Getting Unexpected Realtime Delay on New Install
07 May 2015 13:26 #58466 by KenC
This is the code, name it what ever you like,
!#/bin/bash
exec xset -dpms s 0 0 s noblank s noexpose s off
ADD to STARUP APPLICATIONS list
[System > Preference > Startup Applications , click add. and do the necessary.]
08 May 2015 02:10 #58489 by Mr. Technical
Replied by Mr. Technical on topic Getting Unexpected Realtime Delay on New Install
Thanks PWC and KenC,
KenC, I assume that the shell you provided is made to run under Wheezy, right? I have already switched back to Ubuntu 10.04 and tried it again. No luck, as the attached dmesg file shows. I think it's time to move to another mobo.
Mr. Technical
File Name: log_2015-05-07.txt
File Size:4 KB
08 May 2015 02:24 - 08 May 2015 02:27 #58490 by PCW
I dont see anything wrong off hand in the dmesg
(well maybe that the 7I76 field I/O is not found which may mean that the field power is not present)
Last edit: 08 May 2015 02:27 by PCW.
08 May 2015 03:21 #58491 by Mr. Technical
Thanks, I appreciate your taking a look again. Consider the plug pulled. I'll have to get another motherboard just to keep moving forward on this one.
Mr. Technical
08 May 2015 11:03 - 08 May 2015 11:04 #58503 by KenC
I run Ubuntu 10.04, Linuxcnc 2.6.7.
The shell should run with both Ubuntu and Wheezy.
This should reduce your latency.
If you still feel its not good enough, you could do "isolcpus", its said that multicore actually is no good for RTAI.
BTW, what sort of latency are you expecting?
Last edit: 08 May 2015 11:04 by KenC.
29 Jun 2015 05:01 #60237 by isladelobos
Replied by isladelobos on topic Getting Unexpected Realtime Delay on New Install
I received this message in old (ubuntu 8) and in last versions of linux.
1Ghz processor. two old pci parallel ports and compact flash hard disk.
I changed the base_period to 15000 because a hard reduction 1:30 in the A axis. Need 1000rpm. for G0 moments.
with base_period up to 15000, the motors turn off at hight rpms
It is time to change the main board for put the steppers at full velocity.?
Is hard to found a main board that fit into the control box.
1001001
29 Jun 2015 13:25 #60243 by ArcEye
I changed the base_period to 15000.......
From?
........because a hard reduction 1:30 in the A axis. Need 1000rpm. for G0 moments.
No, the problem is your 30:1 ratio and desire to run A drive at the equivalent of 30,000rpm
You cannot expect any board to be able to generate that many steps, even with hardware stepping it is doubtful.
I would suggest you reduce your speed requirement or sort the A axis motor size or whatever and hence reduce the ratio, so that it can run within the step generation limits.
30 Jun 2015 02:48 #60263 by isladelobos
ouch!.
ok man ok 30:1. you win :-)
beers.
Time to create page: 0.148 seconds
