Debian Wheezy install on D525MW
25 Jan 2015 22:53 #55320 by rds626
Debian Wheezy install on D525MW was created by rds626
No problems with installation but cannot set video mode to native resolution of my monitor (1680X1050).
It's unclear why there are 2 devices listed – LAPTOP & MONITOR but the maximum settings are only 1280X800 or 1024X768 respectively. Both are devices are set ON to use?
I know the GMA3150 video chip on the D525MW can display 1680X1050 resolution because it does so under win XP.
Is there a synaptic package/driver that needs to loaded or what?
Thanks.
26 Jan 2015 00:36 #55328 by ArcEye
Replied by ArcEye on topic Debian Wheezy install on D525MW
Hi
What video modes does the output of xrandr list?
(xrandr > xrandr.txt and attach the xrandr.txt produced)
You may need to install it, can't remember if in base install.
26 Jan 2015 01:26 #55333 by rds626
Replied by rds626 on topic Debian Wheezy install on D525MW
Xrandr reports:
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 4096 x 4096
LVDS1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1280x800 58.1 +
1024x768 60.0*
800x600 60.3 56.2
640x480 59.9
VGA1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.0*
800x600 60.3 56.2
848x480 60.0
640x480 59.9
I'm using the VGA output.
The following video related packages are installed:
libxrandr-dev
libxrandr2
x11=xserver-utils
i965-va-driver
libva-x11-1
libva1
xserver-xorg-video-740
xserver-xorg-video-intel
It looks like the driver can do more resolution (4096 x 4096) but the listed modes top out at 1024 x 768?
26 Jan 2015 02:18 #55334 by BigJohnT
Replied by BigJohnT on topic Debian Wheezy install on D525MW
I recently had a Wheezy install that would not work on the Zotac motherboard. I spent days trying to figure it out. I finally gave up and started changing motherboards till I found one that was a happy fit with Wheezy. I have two computers with Wheezy and two motherboards that won't work well with Wheezy...
JT
26 Jan 2015 02:44 - 26 Jan 2015 15:12 #55338 by ArcEye
I have a D525 working with Wheezy as a media server connected to my TV.
It can do 1980x1080 (ie full HDMI-ish) using the on board chip, but I had to set the modes.
Google using cvt and xrandr.
cvt will get you a modeline string for your desired resolution and monitor frequency
www.x.org/archive/X11R7.5/doc/man/man1/cvt.1.html
eg cvt 1680 1050 60
You can then set that mode and select it using xrandr
This gives a tutorial
www.ubuntugeek.com/how-change-display-re...gs-using-xrandr.html
There are plenty more
Last edit: 26 Jan 2015 15:12 by ArcEye.
The following user(s) said Thank You: rds626
26 Jan 2015 19:22 #55350 by rds626
OK, that sure got me on the right path. I was able to use that information to set my mode. Most of the info about keeping the setting persistent does not seem applicable to the Xfce desktop.
Searching around turned up mostly confusion on how to do it with Xfce early in the boot process. I finally just added a script to session start-up as a workaround.
Many thanks …
