Test (Today)
test of forum features
Failed to fetch http://linuxcnc.org/wheezy/dists/
26 May 2015 03:35 #59032 by jimcisme
What am I doing wrong?
I want 2.7.
I followed these directions :
Getting Started V2.7.0-pre6-55-g4393531, 2015-05-25
3.7.1 Installing on Debian Wheezy (with Preempt-RT kernel)
This is what I get:
Failed to fetch linuxcnc.org/wheezy/dists/base/2.7-uspace/source/Sources 404 Not Found
Failed to fetch linuxcnc.org/wheezy/dists/base/2.7-uspace/binary-amd64/Packages 404 Not Found
Some index files failed to download. They have been ignored, or old ones used instead.
26 May 2015 06:12 #59044 by andypugh
Well, the actual binaries are at www.linuxcnc.org/dists/wheezy/2.7-uspace/
(ie, you seem to have dists/wheezy back to front. But I am not sure how you configured things so it might not be your fault.
The following user(s) said Thank You: jimcisme
Time to create page: 0.129 seconds
