Jessie Buildbot amd64 sim
- Rick G
- Thank you received: 114
15 Sep 2015 20:46 #62614
by Rick G
Jessie Buildbot amd64 sim was created by Rick G
Although the buildbot page
buildbot.linuxcnc.org/
does not show any Jessie packages are they or will they be available?
Specifically looking for Jessie amd64 master-sim
Thanks,
Rick G
Thanks,
Rick G
- dgarrett
- Thank you received: 297
15 Sep 2015 21:04 #62615
by dgarrett
Replied by dgarrett on topic Jessie Buildbot amd64 sim
The following user(s) said Thank You: Rick G
- Rick G
16 Sep 2015 03:37 #62625
by Rick G
Replied by Rick G on topic Jessie Buildbot amd64 sim
Thanks, that was what I thought.
Earlier this morning before I posted the question I followed the instructions on the above link on a new jessie install changing...
deb buildbot.linuxcnc.org/ wheezy master-sim
deb-src buildbot.linuxcnc.org/ wheezy master-sim
to
deb buildbot.linuxcnc.org/ jessie master-sim
deb-src buildbot.linuxcnc.org/ jessie master-sim
Unfortunately I received an error message when I tried to install. Perhaps I missed something. Will try again when back at the office and make note of the error if any.
Thanks,
Rick G
to
Thanks,
Rick G
- Rick G
16 Sep 2015 15:33 #62635
by Rick G
Entered
/etc/apt/sources.list.d/linuxcnc-buildbot.list
Contains
Hit ftp.us.debian.org jessie/main Translation-en
Ign buildbot.linuxcnc.org jessie InRelease
Hit buildbot.linuxcnc.org jessie Release.gpg
Hit buildbot.linuxcnc.org jessie/master-sim Sources
Hit buildbot.linuxcnc.org jessie/master-sim amd64 Packages
Returns
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package linuxcnc-sim is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'linuxcnc-sim' has no installation candidate
Rick G
Entered
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E/etc/apt/sources.list.d/linuxcnc-buildbot.list
Contains
sudo apt-get updateHit ftp.us.debian.org jessie/main Translation-en
sudo apt-get install linuxcnc-simReturns
Rick G
- dgarrett
16 Sep 2015 21:10 #62640
by dgarrett
The jessie builds are very new so maybe the servers are not configured yet for apt.
You can download a deb and install:
$ wget http://buildbot.linuxcnc.org/dists/jessie/master-sim/binary-amd64/linuxcnc-uspace_2.8.0~pre1.1082.gaa37cb0_amd64.deb
$ ls
$ sudo dpkg -i linuxcnc-uspace*.deb
$ dpkg -l linuxcnc\*|grep ii
ii linuxcnc-uspace 1:2.8.0~pre1.1082.gaa37cb0 amd64 PC based motion controller for real-time Linux
$ which linuxcnc
/usr/bin/linuxcnc
- Rick G
17 Sep 2015 03:24 #62652
by Rick G
Thank you very much, that did the trick.
There was a dependency issue with...
But ran...
Which installed the missing packages.
Then everything installed properly.
Thanks,
Rick G
sudo dpkg -i linuxcnc-uspace*.debsudo apt-get -f installThen everything installed properly.
Thanks,
Rick G
- phoenix
12 Jul 2019 16:31 #139185
by phoenix
Replied by phoenix on topic Jessie Buildbot amd64 sim
i got same issue i have strech 2.7 and i want to upgrade 2.8
it says linuxcnc has no installation candidate
i also tried as u suggested but that also didnt work
wget returning error timeout
15 Jul 2019 12:21 - 15 Jul 2019 12:22 #139418
Replied by andypugh on topic Jessie Buildbot amd64 sim
To get 2.8 if you have 2.7 and are running Stretch then follow the buildbot instructions.
Last edit: 15 Jul 2019 12:22 by andypugh.
