Rigid taping problem.
- jbunch
- Thank you received: 3
09 Mar 2015 07:12 #56559
by jbunch
Rigid taping problem. was created by jbunch
I have been playing with this for a while. When I try to rigid tap on my lathe the carrriage will move the tap into the part and the error with one of two outcomes. It will error with a "Z following error" at the depth of the tap. Or it will move the tap into the part about 1.5 times the depth of the part and then will move to home with uncontrolled motion at an angle. At no time does it try to reverse the spindle. I am not sure what to do. I am running 2.6.5 and gmoccapy I just upgraded a couple of days ago but I have had this problem from the begining.
- ArcEye
- Thank you received: 758
09 Mar 2015 19:59 #56564
by ArcEye
Replied by ArcEye on topic Rigid taping problem.
Hi
Really need to know what code you are using and your encoder type and setup to have any chance someone can assist.
I am pretty sure Jon does a lot of rigid tapping, from something he mentioned, so someone should be able to help with enough info
- jbunch
09 Mar 2015 23:51 - 10 Mar 2015 00:04 #56580
by jbunch
Replied by jbunch on topic Rigid taping problem.
I have included a clip from my hal and ini file. The control is on a lathe.
I am able to drill, turn, and single pont thread. Constant surface speed works.
My encoder is a omron with 500 counts per rev and index.
I have tested the index and after being set it clears at the same point every rev.
Mesa electroncs
1 - 7i33 analog control
2 - 7i37 general IO
HAL Clip:
INI Clip:
Thank you
Jim
Mesa electroncs
2 - 7i37 general IO
HAL Clip:
# Generated by PNCconf at Fri Sep 2 04:29:39 2011
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i20/SVST8_4.BIT num_encoders=5 num_pwmgens=4 num_stepgens=0"
setp hm2_5i20.0.pwmgen.pwm_frequency 100000
setp hm2_5i20.0.pwmgen.pdm_frequency 100000
setp hm2_5i20.0.watchdog.timeout_ns 10000000
loadrt near
# ****************** Jog Pendant ******************
loadrt mux8 count=1
loadrt and2 count=16
loadrt or2 count=6
loadrt not count=2
loadrt mult2 count=1
loadrt xor2 count=2
loadrt toggle count=1
loadrt toggle2nist count=3
addf hm2_5i20.0.read servo-thread
loadrt pid num_chan=3
addf pid.0.do-pid-calcs servo-thread
addf pid.1.do-pid-calcs servo-thread
addf pid.2.do-pid-calcs servo-thread
addf or2.0 servo-thread
addf or2.1 servo-thread
addf or2.2 servo-thread
addf or2.3 servo-thread
addf or2.4 servo-thread # Transfer at speed bit to yam-postgui.hal
addf or2.5 servo-thread
addf and2.0 servo-thread # Postgui jog
addf and2.1 servo-thread # Postgui Jog
addf and2.2 servo-thread # Postgui
addf and2.3 servo-thread # Not Used
addf and2.4 servo-thread # Interlock mode.is-idle and Cycle start button
addf and2.5 servo-thread # Interlok Mode auto output pin to mode.is-auto
addf and2.6 servo-thread # program.is-idle lockout
addf and2.7 servo-thread # program.is-idle lockout
addf and2.8 servo-thread # program.is-running run program lockout
addf and2.9 servo-thread # program.is-running program is paused lockout
addf and2.10 servo-thread # Cycle start Button
addf and2.11 servo-thread # Program Paused
addf and2.12 servo-thread # Spindle Near cmd
addf and2.13 servo-thread # Program pause button
addf and2.14 servo-thread # Program pause/resume button
addf and2.15 servo-thread # spindle at Speed lock
addf mux8.0 servo-thread
addf not.0 servo-thread # Invert mode.is-idle
addf not.1 servo-thread # Invert program.is-running
addf xor2.0 servo-thread # Foot Switch
addf xor2.1 servo-thread # Foot Switch
addf mult2.0 servo-thread # Spindle RPM
addf toggle.0 servo-thread
addf toggle2nist.0 servo-thread
alias pin pid.0.Pgain pid.x.Pgain
alias pin pid.0.Igain pid.x.Igain
alias pin pid.0.Dgain pid.x.Dgain
alias pin pid.0.bias pid.x.bias
alias pin pid.0.FF0 pid.x.FF0
alias pin pid.0.FF1 pid.x.FF1
alias pin pid.0.FF2 pid.x.FF2
alias pin pid.0.deadband pid.x.deadband
alias pin pid.0.maxoutput pid.x.maxoutput
alias pin pid.0.enable pid.x.enable
alias pin pid.0.command pid.x.command
alias pin pid.0.feedback pid.x.feedback
alias pin pid.0.output pid.x.output
alias pin pid.0.index-enable pid.x.index-enable
alias pin pid.1.Pgain pid.z.Pgain
alias pin pid.1.Igain pid.z.Igain
alias pin pid.1.Dgain pid.z.Dgain
alias pin pid.1.bias pid.z.bias
alias pin pid.1.FF0 pid.z.FF0
alias pin pid.1.FF1 pid.z.FF1
alias pin pid.1.FF2 pid.z.FF2
alias pin pid.1.deadband pid.z.deadband
alias pin pid.1.maxoutput pid.z.maxoutput
alias pin pid.1.enable pid.z.enable
alias pin pid.1.command pid.z.command
alias pin pid.1.feedback pid.z.feedback
alias pin pid.1.output pid.z.output
alias pin pid.1.index-enable pid.z.index-enable
addf near.0 servo-thread
addf hm2_5i20.0.write servo-thread
addf hm2_5i20.0.pet_watchdog servo-thread
# external output signals
# external input signals
# --- HOME-X ---
net home-x <= hm2_5i20.0.gpio.030.in
# --- HOME-Z ---
net home-z <= hm2_5i20.0.gpio.031.in
# --- BOTH-X ---
net both-x <= hm2_5i20.0.gpio.028.in
# --- BOTH-Z ---
net both-z <= hm2_5i20.0.gpio.029.in
# --- ESTOP-EXT ---
net estop-ext <= hm2_5i20.0.gpio.048.in
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
net x-index-enable <=> pid.x.index-enable
# PWM Generator signals/setup
setp hm2_5i20.0.pwmgen.00.output-type 1
setp hm2_5i20.0.pwmgen.00.scale [AXIS_0]OUTPUT_SCALE
net xenable => pid.x.enable
net xoutput pid.x.output => hm2_5i20.0.pwmgen.00.value
net xpos-cmd axis.0.motor-pos-cmd => pid.x.command
net xenable axis.0.amp-enable-out => hm2_5i20.0.pwmgen.00.enable
setp hm2_5i20.0.encoder.00.counter-mode 0
setp hm2_5i20.0.encoder.00.filter 1
setp hm2_5i20.0.encoder.00.index-invert 0
setp hm2_5i20.0.encoder.00.index-mask 0
setp hm2_5i20.0.encoder.00.index-mask-invert 0
setp hm2_5i20.0.encoder.00.scale [AXIS_0]INPUT_SCALE
net xpos-fb <= hm2_5i20.0.encoder.00.position
net xpos-fb => pid.x.feedback
net xpos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i20.0.encoder.00.index-enable
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net both-x => axis.0.neg-lim-sw-in
net both-x => axis.0.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
net z-index-enable <=> pid.z.index-enable
setp hm2_5i20.0.pwmgen.01.output-type 1
setp hm2_5i20.0.pwmgen.01.scale [AXIS_2]OUTPUT_SCALE
net zenable => pid.z.enable
net zoutput pid.z.output => hm2_5i20.0.pwmgen.01.value
net zpos-cmd axis.2.motor-pos-cmd => pid.z.command
net zenable axis.2.amp-enable-out => hm2_5i20.0.pwmgen.01.enable
setp hm2_5i20.0.encoder.01.counter-mode 0
setp hm2_5i20.0.encoder.01.filter 1
setp hm2_5i20.0.encoder.01.index-invert 0
setp hm2_5i20.0.encoder.01.index-mask 0
setp hm2_5i20.0.encoder.01.index-mask-invert 0
setp hm2_5i20.0.encoder.01.scale [AXIS_2]INPUT_SCALE
net zpos-fb <= hm2_5i20.0.encoder.01.position
net zpos-fb => pid.z.feedback
net zpos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i20.0.encoder.01.index-enable
net home-z => axis.2.home-sw-in
net both-z => axis.2.neg-lim-sw-in
net both-z => axis.2.pos-lim-sw-in
# SPINDLE S
loadrt abs count=7
loadrt scale count=2
loadrt sum2 count=1
addf scale.0 servo-thread
addf scale.1 servo-thread # Scale for To RPM
addf abs.0 servo-thread # change RPM in yam-postgui.hal
addf abs.1 servo-thread # Not used
addf abs.2 servo-thread # spindle speed PID output correction
addf abs.3 servo-thread # not used
addf abs.4 servo-thread # Not used
addf abs.5 servo-thread # Not Used
addf abs.6 servo-thread # Not Used
addf sum2.0 servo-thread
# Encoder
setp hm2_5i20.0.encoder.02.counter-mode 0
setp hm2_5i20.0.encoder.02.filter 0
setp hm2_5i20.0.encoder.02.index-invert 0
setp hm2_5i20.0.encoder.02.index-mask 0
setp hm2_5i20.0.encoder.02.index-mask-invert 0
setp hm2_5i20.0.encoder.02.scale 2000
net spindle-index-enable motion.spindle-index-enable <=> hm2_5i20.0.encoder.02.index-enable
net spindle-revs motion.spindle-revs <= hm2_5i20.0.encoder.02.position
net spindle-velocity motion.spindle-speed-in near.0.in1 scale.1.in <= hm2_5i20.0.encoder.02.velocity
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-speed-out abs.2.in <= motion.spindle-speed-out
# Change velocity to RPM Output in yam-postgui.hal
setp scale.1.gain 60
# *** Spindle speed control
setp scale.0.offset 0.0
#setp scale.0.gain 0.0005405
setp scale.0.gain 0.000359702
setp hm2_5i20.0.pwmgen.02.output-type 1
net spindle-enable => hm2_5i20.0.pwmgen.02.enable
net spindle-enable => and2.15.in1
net spindle-rpm-cmd scale.0.in <= abs.2.out
net spin-lim-out scale.0.out => hm2_5i20.0.pwmgen.02.value
net spindle-rpm => abs.1.in
net spindle-speed-abs <= abs.1.out
# *** spindle at speed
setp near.0.difference 0.6
net com-spindle-vel near.0.in2 <= motion.spindle-speed-out-rps
net spindle-at-speed motion.spindle-at-speed and2.15.in0 <= near.0.out
# Spindle forward and reverse
net spindle-fwd hm2_5i20.0.gpio.040.out <= halui.spindle.runs-forward
net spindle-bkwd hm2_5i20.0.gpio.042.out <= halui.spindle.runs-backward
#******* Cycle Start feed Hold section ****************
#******** Cycle start and resume
net push_cycle_start and2.4.in1 and2.5.in1 <= hm2_5i20.0.gpio.060.in_not
net auto_mode_is_set and2.4.in0 not.0.in <= halui.mode.is-auto
net invert_auto_mode and2.5.in0 <= not.0.out
net sel_auto_mode halui.mode.auto <= and2.5.out
net interlock_auto_mode and2.6.in0 and2.7.in0 <= and2.4.out
net pgm_is_idle and2.6.in1 <= halui.program.is-idle
net pgm_is_paused and2.7.in1 <= halui.program.is-paused
net pgm_is_running_invert not.1.in <= halui.program.is-running
net pgm_is_running and2.8.in0 and2.9.in0 <= not.1.out
net pgm_idle_interlock and2.8.in1 <= and2.6.out
net pgm_paused_interlock and2.9.in1 <= and2.7.out
net start_run_pgm halui.program.run <= and2.8.out
net Resume_running_pgm halui.program.resume <= and2.9.out
#******** End Cycle Start and resume
#******** pause program/ stop program
net pgm_pause halui.program.pause <= hm2_5i20.0.gpio.059.in_not
INI Clip:
# nom2 -- no m2 terminator (use %)
NGCGUI_PREAMBLE = lathe_std.ngc
NGCGUI_SUBFILE = turn-od.ngc
NGCGUI_SUBFILE = bore-id.ngc
NGCGUI_SUBFILE = face-part.ngc
NGCGUI_SUBFILE = face.ngc
NGCGUI_SUBFILE = drill.ngc
NGCGUI_SUBFILE = thread.ngc
NGCGUI_SUBFILE = tap.ngc
EMBED_TAB_NAME = Functions
#alternate: EMBED_TAB_LOCATION = ntb_user_tabs
#this demo requires a parallel ngcgui dir
#EMBED_TAB_COMMAND = gladevcp -x {XID} pyngcgui_popupkeyboard.ui
EMBED_TAB_COMMAND = gladevcp -x {XID} pyngcgui.ui
#EMBED_TAB_NAME = Gremlinview
#EMBED_TAB_LOCATION = ntb_preview
# alternate: EMBED_TAB_LOCATION = ntb_user_tabs
# this demo requires a parallel ngcgui dir
#EMBED_TAB_COMMAND = gladevcp -x {XID} gremlin_view.ui
# Prefix to be used
PROGRAM_PREFIX = ../../nc_files/
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
# Task controller section -----------------------------------------------------
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
# Part program interpreter section --------------------------------------------
[RS274NGC]
#RS274NGC_STARTUP_CODE = G17 G20 G40 G43H0 G54 G64P0.005 G80 G90 G94 G97 M5 M9
RS274NGC_STARTUP_CODE = G18 G20 G40 G43 G54 G64P0.005 G80 G90 G94 G97 M5 M9
PARAMETER_FILE = emc.var
SUBROUTINE_PATH = ../../nc_files/ngcgui_files:../../nc_files/subroutines:../../nc_files/ngcgui_lib:../../nc_files/ngcgui_lib/utilitysubs
# USER_M_PATH = ../../nc_files/ngcgui_lib/mfiles
# SUBROUTINE_PATH = /home/jimbo/linuxcnc/nc_files/ngcgui_files
USER_M_PATH = ../../../nc_files
# Motion control section ------------------------------------------------------
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
# [HOSTMOT2]
# This is for info only
# DRIVER0=hm2_pci
# BOARD0=5i20
# CONFIG0="firmware=hm2/5i20/SVST8_4.BIT num_encoders=4 num_pwmgens=4 num_stepgens=0"
[HAL]
HALUI = halui
HALFILE = yam-lathe.hal
POSTGUI_HALFILE = yam-postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.4
MAX_VELOCITY = 7
MAX_LINEAR_VELOCITY = 1.67
POSITION_FILE = position.txt
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOLCHANGE_QUILL_UP = 1
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = -.125
FERROR = 0.015
MIN_FERROR = 0.0020
MAX_VELOCITY = 3.5
MAX_ACCELERATION = 3.5
P = 17.3
I = 0.0
D = 0.003
FF0 = 0.000
FF1 = 0.07039
FF2 = 0.000106
BIAS = 0.0
DEADBAND = 0.0
OUTPUT_SCALE = -1.0
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 10.0
#INPUT_SCALE = 50900
INPUT_SCALE = 12700.0
MIN_LIMIT = -5.625
MAX_LIMIT = .125
HOME_OFFSET = 0.000
HOME_SEARCH_VEL = .500
HOME_LATCH_VEL = .050
HOME_FINAL_VEL = .700
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = .0625
FERROR = 0.015
MIN_FERROR = 0.002
MAX_VELOCITY = 4
P = 24
I = 0.0
D = 0.05
FF0 = 0.0
FF1 = 0.1039
FF2 = 0.00206
BIAS = 0.0
DEADBAND = 0.0
OUTPUT_SCALE = -1.0
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 10.0
MIN_LIMIT = -13.1201
MAX_LIMIT = .0599
HOME_OFFSET = 0.0
HOME_FINAL_VEL = 1.000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Spindle
[SPINDLE_1]
P = 00.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.000
Thank you
Jim
Last edit: 10 Mar 2015 00:04 by jbunch.
- ArcEye
10 Mar 2015 00:17 #56590
by ArcEye
I assume you are using tap.ngc through a ngcgui panel?
What does it contain?
- jbunch
10 Mar 2015 01:51 - 10 Mar 2015 01:52 #56591
by jbunch
ArcEye,
here is the tap.ngc file:
Here is the preamble file:
Thank You
Jim
jimbo@jimbo-lathe:~/linuxcnc/nc_files/ngcgui_files$ more tap.ngc
(info: Rigid Tapping)
o<tap>sub
#<thread-type> = #1 (=0 0=TPI 1=MM)
#<thread> = #2 (TPI/Pitch)
#<Z_Start> = #3 (=0.100 Z Clearance)
#<T_Depth> = #4 (Thread Depth)
#<RPM> = #5 (Spindle RPM)
#<ToolNumber> = #6 (Tool Number)
#<Coolant> = #7 (=8 Coolant 8 On 9 Off)
G7 G18 G20 G40 G80
T#<ToolNumber> M6 G43
o110 if [#<thread-type> EQ 0]
#<pitch> = [1 / #<thread>]
G20
o110 else
#<pitch> = #<thread>
G21
o110 endif
; Tap the Hole
o120 if [#<thread-type> EQ 0 OR #<thread-type> EQ 1]
S#<RPM> M3 M#<Coolant>
G90
G0 X0.000 Z#<Z_Start>
G33.1 X0.000 Z#<T_Depth> K#<pitch>
M5 M9
G53 G0 X0 Z0
o120 else
(msg, you dufus you didn't use a proper thread type)
o120 endif
; Restore to normal units
G20
o<tap>endsub
jimbo@jimbo-lathe:~/linuxcnc/nc_files/ngcgui_files$ more lathe_std.ngc
(not_a_subfile)
g18 (xz plane)
g20 (inches)
g40 (cancel cutter radius compensation)
g49 (cancel tool lengthoffset)
g90 (absolute distance mode)
g94 (units/min feedrate)
g54 (Coordinate system 1 default)
#<tol> = 0.001
g64 p#<tol> (path control stop)
Thank You
Jim
Last edit: 10 Mar 2015 01:52 by jbunch.
- ArcEye
10 Mar 2015 18:11 #56613
by ArcEye
Hi
I cannot see anything obviously wrong with the code.
It is not possible to tell from the hal file how the encoder is connected to the 5i20, but assuming it has an A and B pulse plus Z index connected? it should work.
Hopefully someone with a working config tapping on a lathe will chime in
- Thank you received: 5015
10 Mar 2015 20:50 #56620
I think the problem might be here. Instead of using the halui pins (which might well be status pins) you probably want to use the motion.spindle-forward and motion.spindle-reverse pins.
Alternatively you can use the is-postive and is-negative pins of the abs function.
Also note that there are 4 different spindle speeds that you can use, absolute and signed, and both rpm and rps versions, depending on which is most convenient. You appear to use at least two of these for different things, which is fine, but it might be neater to link only one to a signal and re-use the signal.
I also see:Which could be avoided by using
Replied by andypugh on topic Rigid taping problem.
# Spindle forward and reverse net spindle-fwd hm2_5i20.0.gpio.040.out <= halui.spindle.runs-forward net spindle-bkwd hm2_5i20.0.gpio.042.out <= halui.spindle.runs-backward
I also see:
loadrt pid names=pid.x,pid.y,pid.z
The following user(s) said Thank You: ArcEye, jbunch
- jbunch
10 Mar 2015 20:53 #56621
by jbunch
Archeye,
One last thing. It is a back tool lathe.
Thanks again for looking.
Jim
Jim
- jbunch
10 Mar 2015 22:33 #56630
by jbunch
Andy,
Thank you that has resolved the problem.
Jim
Jim
