latency test won´t run
01 Apr 2015 23:12 #57393 by tox
latency test won´t run was created by tox
Hello to all,
I just tried to install a new 2.6.4 version on a new pc-board (Asus P5B-V).
No matter if I run from live-CD or from freshly installed systen, latency test just shows 2 rows of zeros.
I didn´t expect to get such extraordinary results from my new board ;-)
Does anybody know a possible solution or the cause of this problem?
Thanks in advance,
tox
28 Oct 2019 18:34 #148996 by pevlabs
Replied by pevlabs on topic latency test won´t run
Hello TOX,
Likely not your problem but on my system the latency test will not run with linuxCNC running.
28 Oct 2019 19:28 #148997 by PCW
Replied by PCW on topic latency test won´t run
That's correct you cannot run any separate latency test when LinuxCNC is running.
( You can however run the histogram component in a running LinuxCNC instance and get better latency data than what the latency test reports )
28 Oct 2019 20:16 #148999 by tox
Replied by tox on topic latency test won´t run
A: Where did I say I ran both at the same time?
B: Posting > 4 years old.
Thanks anyway,
tox
Time to create page: 0.098 seconds
