Old config and 2.7
- allenwg2005
- Thank you received: 4
08 Sep 2015 22:53 #62273
by allenwg2005
Old config and 2.7 was created by allenwg2005
I'm setting up a newish PC on my machine and I went for 2.7 as long as I'm investing the time.
It simulates just fine, but my 2.5.4 config files are understandably out dated.
Could someone please let me know what I need to change to bring this up to date.
Thanks so much for any help.
Start up error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0
Machine configuration directory is '/home/allen/linuxcnc/configs/Router'
Machine configuration file is 'Router.ini'
INIFILE=/home/allen/linuxcnc/configs/Router/Router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Router.hal
Killing task linuxcncsvr, PID=4029
Start up error:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.0
TASK=milltask
HALUI=halui
DISPLAY=axis
- cncbasher
- Thank you received: 288
08 Sep 2015 23:33 - 08 Sep 2015 23:42 #62275
by cncbasher
Replied by cncbasher on topic Old config and 2.7
remove from the hal file the following line
loadrt probe_parport
and from the INI
NML_FILE = emc.nml
that should be it Allen
make sure you use the linuxcnc folder name rather than the older emc2
you may or may not need to remove the probe parport , as the latest build has this removed , but may or may not have trickled down to the build you have .
if you have problems , unhide hidden files , and remove any saying emc nml etc
you files load fine here in latest version .
and from the INI
NML_FILE = emc.nml
Last edit: 08 Sep 2015 23:42 by cncbasher.
The following user(s) said Thank You: allenwg2005
- allenwg2005
08 Sep 2015 23:47 #62277
by allenwg2005
Replied by allenwg2005 on topic Old config and 2.7
Good to hear from you Basher,
I'll do this later this evening (my time).
Gota go turn wrenches!
Thanks, Allen
Thanks, Allen
Time to create page: 0.098 seconds
