latency test freezing
- colton.S9
Processor 1.4GHz
Ram 4GB
System 64bit
Hard disc 8G
- Thank you received: 5022
would make it easier for people to help
- colton.S9
dmesg
if you want to paste the results here you can re-direct the output to a file:
dmesg > someoldfilename
- BigJohnT
- Thank you received: 1175
PCW how do i look up the kernel logs?
linuxcnc.org/docs/html/common/linux-faq.html#_bootup_messages
JT
i downloaded Oracle VM Virtual Box to set up a separate machine with no systems to interfere with the linux download. it seemed to work, the 2.7 download and set up went smooth, but once i tried the latency test the screen would freeze.
The real time portion of LinuxCNC (including the latency test) will not run
(It may crawl) under a hyperviser Like Virtualbox.
To run the real time portion of LinuxCNC in a usable fashion,
LinuxCNC must be installed on the bare machine.
- ArcEye
- Thank you received: 758
i recently tried to install linux on a new computer and got an error telling me that linux doesn't support windows 6.2.9200 SOP yet
I presume you got this " linux doesn't support windows 6.2.9200 SPO" error because you tried to install linux from within windoze.
You need to boot from the DVD, not try and run it from windoze, it is a complete operating system, not a program.
The latency-test error you got is because realtime is not running, or as PCW says is running in such a throttled way as makes no difference.
Boot from the DVD and create a separate partition and install to that. So long as you leave windoze where it is, it will still work and GRUB will give you a dual boot menu.
You must go into BIOS and disable 'Secure Boot' and UEFI first, to be able to install .
- colton.S9
so am i doing something wrong on the booting/installing process?
or is their a way to wipe my computer clean of its operating system and boot from their? i have been looking for a way to do this and i can only find the restore to factory settings..
- racedirector
- Thank you received: 42
- ArcEye
i have tried to boot from the DVD.. and the 1st window asks me witch operating system i want to use. Windows 8.1 or Debian GNU/Linux and continue with install. when i chose Debian and continue with install the 2nd window that comes up is "windows failed to start. a recent hardware or software change might be the cause" then it gives me options to fix the problem. but what i don't understand is that windows is still trying to start even though i want to go with Debian and continue install. at the bottom of this 2nd page it states "Info: the application or operating system couldn't be loaded because a required file is missing or contains errors."and I'm not sure that its saying that the Debian or the windows operating system couldn't be loaded. I'm assuming that windows wont allow Debian to install from this problem. (FYI)
