ZorinOS RTAI Support
14 Jun 2015 10:28 #59796 by ImJay
ZorinOS RTAI Support was created by ImJay
Hi all.
I'm a newbie to the CNC world but I'm so grateful for open-source projects such as LinuxCNC.
Just wondering if ZorinOS could be supported with a RTAI kernal patch, as it provides awesome Wine functionality out of the box.
- Jay.
14 Jun 2015 12:46 #59800 by cmorley
Replied by cmorley on topic ZorinOS RTAI Support
What version of Ubuntu is zorbinos based on?
Linuxcnc developers seem to prefer Debian now, though I have heard of someone using Mint.
Chris M
14 Jun 2015 14:42 - 14 Jun 2015 14:45 #59803 by ImJay
Replied by ImJay on topic ZorinOS RTAI Support
I believe it is based on 14.04LTS, not sure about the kernal version though (3.13.0 at August, 2014 - will check again soon).
Just if I had the knowledge to slap together a proper RTAI patch. I assume something like this may work (gist.github.com/gaoyifan/c881aa36cd02fb5c1c20) if I get the kernal versions offered by rtai and ZorinOS(Ubuntu) correct - assuming the Zorin kernal is default/vanilla.
- Jay.
Last edit: 14 Jun 2015 14:45 by ImJay.
14 Jun 2015 16:00 - 14 Jun 2015 16:04 #59805 by ArcEye
Replied by ArcEye on topic ZorinOS RTAI Support
You don't need to, it is already done
github.com/NTULINUX/RTAI contains patches and basic kernel configs
The kernel version used by Zorin is irrelevant, as long as you use one that is the same or newer, to ensure any module support it relies upon etc. is present.
Depends how much knowledge you do have
PS
I am not going to get into coaching rtai kernel building again, but Birchy used what he learnt to produce scripts which will show you the process,
even if the target is not quite the same.
www.linuxcnc.org/index.php/english/forum...stall-linuxcnc#58146
Last edit: 14 Jun 2015 16:04 by ArcEye.
14 Jun 2015 16:36 #59806 by ImJay
Awesome, thank you for the info and links.
I'll be giving it a go soon enough.
Thanks!
- Jay.
Time to create page: 0.106 seconds
