Startup Error
12 Feb 2015 02:01 #55903 by hurco
Startup Error was created by hurco
I'm getting a startup error when starting Linuxcnc. Happened after I ran stepconfig and created a classicladder for a lube timer.
Can someone help me decipher the error message in the attachment?
12 Feb 2015 06:18 #55905 by newbynobi
Replied by newbynobi on topic Startup Error
No attachment!!
Norbert
The following user(s) said Thank You: hurco
12 Feb 2015 07:59 - 12 Feb 2015 21:14 #55906 by hurco
Replied by hurco on topic Startup Error
Opps.
Hopefully this works this time.
Hurco
Trying this in-line.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.4
Machine configuration directory is '/home/john/linuxcnc/configs/Hurco'
Machine configuration file is 'Hurco.ini'
INIFILE=/home/john/linuxcnc/configs/Hurco/Hurco.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
INFO CLASSICLADDER-   No ladder GUI requested-Realtime runs till HAL closes.
Killing task linuxcncsvr, PID=4890
Debug file information:
custom.hal:1: Unknown command ''
4890
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[    0.000000]  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000001fe74000 (usable)
[    0.000000]  BIOS-e820: 000000001fe74000 - 000000001fe76000 (ACPI NVS)
[    0.000000]  BIOS-e820: 000000001fe76000 - 000000001fe97000 (ACPI data)
[    0.000000]  BIOS-e820: 000000001fe97000 - 000000001ff00000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[    0.000000]  BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[    0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI: Dell Computer Corporation Dimension 2400               /0G1548, BIOS A02 07/31/2003
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0x1fe74 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-C3FFF write-protect
[    0.000000]   C4000-C7FFF uncachable
[    0.000000]   C8000-CBFFF write-protect
[    0.000000]   CC000-CFFFF uncachable
[    0.000000]   D0000-D3FFF write-protect
[    0.000000]   D4000-D7FFF uncachable
[    0.000000]   D8000-DBFFF write-protect
[    0.000000]   DC000-DFFFF uncachable
[    0.000000]   E0000-E3FFF write-protect
[    0.000000]   E4000-E7FFF uncachable
[    0.000000]   E8000-EBFFF write-protect
[    0.000000]   EC000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FE0000000 write-back
[    0.000000]   1 base 01FF00000 mask FFFF00000 uncachable
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] found SMP MP-table at [c00fe710] fe710
[    0.000000] initial memory mapped : 0 - 01800000
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] init_memory_mapping: 0000000000000000-000000001fe74000
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 001fc00000 page 2M
[    0.000000]  001fc00000 - 001fe74000 page 4k
[    0.000000] kernel direct mapping tables up to 0x1fe73fff @ [mem 0x017f8000-0x017fffff]
[    0.000000] RAMDISK: 1e561000 - 1f3de000
[    0.000000] ACPI: RSDP 000feb80 00014 (v00 DELL  )
[    0.000000] ACPI: RSDT 000fd2ea 00034 (v01 DELL    2400    00000007 ASL  00000061)
[    0.000000] ACPI: FACP 000fd31e 00074 (v01 DELL    2400    00000007 ASL  00000061)
[    0.000000] ACPI: DSDT fffcbe22 02404 (v01   DELL    dt_ex 00001000 MSFT 0100000D)
[    0.000000] ACPI: FACS 1fe74000 00040
[    0.000000] ACPI: SSDT fffce226 000A7 (v01   DELL    st_ex 00001000 MSFT 0100000D)
[    0.000000] ACPI: APIC 000fd392 0006C (v01 DELL    2400    00000007 ASL  00000061)
[    0.000000] ACPI: BOOT 000fd3fe 00028 (v01 DELL    2400    00000007 ASL  00000061)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 510MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 1fe74000
[    0.000000]   low ram: 0 - 1fe74000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x0001fe74
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000010 -> 0x000000a0
[    0.000000]     0: 0x00000100 -> 0x0001fe74
[    0.000000] On node 0 totalpages: 130564
[    0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map dfa73200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3952 pages, LIFO batch:0
[    0.000000]   Normal zone: 989 pages used for memmap
[    0.000000]   Normal zone: 125591 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] disabled)
[    0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[    0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at 1ff00000 (gap: 1ff00000:ded00000)
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 17 pages/cpu @dfa2b000 s48384 r0 d21248 u69632
[    0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129543
[    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.4-9-rtai-686-pae root=/dev/mapper/KMB1-root ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] allocated 1045280 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (00000000:00000000)
[    0.000000] Memory: 495740k/522704k available (3495k kernel code, 26516k reserved, 1237k data, 416k init, 0k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff17000 - 0xfffff000   ( 928 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xe0674000 - 0xff7fe000   ( 497 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdfe74000   ( 510 MB)
[    0.000000]       .init : 0xc14a0000 - 0xc1508000   ( 416 kB)
[    0.000000]       .data : 0xc1369d4a - 0xc149f480   (1237 kB)
[    0.000000]       .text : 0xc1000000 - 0xc1369d4a   (3495 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:2304 nr_irqs:712 16
[    0.000000] CPU 0 irqstacks, hard=df408000 soft=df40a000
[    0.000000] Interrupt pipeline (release #3)
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 2192.957 MHz processor.
[    0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 4385.91 BogoMIPS (lpj=8771828)
[    0.004016] pid_max: default: 32768 minimum: 301
[    0.004137] Security Framework initialized
[    0.004151] AppArmor: AppArmor disabled by boot time parameter
[    0.004205] Mount-cache hash table entries: 512
[    0.004680] Initializing cgroup subsys cpuacct
[    0.004691] Initializing cgroup subsys memory
[    0.004712] Initializing cgroup subsys devices
[    0.004717] Initializing cgroup subsys freezer
[    0.004722] Initializing cgroup subsys net_cls
[    0.004726] Initializing cgroup subsys blkio
[    0.004743] Initializing cgroup subsys perf_event
[    0.008018] CPU0: Hyper-Threading is disabled
[    0.008028] mce: CPU supports 4 MCE banks
[    0.008044] CPU0: Thermal monitoring enabled (TM1)
[    0.008152] SMP alternatives: switching to UP code
[    0.014450] ACPI: Core revision 20120320
[    0.040316] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.040705] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.080602] CPU0: Intel(R) Celeron(R) CPU 2.20GHz stepping 09
[    0.084004] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[    0.084004] ... version:                0
[    0.084004] ... bit width:              40
[    0.084004] ... generic registers:      18
[    0.084004] ... value mask:             000000ffffffffff
[    0.084004] ... max period:             0000007fffffffff
[    0.084004] ... fixed-purpose events:   0
[    0.084004] ... event mask:             000000000003ffff
[    0.092068] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.092203] Brought up 1 CPUs
[    0.092211] Total of 1 processors activated (4385.91 BogoMIPS).
[    0.092997] devtmpfs: initialized
[    0.093607] PM: Registering ACPI NVS region [mem 0x1fe74000-0x1fe75fff] (8192 bytes)
[    0.093909] dummy:
[    0.094080] NET: Registered protocol family 16
[    0.094419] ACPI: bus type pci registered
[    0.095739] PCI: PCI BIOS revision 2.10 entry at 0xfbc7f, last bus=1
[    0.095746] PCI: Using configuration type 1 for base access
[    0.097362] bio: create slab <bio-0> at 0
[    0.097689] ACPI: Added _OSI(Module Device)
[    0.097698] ACPI: Added _OSI(Processor Device)
[    0.097703] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.097708] ACPI: Added _OSI(Processor Aggregator Device)
[    0.098915] ACPI: EC: Look up EC in DSDT
[    0.119410] ACPI: Interpreter enabled
[    0.119439] ACPI: (supports S0 S1 S3 S4 S5)
[    0.119520] ACPI: Using IOAPIC for interrupt routing
[    0.162273] ACPI: No dock devices found.
[    0.162294] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.164137] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.167544] pci_root PNP0A03:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.167552] pci_root PNP0A03:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.167558] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.167563] pci_root PNP0A03:00: host bridge window [mem 0x80860000-0xfebfffff] (ignored)
[    0.167569] PCI: root bus 00: using default resources
[    0.167684] PCI host bridge to bus 0000:00
[    0.167693] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.167698] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[    0.167725] pci 0000:00:00.0: [8086:2560] type 00 class 0x060000
[    0.167743] pci 0000:00:00.0: reg 10: [mem 0xe8000000-0xefffffff pref]
[    0.167845] pci 0000:00:02.0: [8086:2562] type 00 class 0x038000
[    0.167871] pci 0000:00:02.0: reg 10: [mem 0xe0000000-0xe7ffffff pref]
[    0.167889] pci 0000:00:02.0: reg 14: [mem 0xfeb80000-0xfebfffff]
[    0.168077] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300
[    0.168147] pci 0000:00:1d.0: reg 20: [io  0xff80-0xff9f]
[    0.168209] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300
[    0.168276] pci 0000:00:1d.1: reg 20: [io  0xff60-0xff7f]
[    0.168331] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300
[    0.168397] pci 0000:00:1d.2: reg 20: [io  0xff40-0xff5f]
[    0.168471] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320
[    0.168504] pci 0000:00:1d.7: reg 10: [mem 0xffa80800-0xffa80bff]
[    0.168617] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.168651] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[    0.168723] pci 0000:00:1f.0: [8086:24c0] type 00 class 0x060100
[    0.168731] * The chipset may have PM-Timer Bug. Due to workarounds for a bug,
[    0.168733] * this clock source is slow. If you are sure your timer does not have
[    0.168735] * this bug, please use "acpi_pm_good" to disable the workaround
[    0.168850] pci 0000:00:1f.1: [8086:24cb] type 00 class 0x01018a
[    0.168873] pci 0000:00:1f.1: reg 10: [io  0xed90-0xed97]
[    0.168892] pci 0000:00:1f.1: reg 14: [io  0xed88-0xed8b]
[    0.168910] pci 0000:00:1f.1: reg 18: [io  0xed98-0xed9f]
[    0.168929] pci 0000:00:1f.1: reg 1c: [io  0xed8c-0xed8f]
[    0.168947] pci 0000:00:1f.1: reg 20: [io  0xffa0-0xffaf]
[    0.168966] pci 0000:00:1f.1: reg 24: [mem 0xfeb7fc00-0xfeb7ffff]
[    0.169017] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500
[    0.169083] pci 0000:00:1f.3: reg 20: [io  0xeda0-0xedbf]
[    0.169140] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100
[    0.169165] pci 0000:00:1f.5: reg 10: [io  0xee00-0xeeff]
[    0.169180] pci 0000:00:1f.5: reg 14: [io  0xedc0-0xedff]
[    0.169198] pci 0000:00:1f.5: reg 18: [mem 0xfeb7fa00-0xfeb7fbff]
[    0.169215] pci 0000:00:1f.5: reg 1c: [mem 0xfeb7f900-0xfeb7f9ff]
[    0.169276] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[    0.169343] pci 0000:01:05.0: [10de:0111] type 00 class 0x030000
[    0.169370] pci 0000:01:05.0: reg 10: [mem 0xfd000000-0xfdffffff]
[    0.169386] pci 0000:01:05.0: reg 14: [mem 0xf0000000-0xf7ffffff pref]
[    0.169440] pci 0000:01:05.0: reg 30: [mem 0xfea00000-0xfea0ffff pref]
[    0.169497] pci 0000:01:09.0: [14e4:4401] type 00 class 0x020000
[    0.169523] pci 0000:01:09.0: reg 10: [mem 0xfe9fe000-0xfe9fffff]
[    0.169588] pci 0000:01:09.0: reg 30: [mem 0xfea00000-0xfea03fff pref]
[    0.169616] pci 0000:01:09.0: supports D1 D2
[    0.169620] pci 0000:01:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.169670] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[    0.169682] pci 0000:00:1e.0:   bridge window [mem 0xfd000000-0xfeafffff]
[    0.169691] pci 0000:00:1e.0:   bridge window [mem 0xf0000000-0xf7ffffff pref]
[    0.169696] pci 0000:00:1e.0:   bridge window [io  0x0000-0xffff] (subtractive decode)
[    0.169702] pci 0000:00:1e.0:   bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[    0.169718] pci_bus 0000:00: on NUMA node 0
[    0.169731] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.170516] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[    0.171241]  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[    0.346659] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[    0.347105] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 15)
[    0.347547] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[    0.347996] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[    0.348476] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    0.348914] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    0.349350] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    0.349796] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[    0.350143] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[    0.350152] vgaarb: loaded
[    0.350156] vgaarb: bridge control possible 0000:01:05.0
[    0.350240] PCI: Using ACPI for IRQ routing
[    0.350251] PCI: pci_cache_line_size set to 64 bytes
[    0.350348] reserve RAM buffer: 000000001fe74000 - 000000001fffffff
[    0.350832] pnp: PnP ACPI init
[    0.350869] ACPI: bus type pnp registered
[    0.355061] pnp 00:00: [mem 0x00000000-0x0009ffff]
[    0.355069] pnp 00:00: [mem 0x00100000-0x00ffffff]
[    0.355075] pnp 00:00: [mem 0x01000000-0x1fe73fff]
[    0.355081] pnp 00:00: [mem 0x000c0000-0x000fffff]
[    0.355086] pnp 00:00: [mem 0xfec00000-0xfec0ffff]
[    0.355090] pnp 00:00: [mem 0xfee00000-0xfee0ffff]
[    0.355095] pnp 00:00: [mem 0xfecf0000-0xfecf0fff]
[    0.355099] pnp 00:00: [mem 0xffb00000-0xffbfffff]
[    0.355104] pnp 00:00: [mem 0xffc00000-0xffffffff]
[    0.355244] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.355254] system 00:00: [mem 0x00100000-0x00ffffff] could not be reserved
[    0.355261] system 00:00: [mem 0x01000000-0x1fe73fff] could not be reserved
[    0.355267] system 00:00: [mem 0x000c0000-0x000fffff] could not be reserved
[    0.355274] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[    0.355280] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[    0.355286] system 00:00: [mem 0xfecf0000-0xfecf0fff] has been reserved
[    0.355296] system 00:00: [mem 0xffb00000-0xffbfffff] has been reserved
[    0.355303] system 00:00: [mem 0xffc00000-0xffffffff] has been reserved
[    0.355311] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.357038] pnp 00:01: [bus 00-ff]
[    0.357046] pnp 00:01: [io  0x0cf8-0x0cff]
[    0.357052] pnp 00:01: [io  0x0000-0x0cf7 window]
[    0.357057] pnp 00:01: [io  0x0d00-0xffff window]
[    0.357062] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[    0.357067] pnp 00:01: [mem 0x80860000-0xfebfffff window]
[    0.357176] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[    0.359883] pnp 00:02: [io  0x0080-0x009f]
[    0.359891] pnp 00:02: [io  0x0000-0x001f]
[    0.359895] pnp 00:02: [io  0x00c0-0x00df]
[    0.359900] pnp 00:02: [dma 4]
[    0.360116] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.360272] pnp 00:03: [io  0x00f0-0x00ff]
[    0.360299] pnp 00:03: [irq 13]
[    0.360390] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.360545] pnp 00:04: [io  0x0061]
[    0.360622] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.360773] pnp 00:05: [io  0x0070-0x007f]
[    0.360796] pnp 00:05: [irq 8]
[    0.360879] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.364215] pnp 00:06: [io  0x03f0-0x03f5]
[    0.364223] pnp 00:06: [io  0x03f7]
[    0.364245] pnp 00:06: [irq 6]
[    0.364251] pnp 00:06: [dma 2]
[    0.364608] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.365742] pnp 00:07: [io  0x0060]
[    0.365749] pnp 00:07: [io  0x0064]
[    0.365772] pnp 00:07: [irq 1]
[    0.365875] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.368726] pnp 00:08: [irq 12]
[    0.368835] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 (active)
[    0.371411] pnp 00:09: [io  0x03f8-0x03ff]
[    0.371437] pnp 00:09: [irq 4]
[    0.371747] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.375532] pnp 00:0a: [io  0x0378-0x037f]
[    0.375540] pnp 00:0a: [io  0x0778-0x077f]
[    0.375562] pnp 00:0a: [irq 7]
[    0.375568] pnp 00:0a: [dma 0 disabled]
[    0.376266] pnp 00:0a: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.378217] pnp 00:0b: [io  0x0062-0x0063]
[    0.378225] pnp 00:0b: [io  0x0065-0x006f]
[    0.378230] pnp 00:0b: [io  0x00e0-0x00ef]
[    0.378234] pnp 00:0b: [io  0x0800-0x085f]
[    0.378238] pnp 00:0b: [io  0x0c00-0x0c7f]
[    0.378243] pnp 00:0b: [io  0x0860-0x08ff]
[    0.378385] system 00:0b: [io  0x0800-0x085f] has been reserved
[    0.378395] system 00:0b: [io  0x0c00-0x0c7f] has been reserved
[    0.378402] system 00:0b: [io  0x0860-0x08ff] has been reserved
[    0.378410] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.379423] pnp: PnP ACPI: found 12 devices
[    0.379431] ACPI: ACPI bus type pnp unregistered
[    0.379439] PnPBIOS: Disabled by ACPI PNP
[    0.420850] Switching to clocksource acpi_pm
[    0.420915] pci 0000:01:09.0: address space collision: [mem 0xfea00000-0xfea03fff pref] conflicts with 0000:01:05.0 [mem 0xfea00000-0xfea0ffff pref]
[    0.420952] pci 0000:01:09.0: BAR 6: assigned [mem 0xfe000000-0xfe003fff pref]
[    0.420961] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[    0.420972] pci 0000:00:1e.0:   bridge window [mem 0xfd000000-0xfeafffff]
[    0.420980] pci 0000:00:1e.0:   bridge window [mem 0xf0000000-0xf7ffffff pref]
[    0.421008] pci 0000:00:1e.0: setting latency timer to 64
[    0.421017] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    0.421022] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[    0.421028] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfeafffff]
[    0.421033] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf7ffffff pref]
[    0.421038] pci_bus 0000:01: resource 4 [io  0x0000-0xffff]
[    0.421043] pci_bus 0000:01: resource 5 [mem 0x00000000-0xffffffff]
[    0.421192] NET: Registered protocol family 2
[    0.421360] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.421742] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.421871] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[    0.422100] TCP: Hash tables configured (established 16384 bind 16384)
[    0.422109] TCP: reno registered
[    0.422127] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.422148] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.422417] NET: Registered protocol family 1
[    0.422706] pci 0000:01:05.0: Boot video device
[    0.422723] PCI: CLS 0 bytes, default 64
[    0.422848] Unpacking initramfs...
[    1.089185] Freeing initrd memory: 14836k freed
[    1.119030] Simple Boot Flag value 0x87 read from CMOS RAM was invalid
[    1.119040] Simple Boot Flag at 0x7a set to 0x1
[    1.119933] audit: initializing netlink socket (disabled)
[    1.119984] type=2000 audit(1423655426.116:1): initialized
[    1.136200] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    1.136641] VFS: Disk quotas dquot_6.5.2
[    1.136707] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.136926] msgmni has been set to 997
[    1.137491] alg: No test for stdrng (krng)
[    1.137588] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    1.137598] io scheduler noop registered
[    1.137602] io scheduler deadline registered
[    1.137652] io scheduler cfq registered (default)
[    1.137843] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.137888] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.137894] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    1.138505] GHES: HEST is not enabled!
[    1.138542] isapnp: Scanning for PnP cards...
[    1.493177] isapnp: No Plug & Play device found
[    1.493332] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.513781] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.534939] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.535350] Linux agpgart interface v0.103
[    1.535522] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[    1.535569] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[    1.535683] agpgart-intel 0000:00:00.0: detected 1024K stolen memory
[    1.535896] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe0000000
[    1.536267] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[    1.539568] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.539667] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.539984] mousedev: PS/2 mouse device common for all mice
[    1.540206] rtc_cmos 00:05: RTC can wake from S4
[    1.540450] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    1.540494] rtc0: alarms up to one day, 242 bytes nvram
[    1.540750] TCP: cubic registered
[    1.540859] NET: Registered protocol family 10
[    1.541418] Mobile IPv6
[    1.541431] NET: Registered protocol family 17
[    1.541450] Registering the dns_resolver key type
[    1.541568] Using IPI No-Shortcut mode
[    1.541899] PM: Hibernation image not present or could not be loaded.
[    1.541937] registered taskstats version 1
[    1.542504] rtc_cmos 00:05: setting system clock to 2015-02-11 11:50:27 UTC (1423655427)
[    1.542727] Freeing unused kernel memory: 416k freed
[    1.543557] Write protecting the kernel text: 3496k
[    1.543594] Write protecting the kernel read-only data: 984k
[    1.565032] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.592586] udevd[45]: starting version 175
[    1.699364] usbcore: registered new interface driver usbfs
[    1.699430] usbcore: registered new interface driver hub
[    1.720161] usbcore: registered new device driver usb
[    1.721481] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.721627] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    1.721637] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    1.721716] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    1.721790] ehci_hcd 0000:00:1d.7: debug port 1
[    1.743797] uhci_hcd: USB Universal Host Controller Interface driver
[    1.760126] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[    1.760174] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xffa80800
[    1.772429] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.772496] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.772503] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.772509] usb usb1: Product: EHCI Host Controller
[    1.772513] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    1.772517] usb usb1: SerialNumber: 0000:00:1d.7
[    1.772852] hub 1-0:1.0: USB hub found
[    1.772870] hub 1-0:1.0: 6 ports detected
[    1.804490] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    1.804501] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    1.804537] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.804609] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000ff80
[    1.804712] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.804720] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.804726] usb usb2: Product: UHCI Host Controller
[    1.804730] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    1.804734] usb usb2: SerialNumber: 0000:00:1d.0
[    1.812378] hub 2-0:1.0: USB hub found
[    1.812398] hub 2-0:1.0: 2 ports detected
[    1.819917] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    1.819927] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    1.819962] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    1.823006] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000ff60
[    1.823110] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.823118] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.823125] usb usb3: Product: UHCI Host Controller
[    1.823130] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    1.823134] usb usb3: SerialNumber: 0000:00:1d.1
[    1.828311] hub 3-0:1.0: USB hub found
[    1.828331] hub 3-0:1.0: 2 ports detected
[    1.837130] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    1.837141] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    1.837187] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    1.837260] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[    1.837356] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.837364] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.837369] usb usb4: Product: UHCI Host Controller
[    1.837373] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    1.837377] usb usb4: SerialNumber: 0000:00:1d.2
[    1.841798] hub 4-0:1.0: USB hub found
[    1.841819] hub 4-0:1.0: 2 ports detected
[    1.853024] Floppy drive(s): fd0 is 1.44M
[    1.871070] FDC 0 is a post-1991 82077
[    1.897870] SCSI subsystem initialized
[    1.921322] libata version 3.00 loaded.
[    1.922290] ata_piix 0000:00:1f.1: version 2.13
[    1.922427] ata_piix 0000:00:1f.1: setting latency timer to 64
[    1.928241] ssb: Found chip with id 0x4401, rev 0x01 and package 0x00
[    1.928255] ssb: Core 0 found: Fast Ethernet (cc 0x806, rev 0x04, vendor 0x4243)
[    1.928265] ssb: Core 1 found: V90 (cc 0x807, rev 0x01, vendor 0x4243)
[    1.928274] ssb: Core 2 found: PCI (cc 0x804, rev 0x02, vendor 0x4243)
[    1.929196] scsi0 : ata_piix
[    1.932130] scsi1 : ata_piix
[    1.932304] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[    1.932313] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[    1.939551] microcode: CPU0 sig=0xf29, pf=0x4, revision=0x11
[    1.969078] ssb: Sonics Silicon Backplane found on PCI device 0000:01:09.0
[    1.969171] b44: Broadcom 44xx/47xx 10/100 PCI ethernet driver version 2.0
[    1.988833] b44 ssb0:0: eth0: Broadcom 44xx/47xx 10/100 PCI ethernet driver 00:0b:db:bd:31:39
[    2.092309] ata2.01: NODEV after polling detection
[    2.097600] ata1.00: ATA-5: WDC WD400BB-00DEA0, 05.03E05, max UDMA/100
[    2.097609] ata1.00: 78165360 sectors, multi 8: LBA
[    2.100543] ata2.00: ATAPI: SAMSUNG CD-R/RW SW-248F, R602, max UDMA/33
[    2.113546] ata1.00: configured for UDMA/100
[    2.113872] scsi 0:0:0:0: Direct-Access     ATA      WDC WD400BB-00DE 05.0 PQ: 0 ANSI: 5
[    2.116380] ata2.00: configured for UDMA/33
[    2.118693] scsi 1:0:0:0: CD-ROM            SAMSUNG  CD-R/RW SW-248F  R602 PQ: 0 ANSI: 5
[    2.128165] Refined TSC clocksource calibration: 2192.884 MHz.
[    2.128180] Switching to clocksource tsc
[    2.179489] microcode: CPU0 updated to revision 0x2e, date = 2004-08-11
[    2.180667] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    2.186218] sd 0:0:0:0: [sda] 78165360 512-byte logical blocks: (40.0 GB/37.2 GiB)
[    2.186524] sd 0:0:0:0: [sda] Write Protect is off
[    2.186533] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.186664] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.228087]  sda: sda1 sda2 < sda5 >
[    2.229304] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.234654] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[    2.234665] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.236357] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.252495] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.254476] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    7.662210] device-mapper: uevent: version 1.0.3
[    7.664004] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    8.175944] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[   10.531445] udevd[308]: starting version 175
[   11.061940] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[   11.061959] ACPI: Power Button [VBTN]
[   11.062154] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[   11.062167] ACPI: Power Button [PWRF]
[   11.214628] [drm] Initialized drm 1.1.0 20060810
[   11.226457] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   11.335814] parport_pc 00:0a: reported by Plug and Play ACPI
[   11.335879] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[   11.366336] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[   11.416502] i915 0000:00:02.0: enabling device (0000 -> 0002)
[   11.421643] i915 0000:00:02.0: setting latency timer to 64
[   11.481335] intel_rng: FWH not detected
[   11.492309] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[   11.492318] [drm] Driver supports precise vblank timestamp query.
[   11.492338] i915 0000:00:02.0: BAR 6: can't assign [??? 0x00000000 flags 0x0] (bogus alignment)
[   11.492343] [drm] failed to find VBIOS tables
[   11.505387] ------------[ cut here ]------------
[   11.505438] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/drivers/gpu/drm/i915/intel_display.c:966 assert_pipe+0x92/0xa0 [i915]()
[   11.505445] Hardware name: Dimension 2400
[   11.505450] pipe A assertion failure (expected on, current off)
[   11.505453] Modules linked in: i2c_i801(+) i915(+) video drm_kms_helper dcdbas parport_pc rng_core parport shpchp drm thermal_sys i2c_algo_bit i2c_core button ext4 crc16 jbd2 mbcache dm_mod sg sr_mod cdrom sd_mod crc_t10dif ata_generic microcode ata_piix libata b44 ssb mmc_core scsi_mod mii pcmcia pcmcia_core floppy uhci_hcd ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[   11.505533] Pid: 373, comm: modprobe Not tainted 3.4-9-rtai-686-pae #1
[   11.505538] Call Trace:
[   11.505552]  [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[   11.505590]  [<e099bbc2>] ? assert_pipe+0x92/0xa0 [i915]
[   11.505620]  [<e099bbc2>] ? assert_pipe+0x92/0xa0 [i915]
[   11.505631]  [<c102aec3>] ? warn_slowpath_fmt+0x33/0x40
[   11.505659]  [<e099bbc2>] ? assert_pipe+0x92/0xa0 [i915]
[   11.505697]  [<e099d0e9>] ? intel_crtc_disable+0x39/0x70 [i915]
[   11.505707]  [<e088f1e7>] ? drm_helper_disable_unused_functions+0xe7/0x140 [drm_kms_helper]
[   11.505742]  [<e09a3b1b>] ? intel_modeset_init+0x6fb/0x1120 [i915]
[   11.505778]  [<e0981d91>] ? i915_driver_load+0xb61/0xfe0 [i915]
[   11.505812]  [<e097faf0>] ? i915_stolen_to_phys+0x90/0x90 [i915]
[   11.505829]  [<e08435d2>] ? drm_sysfs_device_add+0x72/0xa0 [drm]
[   11.505845]  [<e0842049>] ? drm_get_pci_dev+0x149/0x260 [drm]
[   11.505857]  [<c1363ea1>] ? _raw_spin_lock_irqsave+0x41/0x70
[   11.505865]  [<c1261727>] ? pm_runtime_enable+0x17/0x80
[   11.505875]  [<c11cbbde>] ? pci_device_probe+0x8e/0x110
[   11.505885]  [<c1259e40>] ? driver_probe_device+0x60/0x1d0
[   11.505892]  [<c136398d>] ? _raw_spin_unlock+0xd/0x30
[   11.505899]  [<c11cbb1f>] ? pci_match_device+0x8f/0xa0
[   11.505906]  [<c125a029>] ? __driver_attach+0x79/0x80
[   11.505913]  [<c1259fb0>] ? driver_probe_device+0x1d0/0x1d0
[   11.505920]  [<c12588a2>] ? bus_for_each_dev+0x42/0x70
[   11.505927]  [<c11cbc60>] ? pci_device_probe+0x110/0x110
[   11.505934]  [<c1259a59>] ? driver_attach+0x19/0x20
[   11.505941]  [<c1259fb0>] ? driver_probe_device+0x1d0/0x1d0
[   11.505947]  [<c12596ef>] ? bus_add_driver+0x16f/0x240
[   11.505954]  [<c11cbc60>] ? pci_device_probe+0x110/0x110
[   11.505960]  [<c125a4cf>] ? driver_register+0x5f/0x100
[   11.505973]  [<e0842191>] ? drm_pci_init+0x31/0x100 [drm]
[   11.505980]  [<c11cb9ac>] ? __pci_register_driver+0x3c/0xa0
[   11.505988]  [<c1001112>] ? do_one_initcall+0x32/0x190
[   11.505996]  [<c1024a11>] ? set_memory_ro+0x31/0x40
[   11.506011]  [<e089b000>] ? 0xe089afff
[   11.506019]  [<c1075bbd>] ? sys_init_module+0x8bd/0x1ad0
[   11.506039]  [<c1368c28>] ? sysenter_do_call+0x12/0x16
[   11.506046] ---[ end trace aea61128874bd245 ]---
[   11.531480] [drm] initialized overlay support
[   11.531519] ------------[ cut here ]------------
[   11.531564] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/drivers/gpu/drm/i915/intel_display.c:966 assert_pipe+0x92/0xa0 [i915]()
[   11.531570] Hardware name: Dimension 2400
[   11.531575] pipe A assertion failure (expected on, current off)
[   11.531579] Modules linked in: power_supply ac97_bus i2c_i801(+) i915(+) video drm_kms_helper dcdbas parport_pc rng_core parport shpchp drm thermal_sys i2c_algo_bit i2c_core button ext4 crc16 jbd2 mbcache dm_mod sg sr_mod cdrom sd_mod crc_t10dif ata_generic microcode ata_piix libata b44 ssb mmc_core scsi_mod mii pcmcia pcmcia_core floppy uhci_hcd ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[   11.531662] Pid: 373, comm: modprobe Tainted: G        W    3.4-9-rtai-686-pae #1
[   11.531666] Call Trace:
[   11.531681]  [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[   11.531711]  [<e099bbc2>] ? assert_pipe+0x92/0xa0 [i915]
[   11.531741]  [<e099bbc2>] ? assert_pipe+0x92/0xa0 [i915]
[   11.531752]  [<c102aec3>] ? warn_slowpath_fmt+0x33/0x40
[   11.531778]  [<e099bbc2>] ? assert_pipe+0x92/0xa0 [i915]
[   11.531804]  [<e099d0e9>] ? intel_crtc_disable+0x39/0x70 [i915]
[   11.531814]  [<e088f1e7>] ? drm_helper_disable_unused_functions+0xe7/0x140 [drm_kms_helper]
[   11.531822]  [<e088eb4c>] ? drm_fb_helper_initial_config+0x1c/0x220 [drm_kms_helper]
[   11.531831]  [<c1367107>] ? sub_preempt_count+0x67/0xa0
[   11.531839]  [<c10dc0bf>] ? kmem_cache_alloc+0xcf/0xe0
[   11.531846]  [<c10dc847>] ? __kmalloc+0x107/0x120
[   11.531852]  [<c10dc0bf>] ? kmem_cache_alloc+0xcf/0xe0
[   11.531882]  [<e09b1b48>] ? intel_fbdev_init+0x68/0xa0 [i915]
[   11.531902]  [<e0981fdb>] ? i915_driver_load+0xdab/0xfe0 [i915]
[   11.531920]  [<e08435d2>] ? drm_sysfs_device_add+0x72/0xa0 [drm]
[   11.531935]  [<e0842049>] ? drm_get_pci_dev+0x149/0x260 [drm]
[   11.531945]  [<c1363ea1>] ? _raw_spin_lock_irqsave+0x41/0x70
[   11.531954]  [<c1261727>] ? pm_runtime_enable+0x17/0x80
[   11.531964]  [<c11cbbde>] ? pci_device_probe+0x8e/0x110
[   11.531974]  [<c1259e40>] ? driver_probe_device+0x60/0x1d0
[   11.531981]  [<c136398d>] ? _raw_spin_unlock+0xd/0x30
[   11.531987]  [<c11cbb1f>] ? pci_match_device+0x8f/0xa0
[   11.532085]  [<c125a029>] ? __driver_attach+0x79/0x80
[   11.532100]  [<c1259fb0>] ? driver_probe_device+0x1d0/0x1d0
[   11.532106]  [<c12588a2>] ? bus_for_each_dev+0x42/0x70
[   11.532115]  [<c11cbc60>] ? pci_device_probe+0x110/0x110
[   11.532122]  [<c1259a59>] ? driver_attach+0x19/0x20
[   11.532129]  [<c1259fb0>] ? driver_probe_device+0x1d0/0x1d0
[   11.532136]  [<c12596ef>] ? bus_add_driver+0x16f/0x240
[   11.532143]  [<c11cbc60>] ? pci_device_probe+0x110/0x110
[   11.532149]  [<c125a4cf>] ? driver_register+0x5f/0x100
[   11.532165]  [<e0842191>] ? drm_pci_init+0x31/0x100 [drm]
[   11.532172]  [<c11cb9ac>] ? __pci_register_driver+0x3c/0xa0
[   11.532181]  [<c1001112>] ? do_one_initcall+0x32/0x190
[   11.532189]  [<c1024a11>] ? set_memory_ro+0x31/0x40
[   11.532205]  [<e089b000>] ? 0xe089afff
[   11.532213]  [<c1075bbd>] ? sys_init_module+0x8bd/0x1ad0
[   11.532232]  [<c1368c28>] ? sysenter_do_call+0x12/0x16
[   11.532240] ---[ end trace aea61128874bd246 ]---
[   11.552947] wmi: Mapper loaded
[   11.589995] [drm] capturing error event; look for more information in /debug/dri/0/i915_error_state
[   11.592036] render error detected, EIR: 0x00000010
[   11.592036] [drm:i915_report_and_clear_eir] *ERROR* EIR stuck: 0x00000010, masking
[   11.646835] iTCO_vendor_support: vendor-support=0
[   11.688473] No connectors reported connected with modes
[   11.688488] [drm] Cannot find any crtc or sizes - going 1024x768
[   11.727261] Console: switching to colour frame buffer device 128x48
[   11.750408] fb0: inteldrmfb frame buffer device
[   11.750414] drm: registered panic notifier
[   11.750434] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[   11.841043] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[   11.841232] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0860)
[   11.844766] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   12.065535] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[   12.098628] udevd[369]: renamed network interface eth0 to eth1
[   12.171143] [drm] nouveau 0000:01:05.0: Detected an NV10 generation card (0x011100b2)
[   12.173223] [drm] nouveau 0000:01:05.0: Checking PRAMIN for VBIOS
[   12.288676] [drm] nouveau 0000:01:05.0: ... appears to be valid
[   12.288686] [drm] nouveau 0000:01:05.0: Using VBIOS from PRAMIN
[   12.288808] [drm] nouveau 0000:01:05.0: BMP BIOS found
[   12.288813] [drm] nouveau 0000:01:05.0: BMP version 5.20
[   12.288819] [drm] nouveau 0000:01:05.0: Bios version 03.11.01.48
[   12.288825] [drm] nouveau 0000:01:05.0: No useful DCB data in VBIOS
[   12.290100] [drm] nouveau 0000:01:05.0: MXM: no VBIOS data, nothing to do
[   12.291356] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 0 at offset 0xADFE
[   12.291379] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 1 at offset 0xB4EC
[   12.291390] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 2 at offset 0xAE19
[   12.291414] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 3 at offset 0xB493
[   12.291427] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 4 at offset 0xAEAC
[   12.291433] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 5 at offset 0xB000
[   12.291464] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 6 at offset 0xAED1
[   12.359330] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 7 at offset 0xAF9B
[   12.360353] [TTM] Zone  kernel: Available graphics memory: 255496 kiB
[   12.360360] [TTM] Initializing pool allocator
[   12.360394] [drm] nouveau 0000:01:05.0: Detected 32MiB VRAM (SDRAM)
[   12.362451] [drm] nouveau 0000:01:05.0: 64 MiB GART (aperture)
[   12.362558] [drm] nouveau 0000:01:05.0: Saving VGA fonts
[   12.442721] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[   12.442731] [drm] No driver support for vblank timestamp query.
[   12.442824] [drm] nouveau 0000:01:05.0: 0 available performance level(s)
[   12.442832] [drm] nouveau 0000:01:05.0: c: core 174MHz memory 334MHz
[   12.443556] [drm] nouveau 0000:01:05.0: 0xB704: Parsing digital output script table
[   12.492401] intel8x0_measure_ac97_clock: measured 54667 usecs (2634 samples)
[   12.492410] intel8x0: clocking to 48000
[   12.534029] [drm] nouveau 0000:01:05.0: allocated 1280x1024 fb: 0x48000, bo ddca9400
[   12.534596] fbcon: nouveaufb (fb1) is primary device
[   12.534603] fbcon: Remapping primary device, fb1, to tty 1-63
[   12.546654] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
[   12.696407] fb1: nouveaufb frame buffer device
[   12.696426] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:05.0 on minor 1
[   15.776516] EXT4-fs (dm-0): re-mounted. Opts: (null)
[   16.221815] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
[   16.425970] loop: module loaded
[   18.055391] Adding 1044476k swap on /dev/mapper/KMB1-swap_1.  Priority:-1 extents:1 across:1044476k
[   20.309208] RPC: Registered named UNIX socket transport module.
[   20.309217] RPC: Registered udp transport module.
[   20.309221] RPC: Registered tcp transport module.
[   20.309225] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   20.364476] FS-Cache: Loaded
[   20.430345] NFS: Registering the id_resolver key type
[   20.430402] FS-Cache: Netfs 'nfs' registered for caching
[   20.446938] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   23.107900] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[   26.162186] Bluetooth: Core ver 2.16
[   26.163270] NET: Registered protocol family 31
[   26.163278] Bluetooth: HCI device and connection manager initialized
[   26.163284] Bluetooth: HCI socket layer initialized
[   26.163288] Bluetooth: L2CAP socket layer initialized
[   26.163312] Bluetooth: SCO socket layer initialized
[   26.236225] Bluetooth: RFCOMM TTY layer initialized
[   26.236243] Bluetooth: RFCOMM socket layer initialized
[   26.236248] Bluetooth: RFCOMM ver 1.11
[   26.398546] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   26.398555] Bluetooth: BNEP filters: protocol multicast
[   26.660268] lp0: using parport0 (interrupt-driven).
[   26.749732] ppdev: user-space parallel port driver
[   29.373985] ADDRCONF(NETDEV_UP): eth1: link is not ready
[  445.450708] I-pipe: head domain RTAI registered.
[  445.450731] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  445.450746] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  445.450752] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[  445.450758] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  445.450766] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6154250
[  445.527663] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  445.527812] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  445.527824] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[  445.527831] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[  445.527835] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[  445.573721] RTAI[math]: loaded.
[  445.862978] classicladder_rt: module license 'LGPL' taints kernel.
[  445.862989] Disabling lock debugging due to kernel taint
[  445.865681] creating ladder-state
[  457.366131] RTAI[math]: unloaded.
[  457.373266] SCHED releases registered named ALIEN PEDV$D
[  457.390102] RTAI[malloc]: unloaded.
[  457.488048] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  457.495049] I-pipe: head domain RTAI unregistered.
[  457.495071] RTAI[hal]: unmounted.
[  469.830404] I-pipe: head domain RTAI registered.
[  469.830425] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  469.830440] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  469.830447] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[  469.830453] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  469.830460] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6167750
[  469.862558] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  469.862697] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  469.862709] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[  469.862716] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[  469.862720] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[  469.898361] RTAI[math]: loaded.
[  470.204600] config string '0x378 out'
[  470.247145] creating ladder-state
[  473.700230] RTAI[math]: unloaded.
[  473.707392] SCHED releases registered named ALIEN PEDV$D
[  473.725022] RTAI[malloc]: unloaded.
[  473.824048] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  473.831129] I-pipe: head domain RTAI unregistered.
[  473.831150] RTAI[hal]: unmounted.
[  900.509330] I-pipe: head domain RTAI registered.
[  900.509351] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  900.509366] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  900.509373] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[  900.509379] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  900.509386] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6160000
[  900.545308] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  900.545453] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  900.545465] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[  900.545472] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[  900.545477] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[  900.581935] RTAI[math]: loaded.
[  900.761232] creating ladder-state
[  941.505267] RTAI[math]: unloaded.
[  941.516237] SCHED releases registered named ALIEN PEDV$D
[  941.534176] RTAI[malloc]: unloaded.
[  941.632042] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  941.639051] I-pipe: head domain RTAI unregistered.
[  941.639072] RTAI[hal]: unmounted.
[  975.743899] I-pipe: head domain RTAI registered.
[  975.743921] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  975.743936] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  975.743943] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[  975.743949] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  975.743957] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6158750
[  975.779837] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  975.779990] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  975.780465] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[  975.780473] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[  975.780477] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[  975.814778] RTAI[math]: loaded.
[  976.060525] config string '0x378 out'
[  976.091862] creating ladder-state
[  979.109268] RTAI[math]: unloaded.
[  979.116459] SCHED releases registered named ALIEN PEDV$D
[  979.133662] RTAI[malloc]: unloaded.
[  979.232049] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  979.239100] I-pipe: head domain RTAI unregistered.
[  979.239122] RTAI[hal]: unmounted.
[ 1054.740286] I-pipe: head domain RTAI registered.
[ 1054.740305] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1054.740318] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1054.740325] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[ 1054.740330] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1054.740338] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6147000
[ 1054.776171] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1054.776313] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1054.776326] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[ 1054.776333] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[ 1054.776337] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1054.810457] RTAI[math]: loaded.
[ 1055.056899] config string '0x378 out'
[ 1055.111897] creating ladder-state
[ 1058.155521] RTAI[math]: unloaded.
[ 1058.162641] SCHED releases registered named ALIEN PEDV$D
[ 1058.180302] RTAI[malloc]: unloaded.
[ 1058.280049] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1058.287128] I-pipe: head domain RTAI unregistered.
[ 1058.287151] RTAI[hal]: unmounted.
[ 1148.046106] I-pipe: head domain RTAI registered.
[ 1148.046128] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1148.046143] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1148.046150] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[ 1148.046155] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1148.046163] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6165750
[ 1148.082278] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1148.082426] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1148.082438] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[ 1148.082445] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[ 1148.082449] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1148.119202] RTAI[math]: loaded.
[ 1148.362055] config string '0x378 out'
[ 1148.392378] creating ladder-state
[ 1151.255078] spurious APIC interrupt on CPU#0, should never happen.
[ 1151.268928] RTAI[math]: unloaded.
[ 1151.275976] SCHED releases registered named ALIEN PEDV$D
[ 1151.294704] RTAI[malloc]: unloaded.
[ 1151.392052] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1151.399062] I-pipe: head domain RTAI unregistered.
[ 1151.399083] RTAI[hal]: unmounted.
[ 1224.684406] I-pipe: head domain RTAI registered.
[ 1224.684428] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1224.684442] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1224.684449] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[ 1224.684455] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1224.684463] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6128500
[ 1224.720874] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1224.721018] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1224.721031] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[ 1224.721037] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[ 1224.721042] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1224.757795] RTAI[math]: loaded.
[ 1225.023440] config string '0x378 out'
[ 1225.055402] creating ladder-state
[ 1228.258045] RTAI[math]: unloaded.
[ 1228.265305] SCHED releases registered named ALIEN PEDV$D
[ 1228.282954] RTAI[malloc]: unloaded.
[ 1228.380050] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1228.387102] I-pipe: head domain RTAI unregistered.
[ 1228.387124] RTAI[hal]: unmounted.
[ 1265.000195] b44 ssb0:0: eth1: Link is up at 100 Mbps, full duplex
[ 1265.000204] b44 ssb0:0: eth1: Flow control is off for TX and off for RX
[ 1265.000326] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 1275.344023] eth1: no IPv6 routers present
[ 1613.723376] I-pipe: head domain RTAI registered.
[ 1613.723397] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1613.723411] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1613.723418] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[ 1613.723424] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1613.723432] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6165500
[ 1613.757523] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1613.757661] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1613.757675] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[ 1613.757681] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[ 1613.757686] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1613.798460] RTAI[math]: loaded.
[ 1614.010304] creating ladder-state
[ 1620.682653] RTAI[math]: unloaded.
[ 1620.689917] SCHED releases registered named ALIEN PEDV$D
[ 1620.707757] RTAI[malloc]: unloaded.
[ 1620.804057] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1620.811224] I-pipe: head domain RTAI unregistered.
[ 1620.811247] RTAI[hal]: unmounted.
[ 1626.482176] I-pipe: head domain RTAI registered.
[ 1626.482194] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1626.482208] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1626.482215] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[ 1626.482221] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1626.482228] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6164750
[ 1626.525420] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1626.525584] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1626.525598] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[ 1626.525604] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[ 1626.525609] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1626.573665] RTAI[math]: loaded.
[ 1626.899721] creating ladder-state
[ 1681.680425] RTAI[math]: unloaded.
[ 1681.687538] SCHED releases registered named ALIEN PEDV$D
[ 1681.705327] RTAI[malloc]: unloaded.
[ 1681.804051] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1681.811212] I-pipe: head domain RTAI unregistered.
[ 1681.811235] RTAI[hal]: unmounted.
[ 1689.608572] I-pipe: head domain RTAI registered.
[ 1689.608591] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1689.608605] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1689.608612] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229770, CLK_FREQ 2192957000, CPU_FREQ 2192957000
[ 1689.608617] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1689.608624] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229770, 6229770, 6162000
[ 1689.642095] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1689.642237] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1689.642252] RTAI[sched]: hard timer type/freq = APIC/6229770(Hz); default timing: oneshot; linear timed lists.
[ 1689.642259] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2192957000 hz.
[ 1689.642263] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1689.678329] RTAI[math]: loaded.
[ 1689.932284] config string '0x378 out'
[ 1689.964668] creating ladder-state
[ 1692.964826] RTAI[math]: unloaded.
[ 1692.971884] SCHED releases registered named ALIEN PEDV$D
[ 1692.989939] RTAI[malloc]: unloaded.
[ 1693.088050] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1693.095150] I-pipe: head domain RTAI unregistered.
[ 1693.095171] RTAI[hal]: unmounted.
Last edit: 12 Feb 2015 21:14 by BigJohnT. Reason: add code tags
12 Feb 2015 15:31 #55910 by ArcEye
Replied by ArcEye on topic Startup Error
Hi
You will need to zip your whole config dir and attach it
(start xarchiver, create new zip file and then add the directory to it, a zip will attach easily to a post)
This is the error, impossible to guess what line 1 might contain
The dmsg printout just shows that you tried unsuccessfully to start many times in the same session
12 Feb 2015 22:09 #55917 by hurco
Thanks. Hope tar gzip is ok for the forum.
Used Squeeze. My install looks to be stuck with Xfce.
12 Feb 2015 22:35 #55918 by ArcEye
Strangely, there is nothing in custom.hal and I cannot see any spurious non-printing chars either.
Easiest thing is to just remove it from the ini file so that your [HAL] section is just
[HAL]
HALFILE = hurco2.hal
POSTGUI_HALFILE = custom_postgui.hal
Then try again and see if it starts, or what error you get next time
12 Feb 2015 22:57 #55921 by hurco
Linuxcnc now starts and goes to the Axis screen!!!
Do I ask my ClassicLadder question here in this forum or start a new post in the ClassicLadder section?
12 Feb 2015 23:04 #55923 by ArcEye
Excellent, we like simple problems :laugh:
I would post another question on the Classic ladder section, JT knows far more than me about that.
Time to create page: 0.072 seconds
