[Debian Wheezy] Easy install LinuxCNC
- birchy
27 Apr 2015 04:46 - 14 Jun 2015 23:15 #58146
by birchy
[Debian Wheezy] Easy install LinuxCNC was created by birchy
Attached are 2 "easy setup" scripts for installing an RTAI kernel and LinuxCNC on Debian Wheezy (i386). A clean installation of Debian Wheezy is required before running the scripts. The scripts have been tested using the XFCE desktop version of Wheezy, however I can't see any reason why they would not work with other desktop versions.
MODS/ADMIN: Please test and verify these scripts and if OK, feel free to pin them.
Last edit: 14 Jun 2015 23:15 by birchy.
The following user(s) said Thank You: KenC, ArcEye
- ArcEye
- Thank you received: 758
27 Apr 2015 15:52 #58151
by ArcEye
Replied by ArcEye on topic [Debian Wheezy] Easy install LinuxCNC
Hi again,
Glad to see you persevered and can now whip up a working system as required
I don't have anything to test with at present, hopefully someone else will be able to.
- birchy
30 Apr 2015 00:02 - 30 Apr 2015 02:04 #58242
by birchy
Replied by birchy on topic [Debian Wheezy] Easy install LinuxCNC
I'm soooo out of date. There's now a Wheezy installation ISO: linuxcnc.org/index.php/english/download
Last edit: 30 Apr 2015 02:04 by birchy.
- ArcEye
30 Apr 2015 14:45 #58256
by ArcEye
You can never have too many alternatives.
Bet what you learnt doing this will benefit you in the future.
There are quite a few people trying to install, who don't have DVD drives and have been completely unable to get the hybrid iso to boot off a USB stick, so this is still an option
- Thank you received: 4976
30 Apr 2015 18:09 #58265
Replied by andypugh on topic [Debian Wheezy] Easy install LinuxCNC
The archive file is a bit hard t extract, as it contains an archive file with the same name...
- birchy
02 May 2015 01:44 #58304
by birchy
I have now updated my first post and uploaded the scripts as Zip file instead. Please let me know if its OK now?
Not sure what happened there,because there are no archive files inside. There is a folder named "setup-cnc", so maybe that was causing a conflict with the original "setup-cnc" tar? Strangely, the archive extrcts OK on my Wheezy machine with a simple right-click -> exctract here...?The archive file is a bit hard t extract, as it contains an archive file with the same name...
- Askjerry
- Thank you received: 36
14 Jun 2015 22:04 #59812
by Askjerry
Replied by Askjerry on topic [Debian Wheezy] Easy install LinuxCNC - EDIT
I have an install at the ATX Hackerspace (Austin, TX) that was originally built on Ubuntu 10.04 early this year. Axis was upgraded to 2.6 and all was working fine. The host PC started to have issues and was replaced, they downloaded the latest ISO; Debian Wheezy, and reinstalled my configuration files.
Everything appears to work except if you click EDIT to edit the G-Code... apparently, GEDIT does not exist... so AXIS has no clue how to edit the file... it just sits there. I can go to the file and click it... and it will come up in another editor.
How do I fix Axis to be able to just click EDIT and make revisions quickly?
Thanks,
Jerry
Thanks,
Jerry
- birchy
14 Jun 2015 22:15 #59813
by birchy
For now, you can simply do:
Replied by birchy on topic [Debian Wheezy] Easy install LinuxCNC - EDIT
Gedit is a standard text editor for Debian/Ubuntu, so I would assume that installing it should resolve your problem. The default install of Debian comes with 'mousepad' text editor, hence the missing dependency. I'll add it to the install script for future reference.... apparently, GEDIT does not exist...
$ su (enter root password)
$ aptitude install gedit
- BigJohnT
- Thank you received: 1176
14 Jun 2015 22:57 #59815
by BigJohnT
Replied by BigJohnT on topic [Debian Wheezy] Easy install LinuxCNC - EDIT
Or open the Synaptic Package Manager (if you can find it on the silly menu xfc uses) and add it.
JT
JT
- birchy
14 Jun 2015 23:11 #59816
by birchy
Why is that "silly"?
Menu > System > Synaptic Package Manager
