password unrecognized
- tcoleman978
15 May 2015 08:25 #58710
by tcoleman978
password unrecognized was created by tcoleman978
I did an install of the Debian wheeze/linuxcnc 2.6 from the iso download. As I have no Internet it was the easiest way to upgrade. I installed from the "install graphic" menu selection and the format cleaned the SS drive. I entered a password when asked and was asked in only one place. On reboot it asks for a password and will not recognize anything I have tried as a valid password. Is there a secret handshake I have to use ? It also gives me a choice of a default session and some other type of session. I also have worked with Linux a whole 3 days now. What am I missing gentlemen?
- ArcEye
- Thank you received: 758
15 May 2015 13:05 - 15 May 2015 16:48 #58711
by ArcEye
Replied by ArcEye on topic password unrecognized
Hi
This post covers most things, if you actually need to reset the password,
EDIT (link missed out)
www.linuxcnc.org/index.php/english/forum...rrect-password#52203
The dialog does not ask you for your password, it asks for your log in, which is your user name and THEN your password.
This causes confusion with people used to a single user system set up as windoze can be.
The session determines which window manager to use. Just use the default until you find your way around.
Last edit: 15 May 2015 16:48 by ArcEye.
- tcoleman978
15 May 2015 19:02 #58731
by tcoleman978
Replied by tcoleman978 on topic password unrecognized
Yup, thats it. What confused me was the response of unrecognized password as opposed unrecognized user. Sooo.... I thought it wanted a password as there was only one user. Thanx now to dive inhead first.
