Install from usb
03 Jul 2015 08:27 #60360 by awilcox
Install from usb was created by awilcox
I am installing 2.6 from a usb stick and I have a question before I screw up. The disk search finds the hard drive and the usb stick. Will I delete information on the usb stick if I continue? If so, how do I remove the usb stick from the list?
Adrian
03 Jul 2015 10:15 #60361 by awilcox
Replied by awilcox on topic Install from usb (SOLVED)
Make sure you select the hard drive you want to format and then continue.
Next issue, login screen will not recognize password. I reloaded software 2 times but could not fix the problem...any suggestions?
Adrian
03 Jul 2015 12:51 #60365 by ArcEye
Replied by ArcEye on topic Install from usb (SOLVED)
The log-in is your user name
The password is the password.
This causes no end of problems with people coming from windoze.
Linux is a multi-user system, unlike windoze which can have multiple users.
Debian fixed this in Jessie with a log in dialog with 2 fields, so that it is obvious.
The following user(s) said Thank You: awilcox
03 Jul 2015 17:30 #60373 by awilcox
ArcEye,
Thanks, I found the problem in the wee hours last night. You are correct about the transition from windoze. I used to work in unix many moons ago and forgot about the login dialog. You have to read the screen and not ASSUME.
My next question: I am considering using gmocaddy but the wiki seems a bit confusing and the 124 page thread overwhelming to read through. Is it woth the effort?
Adrian
03 Jul 2015 17:47 #60375 by ArcEye
There is a demo sim amoungst the configs, try that and decide for yourself.
I don't have a touch screen and don't like python, but plenty of other people use it.
Time to create page: 0.415 seconds
