Uninstalling Linuxcnc
24 Apr 2015 14:15 #58066 by KenC
Uninstalling Linuxcnc was created by KenC
Something went wrong when I was fooling around with JointAxis Branch.
Is there a way to uninstalling Linuxcnc like pressing a reset button?
You help is most appriciated
Regards
Ken
24 Apr 2015 14:48 #58067 by ArcEye
Replied by ArcEye on topic Uninstalling Linuxcnc
Ken,
sudo apt-get remove linuxcnc
The problem is whether the libraries that the new, wrong, version of linuxcnc had as dependencies and were also installed, will screw things up.
Only way to tell is try it ( AFTER YOU HAVE BACKED UP YOUR DATA) and if it fails then cut and paste the error messages so we can see what the block is.
Thereafter try to only use synaptic to install and uninstall packages, don't double click things in the file manager, you will stand a better chance of recovery.
Time to create page: 0.116 seconds
