine with dual Xeons (Prestonia) built in 2003.
So it isn't quite as simple as that.
Replied by andypugh on topic What processor to install LinuxCNC 2.6?
So the answer is just one: use the Debian-Wheezy installation DVD only if you have a "modern" computer!
- gimpo
10 Jan 2015 05:18 - 10 Jan 2015 06:13 #54842
by gimpo
I've just updated my Ubuntu 10.04 using the built-in "Update Manager" program. One click of the mouse and zero problem.
After I've upgraded LinuxCNC 2.5 to 2.6 following the instructions. Again zero problem.
I'm happy!
By the way: in the "Synaptic Package Manager" it would be better to mark the check boxes "linux-cnc" and "linux-cnc-doc-en" both. So you get version 2.6 of the english documentation too.
Happy to hear that. Maybe my computer was too old... or maybe I'm not lucky at all, I don't know.
I'm happy!
Last edit: 10 Jan 2015 06:13 by gimpo.
