Not allowed to upgrade with apt-get dist upgrade?
- lkuchars
15 Jul 2015 21:08 #60635
by lkuchars
Not allowed to upgrade with apt-get dist upgrade? was created by lkuchars
My version of linuxcnc is:
This is fresh installation and I'm about to do my first ever testing of 2 stepping motors with easy driver 44. I installed my linuxcnc to HD over 6 months ago and today I did
But then on linuxcnc.org homepage I saw this note at the end:
Can anyone explain this? Is it wrong to upgrade this way? I want to make sure I have my setup right before start plugging cables and electrics.
Linux 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55.4linuxcnc
apt-get dist-upgrade
Note: Do Not upgrade the Linux operating system from the installed version as it will prevent LinuxCNC from working as a specific kernel is required.
- Thank you received: 2162
16 Jul 2015 05:45 #60642
Replied by cmorley on topic Not allowed to upgrade with apt-get dist upgrade?
you don't want to upgrade to a newer version of the distribution.
eg don't upgrade 10.04 to 10.06
looks like you are using Debian Wheezy so stick with Wheezy.
other upgrades are usually fine, with the caveat that kernel upgrades usually make themselves the preferred kernel to load,
so you might have to manually select the right kernel or otherwise fix that problem.
Chris M
Chris M
The following user(s) said Thank You: lkuchars
Time to create page: 0.053 seconds
