Problem to install 2.7 in Ubuntu 12.04
10 Oct 2015 19:36 - 10 Oct 2015 20:07 #63667 by haithabu850
Problem to install 2.7 in Ubuntu 12.04 was created by haithabu850
I try to install Lunux CNC in a new Ubuntu 12.04 (32 Bit) system and use the manual: Getting Stated V2.7.0 (page 8)
www.linuxcnc.org/docs/2.7/pdf/LinuxCNC_Getting_Started.pdf
But if I reboot the system (point 8) and type "uname -r" in the Terminal the system print "3.13.0-65-generic" and not "3.4-9-rtai-686-pae"
Where or how I can change the setting?
Last edit: 10 Oct 2015 20:07 by haithabu850.
11 Oct 2015 08:56 - 11 Oct 2015 11:42 #63678 by ArcEye
Replied by ArcEye on topic Problem to install 2.7 in Ubuntu 12.04
The instructions are wrong (or incomplete to be exact).
When you install a new kernel, you have to run
sudo update-grub
or the kernel will never be presented in the boot menu, for you to select.
Do that and then reboot and the rtai kernel should be a boot option
Last edit: 11 Oct 2015 11:42 by ArcEye.
The following user(s) said Thank You: haithabu850
11 Oct 2015 13:17 #63681 by haithabu850
Replied by haithabu850 on topic Problem to install 2.7 in Ubuntu 12.04
Thank you,
But I had made ​​a second mistake.
after that the grub has to be edited.
the line:
GRUB_HIDDEN_TIMEOUT=0
has to be delete or edit to:
#GRUB_HIDDEN_TIMEOUT=0
Otherwise, the boot menu does not appear.
11 Oct 2015 13:58 #63683 by ArcEye
You can just hold down [Esc] during the boot, so long as your keyboard is recognised at boot.
The GRUB_HIDDEN and similar are a pain.
Jessie seems to be hiding all kernels / partitions other than the default booting one as a matter of course now, although you can select a menu item that will show you them if you are quick.
Time to create page: 0.175 seconds
