Linux will not boot
- bbarr828
28 Feb 2015 10:50 #56354
by bbarr828
Linux will not boot was created by bbarr828
I have downloaded ubuntu-10.04-linuxcnc3-i386 (3).iso onto both a Flash drive and a CD-R with the understanding that I should be able to boot my Windows PC with Linux by using F12 and then booting directly from either the drive or the disc. However, when I try this, I only get a black screen with a flashing cursor.
What am I missing?
Thanks,
Brian
What am I missing?
Thanks,
Brian
- jmelson
- Thank you received: 157
28 Feb 2015 14:05 #56355
by jmelson
Replied by jmelson on topic Linux will not boot
Put the CD into a working computer and try to look at the files there. if you see one 600+ MB file called ubuntu-xxxx.iso, you
have created the CD wrong. You need to burn the iso file to the CD with a CD burning program that can create
the iso file system on the CD, not record it as a data file. When burned to the CD as an ISO, it will then
be bootable. When you do this, there will be a tree of directories on the CD.
Check your CD burning program for a "burn as ISO" option. Some CD burning programs do not
have this option, or hide it very well.
Jon
Jon
- BigJohnT
- Thank you received: 1175
01 Mar 2015 07:35 #56367
by BigJohnT
Replied by BigJohnT on topic Linux will not boot
Time to create page: 0.073 seconds
