Compiling from source
- pmcstoneinc
12 Apr 2015 01:42 - 12 Apr 2015 02:46 #57692
by pmcstoneinc
Compiling from source was created by pmcstoneinc
Compiling from source on Arch system, getting stuck on the following....any help greatly appreciated
checking for tcl... /usr/lib/tclConfig.sh found
checking for tk... /usr/lib/tkConfig.sh found
checking for BWidget using /usr/bin/tclsh8.6... found
checking for BLT using tclsh8.5... not found
checking for img::png using /usr/bin/tclsh8.6... configure: error: not found
new to linux as well, I am thinking there will be a long list of dependencies to be met on arch.....
Last edit: 12 Apr 2015 02:46 by pmcstoneinc.
- Thank you received: 5013
12 Apr 2015 05:27 #57700
Replied by andypugh on topic Compiling from source
This might help:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal...g_build_dependencies
- pmcstoneinc
12 Apr 2015 05:35 #57702
by pmcstoneinc
Replied by pmcstoneinc on topic Compiling from source
Excuse my ignorance but is that not for Debian/ubuntu?
12 Apr 2015 05:39 #57703
Yes, and it might not work, but it is probably worth a try.
- pmcstoneinc
12 Apr 2015 05:51 #57704
by pmcstoneinc
No love for Arch?
- ArcEye
- Thank you received: 758
12 Apr 2015 16:38 #57713
by ArcEye
Not really, if you are new to Linux and want to use Linuxcnc, is there some reason that you want to use Arch? Debian would be a saner choice.
For that matter where did you get the rtai kernel, or are you planning to run on a rt-preempt one?
Your problem is similar to those I have had in the past and revolves around tk / tcl version numbers
You appear to need both 8.5 and 8.6
Trouble is I have no idea how Arch packages it or which version is default.
Linuxcnc builds on libraries available for Debian (and Ubuntu since that is just repackaged debian)
This may not be the end of your problems.
I do know that I have had to manually remove the config scripts for tk / tcl before now, because if one version was installed and that version is changed, the config script
still refers to the original version and causes all sorts of grief.
Replied by ArcEye on topic Compiling from source
No love for Arch?
- pmcstoneinc
14 Apr 2015 00:09 #57766
by pmcstoneinc
Debian being a saner choice.....agreed, but I like the challenge, from time to time. Hardware will be Mesa ethernet card, and from what I am gathering sounds like I will need the preempt kernel, thanks for the input.
Time to create page: 0.096 seconds
