LinuxCNC 2.7
07 Mar 2015 04:50 #56522 by cncdan
LinuxCNC 2.7 was created by cncdan
have installed linuxCNC 2.7
when I run the Latency Test it run`s very high like over 170000 is this good or bad or is there something wrong with 2.7 that would cause this to happen
07 Mar 2015 05:01 #56523 by PCW
Replied by PCW on topic LinuxCNC 2.7
What hardware are you using?
Have you done the normal BIOs setup for real time?
(disable all power management, hyperthreading etc)
07 Mar 2015 05:17 #56524 by cncdan
Replied by cncdan on topic LinuxCNC 2.7
its using a G540
your other 2 question don't know I am a complete nob when it come`s to Linux.
the other thing this computer ran mach3 like a bag of crap so the computer might be useless just trying to see if I can get linuxCNC to run on the computer
07 Mar 2015 05:21 - 07 Mar 2015 05:21 #56525 by PCW
I meant what PC hardware are you using?
And did you disable all power management settings in BIOS?
Last edit: 07 Mar 2015 05:21 by PCW.
07 Mar 2015 06:05 #56526 by cncdan
first question, PP
second, no will try
Time to create page: 0.196 seconds
