High latency numbers on Intel D945PVS motherboard
- bernie_nor
06 Apr 2015 04:39 #57559
by bernie_nor
High latency numbers on Intel D945PVS motherboard was created by bernie_nor
Hi All,
I'm having trouble reducing the latency on my computer. I get readings up to 345000ns of jitter on the base thread and 650000ns on the servo thread.
The numbers typicaly jumps up to these values when starting firefox.
I have a Intel D945PVS motherboard. It's equipped with a Intel Pentium running at 3.00GHz and 2GB of RAM.
This is what I've done in the BIOS-settings.in order to reduce the latency:
I've disabled any powersaving settings in the systems menu.
My best guess is that both kernels are still running. But I'm not sure how to turn one of them off.:
Any hints?
Cheers!
Bernie
- SW Single prosessor mode: Enabled
- MAX CPUID Value enabled
- On board Audio disabled
- ASF Support Disabled
- ACPI Suspend state set to "S1 State"
Any hints?
Cheers!
Bernie
- Thank you received: 4912
06 Apr 2015 05:36 #57564
Rather than run uniprocessor you might want to use isolcpus to let RTAI have a whole CPU to itself.
wiki.linuxcnc.org/cgi-bin/wiki.pl?TroubleShooting
And especially:
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
Replied by andypugh on topic High latency numbers on Intel D945PVS motherboard
And especially:
- Thank you received: 5021
06 Apr 2015 08:57 #57569
Replied by PCW on topic High latency numbers on Intel D945PVS motherboard
This may also be video board related so you might try another video board
- bernie_nor
06 Apr 2015 15:45 #57576
by bernie_nor
Thanks for the links.
Tested both solcpus=0 and isolcpus=1, but there is no improvment. isolcpus=0 on uniprocessor gave a nice kernel panic.
I will have a look at my videocard next.
Cheers!
Bernie
Replied by bernie_nor on topic High latency numbers on Intel D945PVS motherboard
And especially:
Cheers!
Bernie
- bernie_nor
09 Apr 2015 02:17 - 09 Apr 2015 02:39 #57634
by bernie_nor
Hi!
Replaced the Nvidia driver with the Nouveau driver did the trick.
These are the numbers I'm getting now:
Servo Thread (1 ms)Max interval: 998760, Max jitter: 3600
Base Thread (25 us) Max Interval: 29405, Max jitter: 4526
Hardware info:
Motherboard: Intel D945PVS
CPU: Intel Pentium D 3.00 GHz
RAM: 2GB (667MHz)
GFX: Nvidia GForce 7300GS running on Nouveau (Version 20091212 ??)
GRUB settings: isolcpus=1
Running software while testing: glxgears, Firefox, desktop remotely controlled, copying files, etc. for 1 hour.
And I have turnend off the single prossessor mode in BIOS again.
Thanks for the prompt help!
Bernie
Hardware info:
RAM: 2GB (667MHz)
Bernie
Last edit: 09 Apr 2015 02:39 by bernie_nor. Reason: Added more information
Time to create page: 0.153 seconds
