Is there any reason to use RTAI over other option?
- luedcortes
11 Aug 2015 09:24 #61286
by luedcortes
Is there any reason to use RTAI over other option? was created by luedcortes
I'm considering to install Debian 8 Jessie (stable) using CONFIG_PREEMPT_RT or Xenomai instead of RTAI to use LINUXCNC (2.8.0-pre1). ¿Is there any technical reason to use RTAI over these other options? Thanks.
- Thank you received: 5022
11 Aug 2015 10:37 - 11 Aug 2015 21:16 #61287
Replied by PCW on topic Is there any reason to use RTAI over other option?
RTAI typically has lower latency than Xenomai or Preempt-RT
This is usually only important for software step generation.
Note that Linuxcnc does not currently support Xenomai, only RTAI and Preempt-RT
and Preempt RT is only supported in LinuxCNC 2.7 or greater
Preempt-RT can have decent latency (good enough for software step generation)
on _fast_ machines:
freeby.mesanet.com/h97-g3258-preemt-rt.png
and typically runs quite badly on slow machines:
freeby.mesanet.com/atom-330-preempt-rt.png
on _fast_ machines:
Last edit: 11 Aug 2015 21:16 by PCW.
The following user(s) said Thank You: luedcortes, developer
