linux preempt and mesa ethernet card
- grub
- Thank you received: 3
18 Oct 2015 02:40 #63884
by grub
Thanks for the info. Added the missing part, although I really think that in the event of having to change the kernel from RTAI to RT/Preemt using a clean-install might be more sensitive than basically scrubbing everything...
If I am not mistaken this whole thing was a "RT≠RTAI" misunderstanding to begin with.
Replied by grub on topic linux preempt and mesa ethernet card
One missing detail is that you also need to install the uspace version of LinuxCNC
The wiki has instructions for the complete process
linuxcnc.org/docs/2.7/html/getting-start...th_preempt_rt_kernel
- johannbuck
18 Oct 2015 02:44 #63885
by johannbuck
Replied by johannbuck on topic linux preempt and mesa ethernet card
Thanks everyone, I think I'm finally ready to Install and use the preempt linuxcnc as soon as my ITX gets here.
I'm now ready to order the 7i92 and PCW, do I need the 7i76 breakout card or is there another one better for
connecting stepper drivers.
- grub
18 Oct 2015 02:54 - 18 Oct 2015 03:00 #63886
by grub
Following PCW's comment,
All the information for a clean install can be found here:
if there are any gaps in the documentation you can fill them with information from this post:
linuxcnc.org/index.php/german/forum/9-in...ssieq-and-linuxcnc27
Just make Jessie -> Wheezy, stick with 32-bit and you should have the desired outcome.
If you get stuck somewhere feel free to post in this board.
P.S. Can't really help you with the hardware. You might want to open another topic to elaborate on that one, as this one might attract the wrong (help with OS/Software) people.
it might be more sensible to install a clean version of Debian and then add the RT/Preempt kernel, rather than to basically completely change the pre-configured setup from RTAI to RT/Preempt.need to install the uspace version of LinuxCNC
Last edit: 18 Oct 2015 03:00 by grub.
The following user(s) said Thank You: johannbuck
- Thank you received: 5330
18 Oct 2015 07:43 - 18 Oct 2015 07:44 #63889
If you already have a parallel port breakout board you can use that with a 7I92
If you need a lot of I/O you can use a 7I92 with a 7I76, but in that case you are better off with a a 7I76E
(which does not need the 7I92 since the Ethernet interface is on board)
Replied by PCW on topic linux preempt and mesa ethernet card
Last edit: 18 Oct 2015 07:44 by PCW.
Time to create page: 0.399 seconds
