Cannot change repositories using Debian ISO
- AggieMEEN
19 Jul 2015 02:28 #60741
by AggieMEEN
Cannot change repositories using Debian ISO was created by AggieMEEN
First off: I am a Linux newbie when it comes to the CLI and its inner workings.
I executed a clean install of the LinuxCNC 2.6 Debian hybrid ISO and noticed that I cannot enable any of the other software repositories (non-free, etc) from Synaptic or the update manager. I can click the box, but the check-mark does not stay. Very odd.
Has anyone else had this happen with the Debian Wheezy that comes in the hybrid ISO?
Thanks,
Thanks,
- ArcEye
- Thank you received: 758
19 Jul 2015 16:09 - 19 Jul 2015 16:15 #60755
by ArcEye
Replied by ArcEye on topic Cannot change repositories using Debian ISO
Can only assume that whatever is in there is not correct?
I never use synaptic for that kind of thing.
Go to /etc/apt/ and rename sources.list to sources.list.old
Then put the attached in its place
(or if that is problematic, cut and paste the below into your existing file and comment ## out the previous lines)
Contains
which are all the main ones for US locations
Afterwards run sudo apt-get update to update the available files lists
Contains
deb http://ftp.us.debian.org/debian/ wheezy main non-free contrib
deb-src http://ftp.us.debian.org/debian/ wheezy main non-free contrib
deb http://security.debian.org/ wheezy/updates main contrib non-free
deb-src http://security.debian.org/ wheezy/updates main contrib non-free
# wheezy-updates, previously known as 'volatile'
deb http://ftp.us.debian.org/debian/ wheezy-updates main contrib non-free
deb-src http://ftp.us.debian.org/debian/ wheezy-updates main contrib non-free
# wheezy-backports
deb http://ftp.us.debian.org/debian/ wheezy-backports main contrib non-free
deb-src http://ftp.us.debian.org/debian/ wheezy-backports main contrib non-free
Last edit: 19 Jul 2015 16:15 by ArcEye.
- cncbasher
- Thank you received: 288
19 Jul 2015 16:25 #60756
by cncbasher
Replied by cncbasher on topic Cannot change repositories using Debian ISO
looks to me your not logged in as root , when using the package manager , have you created a user or using a user without the correct rights
change <your username > to reflect your setup
from a terminal
su -c "adduser <your username> sudo"
then logout and log back in again
from a terminal
- AggieMEEN
19 Jul 2015 22:45 #60761
by AggieMEEN
Replied by AggieMEEN on topic Cannot change repositories using Debian ISO
@cncbasher
I got an authentication error when I tried running the su command. Not sure what to make of that.
When I executed "sudo adduser <my username> sudo" in terminal, it replied back that my username is already a member of sudo.
@ArcEye
From some of the reading I've been doing on Debian Wheezy this is a known issue with Synaptic for a lot of people (maybe everyone?). Apparently it's best to edit the sources.list and work through CLI, avoiding Synaptic.
Right now the only repository I have access to is "Source Code." The other ones (Main, Contrib, Non-Free) are "un-checkmarkable." If I only need Source Code then that's fine; this computer is intended to be a CNC control computer only. If I need the other repositories, then I'll have to work through CLI and edit sources.list.
Thank you all for the replies!
@ArcEye
Time to create page: 0.053 seconds
